* * * * * 1 votes
Old bugs back again. Thanks alot CNC!
  • Please log in to reply
786 replies to this topic
#761 GoetzInd
GoetzInd
    Master Machine Masher
  • Members
  • PipPipPip
  • 1,011 posts
Posted 26 March 2012 - 06:24 AM
Quote
Or they could just fix it.....
That's crazy talk!  :harhar:
#762 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 26 March 2012 - 06:42 AM
View PostRickster™, on 26 March 2012 - 06:12 AM, said:
Or they could just fix it.........(for ppl who don't read the forum or are noobs).....:whistle: :welcome:
Why bother fixing it when we have such great "work arounds" to work with.  ;)
#763 Guest_CNC Apps Guy 1_*
  • Guests
Posted 26 March 2012 - 11:14 AM
What I don't get in this whole discussion about tool offsets and whatnot, is why people don't want refuse to take advantage of functions in the machine that will eliminate a whole host of possible issues that are not even CAM related. I mean hey, it's your machine, use it how you want, but you're really missing out.
#764 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 26 March 2012 - 11:28 AM
Our Mori is set up so that H200 and D200 are always used and we do not have this issue in that machine.
I think that the point is more that you should NOT have to worry about the CAM system outputting faulty numbers. If the CAM system were working properly we would not be having this discussion in the first place. The fact that this particular issue has been around for so long and obviously very well known about by CNC is troubling.
We have a couple of older machines here that are not able to hold the same tolerance on a small diameter hole as on the larger. We use multiple diameter offsets to regulate the hole sizes. On those machines we cannot have a hard coded H or D value unless we want to have to hand edit the necessary programs. I should be able to have faith in my CAM system to output the proper H and D values should I not?
I have allot of respect for you James but this is something that is difficult for me to understand. Height and Diameter values are one area that I would hope that I would not have to fight with this system to output proper values. Regardless how how easy it is to manipulate in to our post.
#765 Rickster™
Rickster™
    MOBSTERATOR
  • Moderators
  • 12,165 posts
Posted 26 March 2012 - 11:29 AM
Quote
but not all??
Neurosis, James is just trying to clarify that CNC may never fix the issue so
You might be better off to fix it by post warning or hard coding etc...
James, for the record, I have fixed my H and D zero issues, sorry I forgot to tell you.... ;)
Now I just have several other issues that plague me that have
no work around, but i hear MU1 will fix them.. :cheers:
#766 gms1
gms1
    Advanced Member
  • Members
  • PipPipPip
  • 883 posts
Posted 26 March 2012 - 11:31 AM
I don't come across the tool renumbering issue very often and I think it's because it HAS burned me so I go out of my way to make sure it doesn't happen again, but this most certainly IS CAM related. If I open my mastercam file I expect to see the tool numbers / offsets match what is in my posted code. Yes, I can make the post edits to fix this and in some cases I have... I just don't like doing it because I want the data to match.
#767 Watcher
Watcher
    Advanced Member
  • Members
  • PipPipPip
  • 509 posts
Posted 26 March 2012 - 11:38 AM
It's always great to hear about real life examples that are often underestimated by CAM developers and their QA teams.
+10K to Neurosis.
#768 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 26 March 2012 - 11:42 AM
This is my feeling on the matter. I want my part file to be correct. I do not want my post fixing xxxx ups that are caused by the CAM system.
Eventually, once I get some free time ( I havent had very many spare blocks of time since getting the new machines )  I will be implement something similar to what newb has.
#769 Wes@M.A.D.
Wes@M.A.D.
    Axis Choreographer
  • Moderators
  • 5,964 posts
Posted 26 March 2012 - 11:44 AM
Quote
words from a true AE :sleeping:
we have some of those Zombies walking around here too
We have over 80 CNC's on the floor to deal with on a DAILY basis. a multitude of different controls and machine types. I would expect my cadcam software to behave as it should/used too. It's one thing to have weeks on end to play with controls and software, It's a whole other ballgame helping to keep a manufacturing company going strong with random H,0 tool and work offsets and what else happening at random.
This release has really made ( he who's name must not be mentioned) looking right on target
#770 Guest_CNC Apps Guy 1_*
  • Guests
Posted 26 March 2012 - 11:45 AM
The reason I say T/H/D mis-match is not necessarrily a CAM issue is because in a lot of instances, people will change a tool number for testing, setup guys will make a fixture and write the code by hand if it's simple enough and then be about their business. So, with that being said, it's a REAL simple, EXTREMELY effective TOOL to add some logic to the tool change cycle in the machine to capture the T# and place that value in a MACRO variable, then use the MACRO variable for your H's and D's. So when you want to change a tool, you change the T# once (with no regard for H/D) or twice if you stage tools. I've been doing it this way since before I even used Mastercam. That is why I say this is not necessarrily a CAM issue. In your particular instance it is a CAM generated issue, but T/H/D mismatches have been happening since LONG before I even saw my first CNC machine.
#771 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 26 March 2012 - 12:04 PM
While that may be true, I have been programming since 1990 and Mastercam is the ONLY system that I have used that has output wrong H and D values.
#772 Rickster™
Rickster™
    MOBSTERATOR
  • Moderators
  • 12,165 posts
Posted 26 March 2012 - 12:10 PM
^^^^same here
#773 Teh Bear without Brains kinda idiot
    Advanced Member
  • Members
  • PipPipPip
  • 1,484 posts
Posted 26 March 2012 - 01:01 PM
+1000
especially when you translate your toolpath but can happen anywhere and be weird
2 different tools can have same number too even after renumber
#774 newbeeee
newbeeee
    old but NOT grown up
  • Members
  • PipPipPip
  • 973 posts
Posted 26 March 2012 - 01:23 PM
If you want a copy of our post, PM me and you're welcome to it.
#775 Mick
Mick
    Bueller? Bueller?
  • Resellers
  • PipPipPip
  • 1,366 posts
Posted 28 March 2012 - 05:17 AM
View Postnewbeeee, on 26 March 2012 - 04:48 AM, said:
Mick,
If a situation happens where H+D do not match T number, when posting it flags a warning saying
PLEASE CHECK THE TOOL OFFSETS. OPERATION ID NUMBER = # (where # is the offending op number).
It then allows you to post and the code shows upto the offending op number, which then has a note saying OPERATION ID # and goes no further.
So it is a very safe warning.
Ah, ok, it actually halts the posting. That is a better option.
#776 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 18 April 2012 - 07:30 AM
Apparently there have been a few bugs missed.  ;)
I changed a z value in a roughing operation and it dirtied a transformed operation (as expected). I tried to re-run the transformed operation and it failed.  Then I noticed that it dirtied two other "entire" tool path groups in a completely different machine group.
ACK!
This was an X5 file pulled in to X6.
#777 GoetzInd
GoetzInd
  • Members
  • PipPipPip
  • 1,011 posts
Posted 18 April 2012 - 07:38 AM
I'm not really surprised they missed a lot of stuff. I'm sure they were trying to fix the big ones first. My biggest day to day problem is with the stability of tool/holders. It is still a disaster. I am working on documenting it better by screen recording an entire part so CNC can see what I am dealing with and hopefully fix/offer some assistance.
Mike
#778 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 18 April 2012 - 07:48 AM
I dont think that this is something that was missed. I think that this might be something new. Edit: I mean from X5 to X6, not sure about X6 to X6 mu1.  I no longer have X6 (non mu1) installed so I cant test it.
I have a roughing operation that was mirrored.  I used "by geometry" rather than "nci"
The previous operations that went dirty are not linked to this operation in any way.  when I tried to regen the transformed operation it flopped the wcs for the operations that were in the other machine group completely upside down.  Look at both of my screen shots.
This is hilarious.
The screen shot on the right is proper, the one on the left is the flopped wcs.
I did just re-open the original file in X5 and was able to regen the mirrored operation without any problem.
#779 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 18 April 2012 - 08:05 AM
Ok,
After attempting to regen the transformed operation a couple of times, I decided to delete it and create it from scratch and everything worked fine. No more flopped wcs.
X6 does not like the X5 transformed operation.   ;)
#780 rjw
rjw
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 22 August 2012 - 12:08 AM
Wow....I've been using Mcam since 3.11 and never upgraded since V9 !!!!!  May be missing some of the new hs paths, but parts come out of the machines regularly  and without a hitch
Now decided to look at the 'latest and greatest X6' and found this thread......too funny and very sad .......while playing with X6, I've watched some strange stuff happen on screen, but thought it was me!!
I did have some success with fbm (simple parts)
Need to keep my ear to the ground, cause I may be going to a new job with 8 - 10 cnc's and I'm expected to impress my Boss with X5...ouch?
