Rick,
Regardless of the Machine Definition 'Max feed' settings, you can set your Operation Defaults to any value you like. For X6, we separated the 'Surface High Speed' operations into individual operation types. The reason we did this is so you can set your default parameters for anything you like.
The solution to your issue is to set your defaults the way you want them. Then Mastercam will always pick up these values and not put in any values you don't want to see.
FYI,
When I checked the defaults in X6 MU2, it looks like those values have been changed to '100.0' for the High Feed value.
PM me and we can do a quick G2M if you aren't sure how to fix the default settings...
Next and all future Releases
Started by
Rickster™
, Apr 16 2012 01:37 PM
24 replies to this topic
#21
Posted 17 April 2012 - 02:57 PM
#22
Posted 17 April 2012 - 03:01 PM
I tried PM'ing you, but your mailbox is full...
#23
Posted 17 April 2012 - 03:18 PM
I have changed every single high speed op to or 500. (as stated in 1st few post)
I have every setting that i am supposed to or can set that would affect it at 500....
I still get the 10000. every time i make a new path and use min distance.
I would have made this thread if it were not for battling with this for a long time
I will be back to work thursday
I will empty my inbox
#24
Posted 17 April 2012 - 03:26 PM
I'm sure we can get you sorted out Rick. Shoot me a PM or Email when you are back at work and we can take a look at the issue.
#25
Posted 17 April 2012 - 03:36 PM
Will do Colin.
