Haas TL Lathe Tapping Canned Cycle
25 replies to this topic
#1 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 05 March 2012 - 02:25 PM
So I just found on Mastercam X6 a lathe Definition called Generic Haas TL 2x lathe. I'm trying to get this post to work but where the section for a simple g84 tapping canned cycle I get a G32 canned cycle. How do I change this G32 canned cycle over to a G84.
Quote
O0000
(PROGRAM NAME - TDATE=DD-MM-YY - 05-03-12 TIME=HH:MM - 11:24)
N100 G20
(TOOL - 111 OFFSET - 111)
(LATHE TOOL 78)
N110 T11211
N120 G97 S200 M03
N130 G0 G54 X10. Z.2
N140 X0.
N150 Z.1
N160 G32 Z-.3681 E.03125 M05
N170 G32 Z.1 M04
N180 M05
N190 M03
N200 G0 Z.2
N210 X10.
N220 G28 U0. W0. M05
N230 T11100
N240 M30
#2 Steve Barner @ SEL
Steve Barner @ SEL
    Advanced Member
  • Members
  • PipPipPip
  • 339 posts
Posted 05 March 2012 - 02:52 PM
It looks like the canned cycle is setup to call a G32 no matter what.  In the post in the "ltap" section:
 pbld, n$, *sthdg32, pfzout, pffr, pnullstop, e$
I don't know what your post editing skills are like.  T'were it me, I'd probably start by changing the *sthdg32 to a *sg83_f
I realize that the tapping code is G84, but the format table that defines the G codes for the canned cycles is messed up I think.  Or you could eliminate the *sthdg32 and put in a "G84" including the quotes.  I'm not sure off the top of my head if the Haas will need a retract amount in the canned block, so it may alarm out when doing the cycle.  I probably wouldn't run a part after modifying something like this until I was sure that the code works.  As always, make a backup of the post before you start monkeying around with it.
#3 Steve Barner @ SEL
Steve Barner @ SEL
    Advanced Member
  • Members
  • PipPipPip
  • 339 posts
Posted 05 March 2012 - 02:54 PM
Actually, now that I read your post more thoroughly, you'll probably have to make a few more edits after that one to stop the M05 and M04 codes from being output.  FWIW, I use the MPLmaster post, and it works great.
#4 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 05 March 2012 - 04:47 PM
Steve are you running a Haas Tool Room lathe. I Tried to use a Generic Haas SL 4X Mt_Lathe and I'm getting a code with a M29 S200 instead of an M03 S200. I Tried to change the line in the post where It says M29 and then suddenly I get nothing for the spindle direction.
Quote
O40000 (HAAS TL FIRST PART)
(DATE=DD-MM-YY - 05-03-12 TIME=HH:MM - 13:37)
(MCX FILE - C:\USERS\ASMURPHY\DESKTOP\HAAS TL FIRST PART.MCX-6)
(NC FILE - C:\USERS\ASMURPHY\DOCUMENTS\MY MCAMX6\LATHE\NC\HAAS TL FIRST PART.NC)
(MATERIAL - STEEL INCH - 1030 - 200 BHN)
(POST DEV - IN-HOUSE SOLUTIONS INC.)
(TOOL - 19  - LATHE TOOL 78        - OFFSET - 19  - INSERT - 10-32 TAP RH - HOLDER - NONE)
G18 G20 G40 G54 G80 G99
(TOOL - 19 OFFSET - 19)
(LATHE TOOL 78)
N1 T1919
G28 U0.
G28 W0.
G54 G0 Z10.
X10.
G98
G97
G0 X10. Z.2
X0.
M29 S200
G99 G84 Z-.3125 R.2 F.01
G80
X10. Z.2
G28 U0.
G28 W0.
M05
M30
#5 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 05 March 2012 - 04:56 PM
Also on the Mill when you select the canned cycle for tapping the Speeds and feeds values become relative to each other. The lathe doesn't seem to be working in the same fashion. Is there a way to fix this?
#6 Steve Barner @ SEL
Steve Barner @ SEL
    Advanced Member
  • Members
  • PipPipPip
  • 339 posts
Posted 05 March 2012 - 05:10 PM
I'm running an SL-20, but the code should be the same.  This is what my tapping section looks like:
ltap$			#Canned tap cycle, lathe
  	pdrlcommonb
  	if use_pitch = 0, #Feed/Min mode, feed divided by spindle speed is equal to thread lead
   	if rigid_tap, pbld, n$, sg9697, sm03, speed, e$   		#Rigid Tapping	Can use G84/G88 with M29 or just G84.2
		pcan1, pbld, n$, *sgdrlref, pgdrlout, pxout, pyout, pzout, prdrlout, *feed, strcantext, e$
  	else, #Feed/Rev mode, feed is equal to thread lead
		if met_tool$, pitch = n_tap_thds$  # Tap pitch (mm  per thread)
		else, pitch = 1/n_tap_thds$   	# Tap pitch (inches per thread)
			, pbld, n$, *sgdrlref, pgdrlout, pxout, pyout, pzout, prdrlout, *pitch, strcantext, e$
 	pcom_movea
 	pcanceldcl
The use_pitch thing is a switch in the post to output feed/rev or inches per minute.  It doesn't look like the TL post has that switch, so that may be something that we would have to add.  That TL tapping section is dog doo.  And you can probably disregard the "if rigid_tap" thing as well (you are rigid tapping right?  Not using a floating holder?)  If so, your code may look like this:
  	pdrlcommonb
 	pcom_movea
 	pcanceldcl
See where that gets you.
#7 Steve Barner @ SEL
Steve Barner @ SEL
    Advanced Member
  • Members
  • PipPipPip
  • 339 posts
Posted 05 March 2012 - 05:11 PM
No.
#8 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 05 March 2012 - 06:39 PM
Well I took my Tl post and deleted the whole section talking about rigid tapping and replaced it with a section that talks about rigid tapping from the Mplmater and started to get a code that looks a little more up to par.
Quote
O0000
(PROGRAM NAME - HAAS TL FIRST PARTDATE=DD-MM-YY - 05-03-12 TIME=HH:MM - 15:35)
N100 G20
(LATHE TOOL 78)
N110 T1919
N120 G97 S100 M03
N140 X0.
N150 M03 S100
N160 G84 R.3 F.03125
N170 X10.
N180 G28 U0. W0. M05
N190 T1900
N200 M30
#9 Steve Barner @ SEL
Steve Barner @ SEL
    Advanced Member
  • Members
  • PipPipPip
  • 339 posts
Posted 05 March 2012 - 06:43 PM
Closer.  Looks like you're missing the depth.  Can you paste the code you posted into the ltap section?
#10 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 06 March 2012 - 10:09 AM
Quote
      pdrlcommonb
        pbld, n$, *sm03, *speed, e$           #Rigid Tapping    Can use G84/G88 with M29 or just G84.2
          prdrlout, dwell$, pffr, strcantext, e$
        if rigid_tap, pbld, n$, *sm03, *speed, e$           #Rigid Tapping    Can use G84/G88 with M29 or just G84.2
          prdrlout, dwell$, *pitch, !feed, strcantext, e$
      pcom_movea
      pcanceldcl
#11 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 06 March 2012 - 10:54 AM
Ok well I think I got the MPLmaster to work. It kept changing the feed rate to ipm instead of ipr. Even though I had a feedrate input that needed ipr it was changing it back to ipm. So I found the line of code that changes that and changed it back. I also added more decimal places to my output feedrate.
Quote
O0000
(PROGRAM NAME - HAAS TL FIRST PART)
(DATE=DD-MM-YY - 06-03-12 TIME=HH:MM - 07:51)
G20
(LATHE TOOL 78)
G54
N19 T1919
G18 G99
G97
G0 X-10. Z.2
X0.
M03 S100
G84 Z-.3125 R.1 F.03125
G80
X-10. Z.2
G28 U0. W0.
M05
M30
#12 Steve Barner @ SEL
Steve Barner @ SEL
    Advanced Member
  • Members
  • PipPipPip
  • 339 posts
Posted 06 March 2012 - 11:06 AM
Good.  THAT looks like some good code.  That TL post is a turd.  Nice work.
#13 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 06 March 2012 - 11:08 AM
Man even that post is messed up it isn't outputting a peck value I'm going to see if I can fix that also.  :no :wallbash:
#14 Steve Barner @ SEL
Steve Barner @ SEL
    Advanced Member
  • Members
  • PipPipPip
  • 339 posts
Posted 06 March 2012 - 11:34 AM
Peck tapping on the Haas isn't as simple as simply adding a peck value.  You need a line of code for each depth you wanna go.  I've eedited my mill post to do it, but haven't done the lathe one yet.  There is a considerable amount of post editing that needs to be done.
If you get stuck, you can PM me here or email me at sbarner (at) wsu (dot) edu
I check that more often.
#15 Russh67
Russh67
    Member
  • Members
  • PipPip
  • 76 posts
Posted 05 April 2012 - 11:19 AM
Hey Guys.
Hope you don't mind my budding in.....
Granted, I have fanuc Oi not haas lathe.
I tried pasting mplmaster tap section into my post and fooled around a little..
I cant get my tapping right...it's close
I use a copy of mplfan that's been edited a lot already for my caxis. I cannot get my feed to be the thread pitch. I also need to get rid of my m73 (caxis spindle on)
Gcode:
(TOOL - 12 OFFSET - 12)
( NO. 4-40 TAPRH)
(C-AXIS FACE DRILL)
G28U0.W0.
G0T1200
G0T1212
M23
M49
M19
G28H0.
G0X0.Z.1
C0.
G97S1320M73                                   *******no G97, no M73 ************
G98G184Z-.682R0.F33.                 *******no g98, Feed to Pitch (.025 for 4-40)*********
G80
T1200
G28U0.W0.H0.M75                         **********M75 is spindle off redundant doesn't matter*********
M18
M30
My tap post block looks like this:
   gcode$ = zero
   prv_dwell$ = zero
   @dwell$
   comment$
   pcan
   pe_inc_calc
   xabs = vequ(refht_x)
   ps_inc_calc
   pcan1, pbld, n$, sgcode, pzout, strcantext, e$
   pe_inc_calc
   xabs = vequ(depth_x)
   ps_inc_calc
   opcode$ = 104 #thread address from feedrate
   if dwell$, pdwell1
   pe_inc_calc
   ps_inc_calc
   pswtchspin
   pbld, n$, *sthdg32, pfzout, *spindle_l, e$
   if dwell$, pdwell1
   prv_gcode$ = -1
   pbld, n$, pnullstop, e$
   pswtchspin
   if refht$ <> initht$,
     gcode$ = zero
     pe_inc_calc
     xabs = vequ(initht_x)
     ps_inc_calc
     pbld, n$, sgcode, pfzout, *spindle_l, e$
   pbld, n$, spindle_l, e$
   opcode$ = 81 #Restore opcode
   pcom_movea
Any Suggestions would be greatly appreciated.....Thank you in advance..
#16 roland_1
roland_1
    Member
  • Members
  • PipPip
  • 52 posts
Posted 07 April 2012 - 08:29 AM
send me your post and MD, part file, orig code and changed example and I will take a look and try to set it work
#17 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 07 April 2012 - 08:35 AM
Also I think they try to throw in the g98 as a canned cycle return plane. But that is how you write for the mill. I was noticing the same things with my post but the Haas Lathes don't recognize that feature because of the whole IPM IPR thing.
#18 Russh67
Russh67
    Member
  • Members
  • PipPip
  • 76 posts
Posted 09 April 2012 - 07:59 AM
Thank you for replying to me....
Quote
On our fanuc G98 is per minute feed, usually put in at all caxis milling lines where the feed rate is commanded.I don't need it in tapping lines....I wish we had a HAAS I like the control on the HAAS much better than fanuc......
I ran the post debug and see that the taping stuff is coming from:
mtap$       #Canned tap cycle, mill
   pdrlcommonb
   pcan1, pbld, n$, sgfeed, *sgdrlref, pgdrlout, pxout, pyout, pzout,
     pcout, prdrlout, pffr, strcantext, e$
   pcom_movea
I am using c-axis to tap on the face even if it's at the center. We don't have tap chucks to fit in the carousel we do have the er-20 tap collets for our live tools.
I don't see any where a 1/# of threads thing in the post to add the pitch in the feed rate for tapping, any tapping.
#19 Rocketmachinist
Rocketmachinist
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
Posted 09 April 2012 - 10:58 AM
I'm taking a shot in the dark here. Remove the *sgdrlref, out of that line it should kick out the g98
#20 Russh67
Russh67
    Member
  • Members
  • PipPip
  • 76 posts
Posted 09 April 2012 - 11:29 AM
I took out sgfeed and it removed the g98.
Earlier in post there is this:
#Canned drill cycle reference height
sg198   : "" #G198   #Reference at initht
sg199   : "" #G199   #Reference at refht
sgdrlref : ""     #Target string
fstrsel sg198 drillref sgdrlref 2 -1
Looks like reference height or Return to Initial height.
I am trying to learn so bear with me..
Reply to this topic
