DMU experts
  • Please log in to reply
33 replies to this topic
#21 chall
chall
    Member
  • Members
  • PipPip
  • 52 posts
Posted 28 February 2012 - 11:40 AM
Quote
Did you jiggle the wires? Seriously, could be something dumb, like a bad plug, wire, connection at the drive. Just guessing.
this is also true, we have to give one of our other DMU's a "love tap" to get the screen to work when we switch it on.
#22 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 29 February 2012 - 08:51 AM
WOW....gets even weirder.
Had to break down the job to run another hurry up job. No problems, lots of rotary moves.
After the reset-up of first job, back to the e-stop BS in the same spot. It took about a half a day completeing about 20 parts before the first e-stop alarm.
#23 Mr. Wizzard
Mr. Wizzard
    Advanced Member
  • Members
  • PipPipPip
  • 1,006 posts
Posted 29 February 2012 - 09:35 AM
Well, that explains it. The machine doesn't want to run those parts. Problem solved. Don't run those parts on it.
Next time, hold up the print and ask first.
If you get a  :no , move on.
#24 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 29 February 2012 - 03:19 PM
^^ Posted Image ^^
Posted ImagePosted ImagePosted Image
#25 Odin
Odin
    Member
  • Members
  • PipPip
  • 199 posts
Posted 01 March 2012 - 11:13 AM
Had something similar happen on our makino 1210 b-axis. ended up being the scale for the b-axis. replaced it and all is well.
#26 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 14 March 2012 - 08:14 AM
OK peeps....gets even strainger..... :question:
Machine used to only go into e-stop BEFORE the centerdrill ran at the index stated.
Now it does it, and NOT all the time, after the center drill is finished. It NEVER does it at the same index with the drill......
Here are the machine alarm numbers...
25201 - Axis B1 drive fault.
300608 - Axis B1 drive 5 speed controller at limit.
510305 - Emergency stop: Drive B axis is not ready.
3000 - Emergency stop.
510311 - Emergency stop: E/R module not ready.
#27 Aeroguy
Aeroguy
    Member
  • Members
  • PipPip
  • 182 posts
Posted 14 March 2012 - 08:19 AM
Yeah, that sounds like your drive board is fried. I used to get those all the time and thats usually what it was.
Call up your friendly service guy and then hurry up and wait 1 week for the new board to come from Germany.
#28 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 14 March 2012 - 09:34 AM
only the one tool......other tools that go to thame position have no problems
#29 Joe788
Joe788
    Advanced Member
  • Members
  • PipPipPip
  • 3,282 posts
Posted 14 March 2012 - 09:53 AM
Columbo, is that particular tool shorter than all the rest?
#30 Mr. Wizzard
Mr. Wizzard
    Advanced Member
  • Members
  • PipPipPip
  • 1,006 posts
Posted 14 March 2012 - 06:28 PM
can you watch the load meters when the tool is in that position?
Anything suspicious there?
#31 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 15 March 2012 - 08:39 AM
Both center drill and drill have the exact same gage length...
looks normal right to the e-stop.
#32 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 15 March 2012 - 12:29 PM
One of my maintenance guys is asking to put a dwell into the program. Anyone know the dwell command for a DMU50? I tried the standard g4 p1 and get an alarm.
#33 Steve_B
Steve_B
    Member
  • Members
  • PipPip
  • 83 posts
Posted 15 March 2012 - 02:37 PM
We have a 2004 DME Evo70 with Heidenhain MillPlus IT V520 contoller and for dwell I use G4 X##.##. ##.## is the time I want to dwell. If I want dwell by revolutions I use G4 D#. # is the amount of turns of the spindle for the dwell.
Not sure if it will work on your version.
#34 Columbo™
Columbo™
    Thee Circle™
  • Members
  • PipPipPip
  • 8,546 posts
Posted 15 March 2012 - 03:35 PM
Not sure, I'll give it a try
We have a Siemens 840D Powerline control
