Dynamic in Haynes 188
  • Please log in to reply
5 replies to this topic
#1 K2csq7
K2csq7
    Advanced Member
  • Members
  • PipPipPip
  • 2,279 posts
Posted 15 February 2012 - 11:29 AM
Hola Commrades,
Got a job coming up with 18 windows; .770 X 3.015 w/ .325 rads in the 4 corners.
Through an .080 wall about 6" up off the table (turned part, I will have a cap on the top while milling for added support). It will be a 3+2 setup on a very old machine. Max RPM is about 2k. Max backfeedrate = 50 IPM. (and that's pushing it)Posted Image
When your all done laughing I'd like some suggestions  Posted Image!
I am planning on using a 5 fluted 5/16" Supermill at about 100 SFM & .001 CPT (to start with).
Plunging into a predrilled hole for entry.
I've got a .046 stepover in there now, and a toolpath radius of .050 (Dynamic Area). Filter = 1:1 total tolerance = .004, leaving .006 / side for finishing.
We have a similar job with more but smaller windows that runs on that machine and was programmed a long time ago, it goes like this...
An entry hole is drilled at each end, then it just plows the endmill through the middle of the slot.
I know I will have excellent tool life, but would like to get the cycle time for the roughing down from the current backplot time of 10 mins.
TIA for any suggestionsPosted Image
#2 TEEJAY
TEEJAY
    5 Axis Choreographer
  • Moderators
  • 6,170 posts
Posted 15 February 2012 - 12:16 PM
good luck Kieth, We have some Haynes 282. I treat it like Rene. And to be honest, I havent had a lot of luck with dynamic toolpaths in this stuff. Seems plowing your way thru works better.It has less of a chance to fight back
#3 K2csq7
K2csq7
    Advanced Member
  • Members
  • PipPipPip
  • 2,279 posts
Posted 15 February 2012 - 12:47 PM
I have used Dynamic on this stuff with good results in the past, but the amount of material to be removed was far less, and I was able to use Dynamic core as they were not closed chains. I've never seen the 282... maybe it's worse?
Quote
Quote
good luck Kieth
You were suppossed to be done laughing before suggesting something!Posted Image
LOL, thanks Wes, I'll make up a plowing program to have as backup!
#4 TEEJAY
TEEJAY
  • Moderators
  • 6,170 posts
Posted 15 February 2012 - 12:54 PM
282 is new. It turns 718 Inconnel into aluminum  ;)
#5 Jeremy Herron@DBS Solutions™
    Advanced Member
  • eMC Learning Group
  • PipPipPip
  • 920 posts
Posted 16 February 2012 - 09:50 AM
Hey Keith,
We do it all the time, with your situation I would usually go with
1/4 hanita varimill 2 5 flute 125 sfm .0025 fpt (chip thinning applied) .025 stepover, I usually about 120 mins in cut in haynes 188
or
3/8 hanita varimill 2 5 flute 145 sfm .0028 fpt (chip thinning applied) .0375 stepover, I usually about 60-90 mins in cut in haynes 188
HTH.
:thumbsup:
#6 K2csq7
K2csq7
    Advanced Member
  • Members
  • PipPipPip
  • 2,279 posts
Posted 16 February 2012 - 01:54 PM
Thank you sir!
