Dumb threading question
#1
Posted 21 March 2012 - 12:50 PM
1.5-12 UNJF ID thread .....
I can use a 12UN insert to thread it .... right ...
the root radius callout only applies to OD threads ... right ????
#2
Posted 21 March 2012 - 01:16 PM
you are correct the only diff. on a unj id thread is the minor dia. is bigger to
fit the root on the od thread. if you are using a full profile id insert you
will have to bore the id to the correct dia.
there is no diff. on the id thrd gages other then the lable that says un or unj
HTH Ken,
#3
Posted 21 March 2012 - 01:23 PM
#4
Posted 21 March 2012 - 01:25 PM
I'm hate to blow these 2 parts out on something as dumb as using the wrong threading insert..
I asked the same question of inspection and they just confirmed the deatails posted above
#6
Posted 21 March 2012 - 03:46 PM
Mike
#7
Posted 21 March 2012 - 04:01 PM
Quote
#8
Posted 21 March 2012 - 04:18 PM
robk, on 21 March 2012 - 03:34 PM, said:
Thank you...
#10
Posted 21 March 2012 - 11:59 PM
#11
Posted 22 March 2012 - 08:18 AM
#12
Posted 22 March 2012 - 09:19 PM
#13
Posted 23 March 2012 - 12:14 AM
Quote
When you make stuff that helps propel 200+ people 500mph 30,000 feet into the air it is either to print or a fancy paper weight.
#15
Posted 02 May 2012 - 04:11 PM
#17
Posted 03 May 2012 - 12:35 PM
Mike
#18
Posted 03 May 2012 - 12:43 PM
#19
Posted 03 May 2012 - 12:47 PM
Mike
#20
Posted 03 May 2012 - 01:51 PM
