peck drill post error
My lathe post creates the following for peck drilling. Peck depth is supposed to be 0.05". Any suggestions on what to fix in the post?
(And, is it possible to get the subsequent rapid to stop just before the last drill depth, without writting a custom drill cycle?)
N110 G0 X1.0 Z6.0
N120 G0 T0707 M41
N130 G97 S2000 M03
N140 G0 X0. Z.05 M8
N150 Z.1
N160 G99 G1 Z.04 F.005
N170 G0 Z.1
N180 Z.04
N190 G1 Z-.02
N200 G0 Z.1
N210 Z-.02
N220 G1 Z-.0506
N230 G0 Z.1
N240 Z-.0506
N250 G1 Z-.0662
N260 G0 Z.1
N270 Z-.0662
N280 G1 Z-.0742
N290 G0 Z.1
N300 Z-.0742
N310 G1 Z-.0782
N320 G0 Z.1
N330 Z-.0782
N340 G1 Z-.0803
N350 G0 Z.1
N360 Z-.0803
N370 G1 Z-.0814
N380 G0 Z.1
to infinity pecks...
claya
Looks like, it's likely that your control def is set to not support peck drilling and/or, your post doesn't support a G83 function if that's what you were expecting to see.
Go into your control def...machine cycles....lathe drill cycles and see if Peck Drill Full retract is checked.
If it is not, check it, you may get a customize drill cycle message then, if you do, your post will need editing to support eh G83 cycle
hth
The control is certainly setup for longhand peck drilling. Since it is, you will need to use the mastercam defined drill cycle parameters (first peck, subsequent peck, peck clearance, etc). Even if these values are greyed out, they may effect your output. As grammin mentioned if you are looking for a canned cycle, you will need to enable that option in your control def and then modify the post to match your desired output.
