Adding a decimal point to B moves
Good morning everyone. I am using a mpmaster post on an OKK 800 HMC. The machine has a live table so i need the B moves to output with a deciamal point after every B axis move. is this something in the post or in the machine def? I have played with both and have no results.
Thanks for any and all help.
fmt  X  2   xabs        #X position output
fmt  Y  2   yabs        #Y position output
fmt  Z  2   zabs        #Z position output
fmt  X  3   xinc        #X position output
fmt  Y  3   yinc        #Y position output
fmt  Z  3   zinc        #Z position output
fmt  A  11  cabs        #C axis position
fmt  A  14  cinc        #C axis position
fmt  A  14  cout_i      #C axis position
Use the debugger to find which variable (cabs is for absolute positioning, cinc for incremental) puts out your B moves, then change the format statement (replace the 11 and/or 14 with a 2 or a 3, respectively).
yes, i want B233. which i got by telling the machine def it was capable of continuous milling. but when i did that it put all the code between the lock and unlock code so i had to change the way it output that. It should work the way i have it.
Thanks again, have a great day.
  • 8 months later...
# Toolchange / NC output Variable Formats
fmt T 4 t$ #Tool number
fmt T 4 first_tool$ #First tool used
fmt T 4 next_tool$ #Next tool used
fmt D 4 tloffno$ #Diameter offset number
fmt H 4 tlngno$ #Length offset number
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
fmt N 21 n$ #Sequence number
fmt A 2 indx_out #Index position <<<<<<<<<<<<<<< B0. output
fmt R 14 rt_cinc #C axis position, G68
fmt I 3 iout #Arc center description in X
fmt J 3 jout #Arc center description in Y
fmt K 3 kout #Arc center description in Z
fmt R 2 arcrad$ #Arc Radius
fmt F 15 feed #Feedrate
fmt P 11 dwell$ #Dwell
fmt M 5 cantext$ #Canned text
fmt F 2 pitch #Tap pitch (units per thread)
