Blade Expert
#21
Posted 17 April 2012 - 03:14 PM
#22
Posted 17 April 2012 - 03:33 PM
#24
Posted 17 April 2012 - 03:40 PM
Quote
Whats a bicycle? G-code programming? Bug free!
Mike
#25
Posted 17 April 2012 - 04:44 PM
#26
Posted 17 April 2012 - 05:48 PM
CNC Apps Guy 1, on 17 April 2012 - 01:48 PM, said:
+1000
#27
Posted 17 April 2012 - 11:22 PM
#28
Posted 18 April 2012 - 10:30 AM
If you installed the sample files you can open the Blade Expert sample file for review.
If you feel that you can comfortably program that file in less that 2 hours then Blade Expert is not for you.
If you only do these kinds of part occasionally Blade Expert is not for you.
If you don't have a modern CNC machine, capable of precise multiaxis, synchronized motion Blade Expert is not for you.
If you are a professional and serious about exploring multi-blade machining Blade Expert is definitely for you.
If you are already making a living cutting parts like these you will know what a bargain BE is in this field and Blade Expert is for you.
If you do a bit of research of what solutions are available on the market you will know what a bargain BE is.
Why use Mastercam Blade Expert? What is the Mastercam difference?
We have extensively tested our integrated solution . . . hands-on cutting parts on the machine during the BE integration process.
We are providing much more than just a tool, we have assembled a complete, customized solution.
We are so confident in our Blade Expert solution package that we will give you a money-back quarantine.
What is in the package?
The power of Mill Level 3
Blade Expert
We will program your first part and follow it through until you take the finished part off your machine. Train you along the way with your part and your machine.
We will help you calibrate your machine and fine-tune your post processor when needed.
We will build a virtual replica of your machine, so that you can see the whole manufacturing process on your screen before committing to the machine.
Unparallelled World-wide reseller support from the #1 CAM system.
We haven't seen a part we couldn't cut yet.
Don't try this at home, don't guess, don't make assumptions . . . talk is cheep.
Contact us if you are serious and let's cut your part together.
#29
Posted 18 April 2012 - 11:01 AM
#30 Guest_CNC Apps Guy 1_*
Posted 18 April 2012 - 11:26 AM
Karlo may speak softly but dayum he carries a big @$$ stick.
#31
Posted 18 April 2012 - 11:34 AM
#32 Guest_CNC Apps Guy 1_*
Posted 18 April 2012 - 12:03 PM
Doing it using conventional methods... probably closer to an hour.
Just sayin'
#33
Posted 18 April 2012 - 01:19 PM
Quote
#34
Posted 18 April 2012 - 01:41 PM
Blade Expert is a custom application that was developed specifically for impeller and other multibladed parts.
What used to take between 8-40 hours can now be done in under 4 hours.
It allows an unlimited number of splitters.
As far as some of the comments on other CAM packages.
• One of them was used as the benchmark when developing the Blade Expert product.
• The other one looks very similar to Mastercam Blade Expert.
At CNC Software we currently have 3 different five axis machines in our machine shop to test Blade Expert with.
We welcome the opportunity to demonstrate Blade Expert with your part, in your shop, cutting on your machine.
Challenge us, send us your toughest multibladed part.
Thank you,
Gene Welti
gene.welti@mastercam.com
Corporate Sales
CNC Software, Inc.
#35
Posted 18 April 2012 - 02:05 PM
It uses 2 ball nosed taper mills
#36
Posted 18 April 2012 - 03:23 PM
Quote
Without bull nose support, It wont work. The taper tools are great for finishing, but without the heavy stock removal support?
Maybe down the road they can support that
#37
Posted 18 April 2012 - 03:42 PM
Just sayin'
James - really? I mean REALLY
I know I am THE newbeeee and have a LOT to learn, but would this really only take an hour with 'std' mcam???
I mean, rub my nose it - I neeeeeeeeeeeed more lessons.
Wow, just wow.
#38
Posted 18 April 2012 - 03:47 PM
Quote
Don't worry Newbee, no one in the world is making MACHINE READY code for that part in one hour.
Mike
#39
Posted 18 April 2012 - 03:50 PM
Quote
+1+1+1
It's easy to "throw" a toolpath on a model
#40
Posted 18 April 2012 - 04:23 PM
