COMMUNICATION 9.1
  • Please log in to reply
4 replies to this topic
#1 MAZAK640
MAZAK640
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 28 July 2010 - 04:20 AM
I am using draft 9.1 to communicate with a fanuc 21t control on a lathe.The cable connection is a smart cable(automatically configures pin connections)to RS232 Express card, which I have used in the past for transmitting back and forth.I recently started using a new laptop and the problems have started.The only lathe settings are, the port you are using, the stop bits, baud rate. I am matching Mastercam's settings but I can't transmit.It appears that Mastercam can send without errors but the Lathe is not reading and also it appears that the lathe is trying to punch but Mastercam is not recieving.
Anybody have any ideas ?
#2 Crazy^Mill/Turn
Crazy^Mill/Turn
    Regular Guy
  • Members
  • PipPipPip
  • 10,545 posts
Posted 28 July 2010 - 05:29 AM
Yeah go back to the old computer. You probably had a serial port that you were using and not trying ot use 3 different adapters to accomplish the same task and you are going to fight and fight till you just deal with the fact older equipment has problems. If the old computer died go to ebay and get a replacement one pretty cheap. Not trying to be mean, just stating the facts.
#3 billyc_
billyc_
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 16 August 2012 - 08:50 AM
Did you ever get you problem fixed? I'm having the same problem with communicating Haas Mill. The same with you got a laptop hoping to make my life easier and like you can't get it to communicate.
#4 lazyboy
lazyboy
    Member
  • Members
  • PipPip
  • 260 posts
Posted 16 August 2012 - 09:00 AM
Might want to look at comm port setting? just a wild guess
#5 billyc_
billyc_
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 19 August 2012 - 12:32 AM
The comm port setting was the first setting that I looked at lazyboy. Thank you any way I figure the problem out.
