Photo - - - - -
New Xform Fit Function and More in Mastercam Design
  Posted by paulasworld , 22 June 2012 · 205 views
Intersecting and Trimming Solid Edges:Mastercam’s AutoCursor now recognizes intersections between wireframe geometry and solid edges without creating additional geometry first. You can also trim or extend wireframe geometry to solid edges using the existing Mastercam trimming functions.
Remove Solid History:The functionality from the NoHist C-Hook is now incorporated into the main Mastercam product. This function strips the list of operations or features from a solid model, leaving it as a “brick” in the Solids Manager. You can use this to prevent changes and protect your model.
Posted ImageMastercam’s AutoCursor recognizes intersections between wireframe geometry and solid edges without creating additional geometry first.Posted ImageXform Fit nests geometry along a vector.
Xform Fit:Xform Fit is a new function in Mastercam X6 that “nests” geometry along a vector, making it easier for you to make multiple copies between two defined points without knowing the exact distance between the points. This can be helpful when fitting parts between clamps and fixtures.
Trim/Divide Support:Mastercam X6 includes support for splines in Xform Divide for trimming curves or curves to be trimmed.
All and Only Mask – Arc Sweep:The All and Only masks now include the option to select arcs and circles with a sweep angle in mind. This is another way to speed up your geometry selection.
Posted Image
Feet/Inches:In the following Analyze functions, you can now see results in inches, feet/inches decimal, feet/inches fractional, millimeters, centimeters, or meters:
  • Position
  • Volume/Area, 2D Area
  • Volume/Area, Surface Area
  • Volume/Area, Solid Properties
https://blogger.goog...g.mastercam.com
June 2013
S M T W T F S
      1
2345678
9101112131415
161718 19 202122
23242526272829
30
Recent Comments
