FEEDRATE F0.
from the X5 gen5x post
fix_fr : 1 #If feedrate is zero, apply these values
deffeedpm : 1. #Default for zero feed in inch/min
deffeedpm_m : 25. #Default for zero feed in mm/min
deffrinv : 500. #Default for zero feed inverse time
If you set fix_fr 0 nothing is done
set to 1 the following values are applied..
Z2G is to big for email. I'll try what TTom said. It doea appear it happens on very small moves around the edges
Y-.5057 Z.3168 A311.338 F10000.
Y-.51 Z.3098 A310.548 F10000.
Y-.514 Z.303 A309.79 F10000.
Y-.5153 Z.3008 A309.542 F0.
Y-.5201 Z.2924 A308.608 F10000.
Y-.5248 Z.2839 A307.675 F10000.
Y-.5291 Z.2755 A306.768 F10000.
I just do a global replace with F10000.
This is a bit of a cheat, but you can always just output the 10000 if the calculated feed is 0.
In pfclc_deg_inv:
       if cuttype = three, cldelta = sqrt((x$-prv_x$)^2+(y$-prv_y$)^2+(z$-prv_z$)^2)
       if inversefeed$ = 0, frinv = fr_pos$/cldelta  # 1/min
       else, frinv = fr_pos$/(60*cldelta)  # 1/sec
       if frinv = 0, frinv = 10000 <-- ADD THIS LINE
       if rot_feed & opcode$ <> 3 & opcode$ <> 16,
         if frinv > maxfrinv, frinv = maxfrinv
         if frinv < minfrinv, frinv = minfrinv
         feed = frinv
  • 1 year later...
Know this is an old thread, but I could really Use some help!
I'm Using a Mpmaster Post and when In G93 (Inverse) I'm not Getting a F. call at All on some lines! So this alarms the machine beacause G93 isn't modal on Haas anyways...
I applied the^^^ "cheat" in my post, But it doesn't see this Like the F0. problem. Any Ideas???
