X+ Setup Sheet and Tool List - 3rd party Add-on
  • Please log in to reply
317 replies to this topic
#281 Günther Massimo - GMCCS
    Advanced Member
  • Resellers
  • PipPipPip
  • 429 posts
Posted 12 July 2012 - 08:09 AM
View PostJParis, on 11 July 2012 - 05:42 AM, said:
Should I be able to take my  jp.tl and jp.css and copy it to another computer?
I thought I might but I am getting an error when trying to launch it on the copied "to" computer
yes, that should work.
#282 JParis
JParis
    Advanced Member
  • Moderators
  • 23,606 posts
Posted 12 July 2012 - 08:13 AM
Hmm,
I'll have to get a screen cap off of my home computer and post it, I tried that and go an error message, it's in German, so I could decipher it  ;)
#283 JParis
JParis
    Advanced Member
  • Moderators
  • 23,606 posts
Posted 15 July 2012 - 06:37 AM
Trying to figure what's going on, I coped my jp.tl and jp.css from another computer to this one and get this error
#284 Guest_CNC Apps Guy 1_*
  • Guests
Posted 15 July 2012 - 09:48 AM
Basically , the file it is attempting to access has a (a word I've never seen before) without a name after its end.
That's what it said. Maybe a wrong file extension or if there's a file extension listed in the file that is wrong. I guess Those two years of french do come in handy from time to time.
Finchier... :headscratch:
#285 JParis
JParis
    Advanced Member
  • Moderators
  • 23,606 posts
Posted 15 July 2012 - 09:51 AM
Ahh, if it's in French, I'll just ask my wife.
Being married to a canuck comes in handy occasionally  :D
:looking over my shoulder warily:
#286 Guest_CNC Apps Guy 1_*
  • Guests
Posted 15 July 2012 - 06:58 PM
:thumbup:
#287 PLANET
PLANET
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 16 July 2012 - 09:57 AM
View PostAlex_AMEAB, on 18 June 2012 - 06:08 AM, said:
Have anyone else had problems copying the css and xss file from X5 to X6? It worked fine from X4 to X5, but now i get an error when X+ is trying to read the files.
Error message "Attempted to access an unnamed file past its end."
Anyone find an answer to this??
I'm getting the exact same message.
Thanks.
#288 Günther Massimo - GMCCS
    Advanced Member
  • Resellers
  • PipPipPip
  • 429 posts
Posted 17 July 2012 - 02:41 AM
Thanks.
You can not use the files from from X5.
X+ for X6 is not compatible with the old files.
#289 miguelhot
miguelhot
    Newbie
  • Customers
  • Pip
  • 2 posts
Posted 20 July 2012 - 08:14 AM
View PostGünther Massimo - GMCCS, on 30 December 2011 - 07:55 AM, said:
X+ for X6 is on the way.
But since X6 is available as 64Bit version, I decided to convert X+ from Masm32 to VC++.
That makes it easer to maintain both versions (32Bit and 64Bit).
I've started with the Setupsheet. The "tool list" and the "toolpath sketcher" will follow.
hi a question how can i change the logo in x+ for x6 , x5 was easy ,but in x6 is been really hard, thanks
#290 JParis
JParis
    Advanced Member
  • Moderators
  • 23,606 posts
Posted 20 July 2012 - 08:19 AM
Start here, it was searchable,  and it's in this thread already
http://www.emasterca...ndpost&p=784105
#291 Thad
Thad
    Highly Advanced Member
  • Members
  • PipPipPip
  • 10,782 posts
Posted 27 July 2012 - 08:20 AM
I'm using the latest version of X+. I use Z-Max and Z-Min to help the operator determine the tool length needed for the program. In X2, and even X5 it appears, the Z-Max value is the absolute Z value of the feed plane. For example, if the top of my part is Z0 and I cut from Z0 to Z-.5, the Z-Max value is Z.1. What I'm seeing in the latest version is that the Z-Max value is using the clearance plane. Is this a bug? Z-Max and Initial Height output the same thing except Initial Height has the (abs) by it.
I've tried using Top of Stock and Feed Plane, but none of them give me what I'm looking for. I'm looking for absolute values of where the toolpath starts and where it ends. Will one of the options give me that?
On another note, I have a suggestion. I suggest that only absolute values are used in all fields and eliminate the (abs) or (inc). I don't see how incremental values such as 0 are of any use to anyone. Incremental values are based on the Z level at which the geometry resides. That's totally irrelevant to the operator who uses the setup sheet. Gunther, please take this constructively as it is intended. :)
Thad
#292 shazam/TPP
shazam/TPP
    Advanced Member
  • Members
  • PipPipPip
  • 1,565 posts
Posted 28 September 2012 - 06:40 AM
bump new release of x+ on 9/24/12
#293 Thad
Thad
  • Members
  • PipPipPip
  • 10,782 posts
Posted 28 September 2012 - 08:23 AM
Still has the Z-Max issue from my previous post. :(
I haven't had a chance to take a real good look at it yet, but at first glance, it appears that the CSS needs some work. My company logo and header info are overlapping.
#294 JAMES GABEL
JAMES GABEL
    Advanced Member
  • Members
  • PipPipPip
  • 304 posts
Posted 28 September 2012 - 03:45 PM
I am still lost on how to X+ to work on X6.
#295 Thad
Thad
  • Members
  • PipPipPip
  • 10,782 posts
Posted 28 September 2012 - 09:01 PM
Two people have tried to help you and you've ignored them so far. :rolleyes:
#296 Todd Mann from Fastech
    Member
  • Members
  • PipPip
  • 229 posts
Posted 01 October 2012 - 07:58 AM
I have loaded X+ and have created a couple of tool list and set-up sheets. When I created a tool list as a .xml and I have it output a tool bitmap it does show the bitmap of the tool on the spread sheet. Is there something I need to do differant?
#297 John Hill @ Poplar Hill Machine
    Member
  • Members
  • PipPip
  • 112 posts
Posted 22 October 2012 - 06:21 AM
I'm using the css/html version of the setup sheet and when loading a previously saved configuration, the first preview in the browser is not properly formatted.
Correct formatting returns on subsequent views...at which point the "default_tl.tl" is overwritten with my saved configuration info.
Anyone else having trouble saving & re-loading with proper formatting?
John
#298 Thad
Thad
  • Members
  • PipPipPip
  • 10,782 posts
Posted 22 October 2012 - 07:52 AM
View PostJohn Hill @ Poplar Hill Machine, on 22 October 2012 - 06:21 AM, said:
John,
So you create the sheet and it isn't displayed properly, then you refresh the page and it appears like it should?
What exactly do you mean that it doesn't have proper formatting? Can you give us a screenshot? It kinda sounds like the CSS isn't being read, but I'd have to see it to say for sure.
Thad
#299 John Hill @ Poplar Hill Machine
    Member
  • Members
  • PipPip
  • 112 posts
Posted 22 October 2012 - 08:36 AM
Here's my steps and screen shots:
1 - Load saved configuration:
2 - View report 1st time NO formatting:
3 - Re-launch X+ - 'default_tl.tl' now overwritten with my SAVED config info:
4 - View report 2nd time - now has proper formatting:
So what am I doing wrong???
John
#300 John Hill @ Poplar Hill Machine
    Member
  • Members
  • PipPip
  • 112 posts
Posted 22 October 2012 - 10:00 AM
Just noticed that if I click on the CSS button after loading one of my saved configs, it give me an error message:
   Cannot find the C:\Documents and Settings\All Users\Documents\X+\<<<My Saved Config Name Here>>>.css file.
   Do you want to create a new file?
So...it appears that when click the Save button, only the .tl file is created and not the related .css file.
This is why the second viewing works...default_tl.tl is  overwritten with the saved config data and the default_tl.css file already exists.
Or I could be completely wrong!
John
