Help with tooling
  • Please log in to reply
3 replies to this topic
#1 SpecialtyTool
SpecialtyTool
    Member
  • Members
  • PipPip
  • 84 posts
Posted 08 November 2011 - 06:00 AM
Does anyone know where I can find a long woodruff cutter? At least an 1" in cutter diameter. I am trying to machine a counterbore on the bottom a part that needs to be in line with a bore on top within a few tenths. I'll give you the dimensions of the counterbore I am making. I will be reaching 3.600" deep through a 1.200" diameter hole to machine a 1.460" diameter counterbore that is .520" deep. So I need over 1/4" difference between the diameter of the cutter and the diameter of the shank. And did I mention I have about .0005" tolerance on the diameter of the bore? I had thought about going through the part and back boring it but I am having trouble locating the tooling for this approach as well. Any advice would be appreciated.
#2 dfedwards
dfedwards
    Member
  • Members
  • PipPip
  • 61 posts
Posted 08 November 2011 - 09:59 AM
You may want to look at Iscar Multi-Master. These are solid carbide cutter heads that are threaded into a Multi-Master shank. The heads are available in many different types of configurationa and the shanks are also (straight, tapered, steel, solid carbide, etc.) Hopefully this helps.
#3 dfedwards
dfedwards
    Member
  • Members
  • PipPip
  • 61 posts
Posted 08 November 2011 - 10:00 AM
Also, for the back boring, PhHorne offers a large variety of tooling for this.
#4 JParis
JParis
    Advanced Member
  • Moderators
  • 23,602 posts
Posted 08 November 2011 - 10:43 AM
AB Tools
http://www.abtoolsinc.com/
If they don't have it, they make them pretty quick too
