New Machine!
  • Please log in to reply
20 replies to this topic
#1 MIKE_B
MIKE_B
    Advanced Member
  • Members
  • PipPipPip
  • 451 posts
Posted 28 January 2012 - 09:23 AM
Hi All
I am totaly new to Horizontal machining.  We are getting a new Mori NHX4000 with a MAPPS IV control (I know nothing about this control).
This will be a single pallet changer with future palns to add CPP system.
List of options we are getting:
1: 120 tool capicity
2: Full 4th axis rotary table
3: Through spindle coolant
4: Optical spindle touch sensor (Renishaw)
5: Table touch sensor (Metrol)
6: SSS control (Not sure what this is yet)
Can you guys tell me some must haves or any other info your willing to share?  And also do I go to my reseller for a post or do we try and get one with the purchase of the machine?
Look forward to hearing your thoughts
Mike
#2 Hardmill
Hardmill
    Anti-Moderator
  • Members
  • PipPipPip
  • 17,272 posts
Posted 28 January 2012 - 12:43 PM
Ive used the MPmaster post for this type machine with only a few cosmetic tweaks.
PEACE :D
#3 EX-wccprogrammer
EX-wccprogrammer
    Advanced Member
  • Members
  • PipPipPip
  • 391 posts
Posted 28 January 2012 - 12:48 PM
We have a NH4000 (not NHX).  Ours uses a very lightly modified MPFan post.  You should not need a custom post for your machine.
#4 Joe788
Joe788
    Advanced Member
  • Members
  • PipPipPip
  • 3,272 posts
Posted 28 January 2012 - 01:08 PM
MPMaster HMC (or VMC modded for HMC depending on your tastes) will be just about post&go straight out of the box, as long as you're not doing simultaneous 4th axis milling.
#5 JMC
JMC
    Advanced Member
  • Members
  • PipPipPip
  • 843 posts
Posted 28 January 2012 - 01:10 PM
MPMASTER is the way to go like others have said....maybe a few minor tweeks that can easily be addressed on this forum. 120 tools? get more now if you have the option.....120 may seem like alot now, tho trust me on this....the more the better. I am now working with machines that have 320 tools (50 taper) and that is not enough. Granted, it will take you a few years to grow into these large magazines.....once you do you will realize the benefits ($$$)
Quote
not sure what that is. Whatever it is make sure you have a touch probe and laser detection.
#6 mkd
mkd
    Advanced Member
  • Members
  • PipPipPip
  • 579 posts
Posted 28 January 2012 - 03:17 PM
mori likes to sell a full forth axis drive, then charge extra for inverse time feed as an option. asinine...
#7 JMC
JMC
    Advanced Member
  • Members
  • PipPipPip
  • 843 posts
Posted 28 January 2012 - 08:13 PM
Thats a Fanuc thing....Mori is not to blame for this.....I have seen this on more than one make. You are right tho....it should be standard
#8 DavidB@Sandvik
DavidB@Sandvik
    Advanced Member
  • Members
  • PipPipPip
  • 3,969 posts
Posted 28 January 2012 - 09:05 PM
Will you look at Esprit seeing you will get a seat with that machine?
Esprit will be set for your machine with a fully functional post and machine definition for maching simulatoin.
You will have a floating licence of Esprit in the machines controller so you can set it up on a PC
#9 Guest_CNC Apps Guy 1_*
  • Guests
Posted 28 January 2012 - 09:06 PM
Inverse (or lack thereof) is ALWAYS a builder issue. They chose not to make it standard.
Back to 120 Tools... that is SO NOT ENOUGH TOOLS for a machine in a pallet system. I know 120 sounds like a lot, but it's nothing.
#10 Hardmill
Hardmill
    Anti-Moderator
  • Members
  • PipPipPip
  • 17,272 posts
Posted 28 January 2012 - 09:37 PM
Thats a great option too.
Its a different beast but does the job very well.
PEACE :D
#11 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 28 January 2012 - 11:20 PM
I agree 120 tools is not enough tools. A lot of the time we will have 3 or4 different jobs set up in a machine at the same time tool space gets used up fast.
#12 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 28 January 2012 - 11:42 PM
If I am not mistaken, Mori is now using Mitsubishi controls on their NH machines (and others). As far as I know, they have always used them on their X series machines which are the budget series I believe. They have the old style column, single ball screws, etc. I am going from memory here (which isnt very good in my old age) so....
Maybe DavidB@DMG/Mori Seiki can clear this up?
#13 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 28 January 2012 - 11:50 PM
This is very true and would be great EXCEPT! If you were to plan on programming any of your other machinery with this seat of Esprit they will not be supported Unless they are all NH(x) that is. Im not sure if things have changed since I last talked to Esprit, but if we wanted support for the rest of our machines we had to purchase another seat of Esprit that was not tied to the Mori. We couldnt just purchase a post.
#14 DavidB@Sandvik
DavidB@Sandvik
    Advanced Member
  • Members
  • PipPipPip
  • 3,969 posts
Posted 29 January 2012 - 03:58 AM
Yes the seat of Esprit in the Mori machine is setup only for that machine purchased. But it will get you up and running with this new machine from day 1.
You can also use the Esprit posted G code to give to your post developer as a templete for your Mp post. As others have stated the MP Master Horizontal will only need minor tweaks.
What spindle taper did you select?
Good Luck Dave
#15 Neurosis
Neurosis
    Forum Indigent
  • Members
  • PipPipPip
  • 1,331 posts
Posted 29 January 2012 - 09:23 AM
Good Luck Dave
Up and running from day 1? Are you assuming that a person can learn to use a new cad/cam system in only one day? We must have some geniuses in here.  :)
Any chance that you could clear my other question/s up?   Do the X series machines, or any of the newer Mori's, come with Mitsubishi controls now?
#16 YoDoug®
YoDoug®
    Advanced Member
  • Members
  • PipPipPip
  • 2,566 posts
Posted 29 January 2012 - 11:14 AM
Good Luck Dave
Dave, I also was told that the seat of Esprit that comes in a new Mori is only a 1 or 2 year license and after that you would need to buy a seat from Esprit. Does that sound correct?
#17 Joe788
Joe788
    Advanced Member
  • Members
  • PipPipPip
  • 3,272 posts
Posted 29 January 2012 - 11:32 AM
There are a lot of Moris that come with Mitsubishi controls for the last 5 years or so, they just don't really advertise which ones.
#18 DavidB@Sandvik
DavidB@Sandvik
    Advanced Member
  • Members
  • PipPipPip
  • 3,969 posts
Posted 29 January 2012 - 04:54 PM
Quote
Incorrect, Mori will support Esprit for the machine warranty period of 2 years. Then if required the end user may purchase SMC at 12% of the current list price of standard ESPRIT for the configuration of ESPRIT they are operating. So for example, if the license would sell for $10,000, the annual software maintenance contract cost would be $1200/year.
Reagrding the posts.
Each ESPRIT for MAPPS on-machine license is configured with the full set of ESPRIT’s capability for the machine on which it is installed. No other machine may be programmed with this license. For example, if a customer buys a NMV 5000 without the turning option, the ESPRIT license would be only program 2-5 axis milling. The post would be for the NMV 5000. No other post processor would be able to run on that copy of ESPRIT. If a customer needs more posts processors or runs other brands of machines, then your local Esprit rep would step in and give the customer options regarding buying additional licenses of ESPRIT.
Yes Mori uses Mitsubishi controllers in the NHX. The NL has always been Mitsubishi.
#19 YoDoug®
YoDoug®
    Advanced Member
  • Members
  • PipPipPip
  • 2,566 posts
Posted 29 January 2012 - 07:27 PM
That sounds pretty reasonable. Thanks for the reply
#20 FNMI
FNMI
    Member
  • Members
  • PipPip
  • 255 posts
Posted 31 January 2012 - 07:00 PM
I have 7 NH4000 DCG machines they are very good, and I use the mpmaster.pst with a few modification, works very good make sure you get, Max  Memory and program numbers as well  as extended macro variables, fixture and tool offsets. Also (G10) data input,  (G68) Coordinate rotation and tool life management.
