DMU experts
  • Please log in to reply
33 replies to this topic
#1 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 22 February 2012 - 01:50 PM
We have a DMU-50
This does not happen all the time, but today even after a restart it happened three times in a row.
Program sends machine to C270. and B95. Machine goes to C270. and B94.98971 and goes into e-stop.
Any ideas???
service people have no clue....
#2 Mr. Wizzard
Mr. Wizzard
    Advanced Member
  • Members
  • PipPipPip
  • 1,006 posts
Posted 22 February 2012 - 02:11 PM
not a DMU guy, does the load meter spike while trying to rotate?
#3 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 22 February 2012 - 02:19 PM
Nope, makes the rotation and the next Z move and then the alarm. (but B never got there 100%)
#4 Mic
Mic
    Member
  • Members
  • PipPip
  • 267 posts
Posted 22 February 2012 - 02:22 PM
Heidenhain control?
Sounds like a problem with the position monitoring. I think there is a timer parameter or something similar that can be increased slightly to overcome the problem.
#5 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 22 February 2012 - 02:24 PM
View PostMic, on 22 February 2012 - 02:22 PM, said:
Heidenhain control?
Yea....thanks, I'll get someone on it
Posted Image
#6 Aeroguy
Aeroguy
    Member
  • Members
  • PipPip
  • 181 posts
Sounds like you might be hitting a limit switch. Is your machine able to do negative axis?
#7 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 22 February 2012 - 02:26 PM
No limit switch....it works most of the time, just recently it's been acting up. Been running the same parts for weeks.
#8 Mr. Wizzard
Mr. Wizzard
    Advanced Member
  • Members
  • PipPipPip
  • 1,006 posts
I have nothing, sorry. Not being a DMU guy, just thinking something was getting hung up (chips, maybe crack in something) that would force a load and make the A stall out.
#9 dougm
dougm
    Member
  • Members
  • PipPip
  • 139 posts
Posted 23 February 2012 - 08:34 AM
we had a similar problem with ours
the locks were not holding the B axis.
Doug
#10 Aeroguy
Aeroguy
    Member
  • Members
  • PipPip
  • 181 posts
Posted 23 February 2012 - 08:57 AM
Hmmm.. Well this could just be a shot in the dark, but maybe one of your driver boards is acting up. That used to happen to me at least every 6 months or so. I would probably suggest swapping the board with another axis and see if the alarm changes to that axis.
#11 K2csq7
K2csq7
    Advanced Member
  • Members
  • PipPipPip
  • 1,985 posts
Posted 23 February 2012 - 09:47 AM
We had a similar issue on our Daewoo's, it was the timing of the lock for the rotary.
#12 chall
chall
    Member
  • Members
  • PipPip
  • 52 posts
Posted 23 February 2012 - 12:44 PM
Is it a dmu 50 evolution or the 3+2 version. We have 2 small dmu's and have had the bolts shear on the b axis clamps at least 4 times, one is currently down for this reason, and the machine is just over a year old. One thing to try that might keep you going is slow your feed down for the spatial/cycle 19 move. Do you get any errors at all? Or just the e stop?
#13 dougm
dougm
    Member
  • Members
  • PipPip
  • 139 posts
Posted 23 February 2012 - 01:22 PM
Our 3+2 was just as chall said sheared the bolts twice
#14 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 23 February 2012 - 05:11 PM
ours is a 3+2 also....
The machine goes to an e-stop
The wierd thing is the only time in the program it shuts down (and not all the time) is on the center drill. The drill later on never, as of yet had the problem.
#15 Mr. Wizzard
Mr. Wizzard
    Advanced Member
  • Members
  • PipPipPip
  • 1,006 posts
Posted 24 February 2012 - 07:56 AM
If you have the time, can you program some incremental rotations back and forth and run in a loop to see if the problem happens in the same spot consistently? Just on the center drill is weird....
#16 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 24 February 2012 - 09:17 AM
WEIRD.......YES...very
Made a looping program and it ran fine. whent back to the production program.....same $hit...
Checked the program all is good.
Copied the drill and changed the cycle 83 to 81 and changed the drill depth for the center drill....e-stop AGAIN...
BTW.....this machine is past weird.
#17 Mr. Wizzard
Mr. Wizzard
    Advanced Member
  • Members
  • PipPipPip
  • 1,006 posts
Posted 24 February 2012 - 09:35 AM
WOW, the things that happen to us.....
Are there any macros or settings being loaded, run by the program or canned drilling cycle within the control (in the background) that could be throwing a curve ball? Anyone (operator) mess with the machine parameters or settings?
#18 chall
chall
    Member
  • Members
  • PipPip
  • 52 posts
Posted 26 February 2012 - 03:03 PM
can u post that bit of the program up?
#19 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 28 February 2012 - 06:44 AM
Goes down on line 860 (again, not all the time)
;(CENTER DRILL SECTION C-C - CLEVIS SIDE)
N830 S4278 M3
N840 G599 D1
N850 SUPA X-21.5 Y-.1
N860 CYCLE800(1,"DMG",0,27,0.,0.,0.,90.,0,95.,,,,1)
N870 G90 G0 X-1.25 Y1.0479
N880 Z5.
N890 F6.16
N900 MCALL CYCLE81(5.,-1.2237,.1,-1.47,)
N910 X-1.25 Y1.0479
N920 MCALL
N930 G0 SUPA D0 Z-.1
#20 Mr. Wizzard
Mr. Wizzard
    Advanced Member
  • Members
  • PipPipPip
  • 1,006 posts
Posted 28 February 2012 - 07:08 AM
Did you jiggle the wires? Seriously, could be something dumb, like a bad plug, wire, connection at the drive. Just guessing.
