# 0-80 tap on 316 Stainless steel
  • Please log in to reply
14 replies to this topic
#1 Metric
Metric
    Member
  • Members
  • PipPip
  • 47 posts
Posted 08 September 2011 - 11:08 PM
Hello all.
I need tap a punch of #0-80 on 316L blind holes.Please give me some speed recommendation.
I had Kennametal roll tap in hand now.
Thanks in advance.
MDT.
#2 Goldorak
Goldorak
    I Live. I Ride. I am Jeep.
  • Members
  • PipPipPip
  • 1,619 posts
Posted 09 September 2011 - 06:18 AM
use taping paste instead of coolant, the tool lige will be 100x longer
and be sure to hold the pre drill diameter to the tap spec a 80 TPI thread is freakin' small, just drill .005 to .007 bigger you wont get any thread in your hole
a 0-80 has .059 od and for a roll tap the tad drill size is .048 to .055
#3 Metric
Metric
    Member
  • Members
  • PipPip
  • 47 posts
Posted 09 September 2011 - 09:06 AM
Thanks Goldorak,
How about spindle speed or SFM recommendation?
MDT.
#4 Matthew Hajicekā„¢ -Midland Tech
    Advanced Member
  • Members
  • PipPipPip
  • 4,657 posts
Posted 09 September 2011 - 09:30 AM
That will depend largely on how quickly your machine can accelerate and decelerate.  If you program for a good SFM I doubt the machine will get going that fast before getting to the bottom of the hole.
#5 Metric
Metric
    Member
  • Members
  • PipPip
  • 47 posts
Posted 09 September 2011 - 10:25 AM
We have Kitamura CAT30 taper with Fanuc control,I think the speed response is not the problem.
The main question is with the 0-80 TPI normally how much the SFM would be for 316L?
Thanks.
#6 Ron Branch @ 5th Axis
    Regular Guy
  • Members
  • PipPipPip
  • 589 posts
Posted 09 September 2011 - 11:15 AM
45 sfm would be pushing it IMHO, 20-25 sfm should be a good SFM for that material.
#7 Metric
Metric
    Member
  • Members
  • PipPip
  • 47 posts
Posted 09 September 2011 - 02:29 PM
Hello Ron,
Thank you a lot.That will give me start point to work with.By the way,are you still work with the company in Brea?
MDT.
#8 GIZMO 21
GIZMO 21
    Member
  • Customers
  • PipPip
  • 128 posts
Posted 09 September 2011 - 04:54 PM
also increase your ref. plane to like Z.250 to give enough time to sincronize.
#9 Guyinthedesert
Guyinthedesert
    Member
  • Members
  • PipPip
  • 292 posts
Posted 09 September 2011 - 05:16 PM
I would go with a threadmill.
If you want to tap it, use an Exo VC10 or an Emugee tap. I, myself never tried roll taps on 316.
#10 Metric
Metric
    Member
  • Members
  • PipPip
  • 47 posts
Posted 09 September 2011 - 06:59 PM
Hello All Bro.'s
Thanks a lot for the in put.I will let you guy know the result on Monday.
Regards.
MDT.
#11 Buddy J
Buddy J
    Member
  • Members
  • PipPip
  • 139 posts
Posted 09 September 2011 - 07:50 PM
Not that you want to mess with the mess but I tapped dozens (full run) of 0-80's
in A286, (much nastier than 316) @ 500 RPM, 6.25 IPM using MolyDee tapping fluid.
PITA but worked well
#12 Tim Johnson
Tim Johnson
    Advanced Member
  • Members
  • PipPipPip
  • 2,382 posts
Posted 10 September 2011 - 03:41 PM
Quote
I've never understood that logic.
How much Z do I need to give for enough time to synchronize out of the hole?
Edit: I'm showing 40sfm in my speed chart.
#13 dylskee
dylskee
    Member
  • Members
  • PipPip
  • 43 posts
Posted 10 September 2011 - 08:01 PM
Not out of the hole but when the tap enters the hole. This doesn't really apply to newer machines, for the old klunkers it was a good idea to start the tapping operation .250 above the hole to allow the spindle to get to full RPM for entering the drilled hole. I've tapped at 2000 RPM at .050 above the hole but that was with a Brother tapping center and that's what they are made to do.
#14 Metric
Metric
    Member
  • Members
  • PipPip
  • 47 posts
Posted 16 September 2011 - 10:45 PM
Thanks you for all input,I finished the job today,with Kennnametal rolling tap at 400 spindle speed,all 120 holes without any problem.
Again thanks a lot for you help.
MDT.
#15 Mic6
Mic6
    Advanced Member
  • Members
  • PipPipPip
  • 3,235 posts
Posted 19 September 2011 - 07:27 AM
View PostBuddy J, on 09 September 2011 - 07:50 PM, said:
MolyDee
^  that
