Auto Cursor in X
  • Please log in to reply
46 replies to this topic
#1 heeler
heeler
    Advanced Member
  • Members
  • PipPipPip
  • 523 posts
Posted 16 August 2005 - 03:14 AM
Is there a way to turn the auto cursor off in X?  I really hate the auto cursor and like to just push the keyboard button to have the cursor select center, endpoint, ect.
DID I SAY I HATE THE AUTO CURSOR.
I see so many error here with the people using the auto cursor.  Just a slight movement of the mouse and you don't get what you wanted.
Hopefully someone can help.  I don't want to have to use the autocursor screen every time, and I don't want to rely on the little, little picts of tangent, endpoint, ect.
Glenn
P.S.
#2 Cadcam From Cad/Cam Consulting
    Advanced Member
  • Members
  • PipPipPip
  • 8,760 posts
Posted 16 August 2005 - 03:21 AM
Do a right click option and pick Autocurser and then unselect all in the option window.
#3 gcode
gcode
    Serenity
  • Moderators
  • 19,858 posts
Right clck, autocursor, disable all.
Unfortunately, the single key shortcuts
C = center, M = midpoint, E = endpoint etc are gone.
Personally I like the autocursor a lot, but I miss the single key shortcuts. It would be nice
if we could make the ltlle autocursor snap symbols
bigger.
#4 BBOwen
BBOwen
    Advanced Member
  • Members
  • PipPipPip
  • 662 posts
Posted 16 August 2005 - 03:23 AM
I love the auto cursor. I am used to autocad so I like it and the custom features it has.
#5 heeler
heeler
    Advanced Member
  • Members
  • PipPipPip
  • 523 posts
Posted 16 August 2005 - 03:47 AM
Jay,
I did that, but then how do I select the point that I want?
Glenn
#6 Mike Mattera - TFM
Mike Mattera - TFM
    Advanced Member
  • Members
  • PipPipPip
  • 1,163 posts
Posted 16 August 2005 - 03:54 AM
I dont understand why people would want to pick something manually when they can select it by just pointing. What could be eaiser than just moving over the endpoint to select the endpoint. How could picking another key, with your mouse of menu, possibly be easier?
Maybe your just getting too many choices.
Above the ribbon bar there ia an Exclmation mark Icon ( ! )  that says Config (when you mouse over it).  Pick that and turn off the snap functions you DONT want to use. This lets you be more selective about how the autocursor works.
Mike Mattera
#7 Robert Bernobic from CNC Software
    Member
  • CNC Software
  • PipPip
  • 101 posts
Posted 16 August 2005 - 04:00 AM
"Unfortunately, the single key shortcuts
C = center, M = midpoint, E = endpoint etc are gone..."
...but not forgotten. Go to Settings, Key mapping, select AutoCursor from Category list, and you can create shortcut keys to whatever selection modes you want. Go to Settings, Customize, and you can add them to the right-click menu.
--Robert
#8 The Dude
The Dude
    Member
  • Members
  • PipPip
  • 56 posts
Posted 16 August 2005 - 04:05 AM
Under settings>customize>drop down>right click>>
you can add origin,endpoint, etc (from auto cursor). Then when a function like line is active you can just right click for what you need.
#9 The Dude
The Dude
    Member
  • Members
  • PipPip
  • 56 posts
Posted 16 August 2005 - 04:07 AM
I knew that would happen  graemlins/cuckoo.gif
#10 Cadcam From Cad/Cam Consulting
    Advanced Member
  • Members
  • PipPipPip
  • 8,760 posts
Posted 16 August 2005 - 04:10 AM
there is an option button to the right of were you type a value.
    Posted Image
#11 smokey_44
smokey_44
    Advanced Member
  • Members
  • PipPipPip
  • 554 posts
Posted 16 August 2005 - 04:11 AM
I haven't got X yet but I know now that picking c  for center and using keyborard is ALOT faster that some auto cursor. Never liked the feature at all cause it always slows me down, Hopefully they will (cnc) put these options back in
Dave
#12 smokey_44
smokey_44
    Advanced Member
  • Members
  • PipPipPip
  • 554 posts
Posted 16 August 2005 - 04:12 AM
Dave
#13 smokey_44
smokey_44
    Advanced Member
  • Members
  • PipPipPip
  • 554 posts
Dave
#14 smokey_44
smokey_44
    Advanced Member
  • Members
  • PipPipPip
  • 554 posts
Posted 16 August 2005 - 04:13 AM
Dave
#15 heeler
heeler
    Advanced Member
  • Members
  • PipPipPip
  • 523 posts
Posted 16 August 2005 - 04:32 AM
Jay,
That is what I wanted to get away from.  I really hate to have to click all over the screen, I really liked the way that in V9, I could be in the create function and with auto cursor off, could just push the button on the keyboard and know that it would only select what I wanted.  A simple click on the keyboard and I would only get what I wanted now.  I couldn't begin to count how many times I have went out with our operators looking at why a machine or Mcam was F'd up.  Just to find that they had used auto cursor(a near as I could figure) to select something and had it use the wrong thing.
Glenn
I would like to repeat
p.s.
I'll have to check out the key mapping thing
#16 Paul McGarr
Paul McGarr
    Advanced Member
  • Members
  • PipPipPip
  • 397 posts
Posted 17 August 2005 - 02:33 AM
EDIT - Double Post
#17 Paul McGarr
Paul McGarr
    Advanced Member
  • Members
  • PipPipPip
  • 397 posts
Posted 17 August 2005 - 02:34 AM
I never use autocursor because it is too easy to accidently slip into sketch mode.  I understand that you have some control over this in X so I will try it again. In the meantime, is there any way to customize autocursor in version 9 to keep it from sketching?
Paul
#18 Thad
Thad
    Highly Advanced Member
  • Members
  • PipPipPip
  • 10,782 posts
Posted 17 August 2005 - 03:45 AM
I always thought it was pretty obvious when the big square disappeared.  graemlins/headscratch.gif
Thad
#19 Paul McGarr
Paul McGarr
    Advanced Member
  • Members
  • PipPipPip
  • 397 posts
Posted 17 August 2005 - 03:57 AM
It is obvious that when the big square disappears, you are sketching.  If you are moving fast, the big square could be just disappearing as you click leaving you with a sketched point that looks real close to being in the correct place.  What you end up with is a hole out of position.  Even worse, it's so close that you might not even notice it until inspection.
I'm not asking for opinions as to why I shouldn't worry about accidently sketching.  I'm asking if there is a way to customize autocursor in v9.  I'm  happy to know that it's available in x though.
Paul
#20 chris m
chris m
    Advanced Member
  • Members
  • PipPipPip
  • 5,800 posts
Posted 17 August 2005 - 05:06 AM
Paul, you are a man after my own heart
