Turning an .011 thick flange.
  • Please log in to reply
36 replies to this topic
#1 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 26 April 2012 - 10:03 AM
I need to turn a flange on a part that is .011 thick any ideas? The part is 3.00" dia. with a counter bore feature (2.2") with a hole in the center (1.6"dia.) the bottom face of the counter bore is the .011" thick flange. Material is hardened 4130 steel 38-42 Rc.
#2 K2csq7
K2csq7
    Advanced Member
  • Members
  • PipPipPip
  • 1,987 posts
Posted 26 April 2012 - 10:24 AM
100, 100, GO!
Maybe get one face done & fill it with something (cerrolow), then turn the other side???
#3 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 26 April 2012 - 10:35 AM
Also I need to make 30 parts.
#4 Del.
Del.
    Advanced Member
  • Members
  • PipPipPip
  • 2,772 posts
Posted 26 April 2012 - 10:52 AM
I would leave it thicker on that side and stick it to a magnetic holder and wire edm off the rest of thickness. I don't see how you could turn or grind an area that thin.
#5 Goldorak
Goldorak
    I Live. I Ride. I am Jeep.
  • Members
  • PipPipPip
  • 1,609 posts
Posted 26 April 2012 - 10:55 AM
program it like a thin wall in milling
finish it .025 step by .025 step on each side with a grooving tool to prevent warp
we make 2inch od by 1in id by .02 thk washer from inconel like this ant it works like a charm
#6 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 26 April 2012 - 11:10 AM
Quote
We don't have an EDM. They want to do it all on the lathe. :thumbdown:
#7 Del.
Del.
    Advanced Member
  • Members
  • PipPipPip
  • 2,772 posts
Posted 26 April 2012 - 11:17 AM
Could you make like a solid plug to go into it when you face the back side off. I wonder what the purpose of such a thin section is for and how long it would hold up. Thump it with your finger and it would bend it i would think.
#8 K2csq7
K2csq7
    Advanced Member
  • Members
  • PipPipPip
  • 1,987 posts
Posted 26 April 2012 - 11:39 AM
Inco is much stronger.
.011 in alloy steel is like .003 in Inco, IMO of course...
#9 Mr. M
Mr. M
    Application Engineer
  • Members
  • PipPipPip
  • 1,110 posts
Posted 26 April 2012 - 11:55 AM
I've done it where you have the back side up against a shoulder or boss to do the second side down to .007 in CRS. Can you put up a picture?
#10 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 26 April 2012 - 12:11 PM
I can't post pictures of the part, I will have to draw something up that I can show.
#11 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 26 April 2012 - 12:47 PM
Here is the turn profile of the part.
Posted Image
#12 K2csq7
K2csq7
    Advanced Member
  • Members
  • PipPipPip
  • 1,987 posts
Posted 26 April 2012 - 12:53 PM
Looks like your going to have to make a nice fixture to support one (finished) side of the flange, while you turn the other.
We use stuff called "Zap A Gap", (like super glue) you could use that to glue the finished side to the fixture to prevent it from lifting up on you while you finish the 2nd side.
You can get some Zap a Gap remover spray to get rid of it when machining is done.
:edit:
I don't think they make the remover I spoke of.
#13 GoetzInd
GoetzInd
    Master Machine Masher
  • Members
  • PipPipPip
  • 1,013 posts
Posted 26 April 2012 - 01:04 PM
I would do the ID side first then hold it on the id with pie jaws that went all the way to the bottom of the c'bore. Then use a insert with large corner rad. to face the other side to keep cutting pressure on the support. Done some thin parts that way but not that thin.
Mike
#14 Guest_CNC Apps Guy 1_*
  • Guests
Posted 26 April 2012 - 05:58 PM
Pinch Turn it.. (ID/OD))
#15 Mr. M
Mr. M
  • Members
  • PipPipPip
  • 1,110 posts
Posted 26 April 2012 - 06:48 PM
Yup, this is what I've done, and for the final pass taking a .030+ pass from center out might be the ticket
#16 JAMMAN
JAMMAN
    Full Of ****
  • Members
  • PipPipPip
  • 1,463 posts
Posted 26 April 2012 - 07:03 PM
Mike
Exactly what I was thinking, pie jaws are awesome. I really don't think you need a large radius tool though, you would have to make a deliberate effort to not push it against the jaws.
#17 chris m
chris m
    Advanced Member
  • Members
  • PipPipPip
  • 5,800 posts
Posted 27 April 2012 - 08:07 AM
Quote
We do it all day long
I would suggest a collet (like a Dunham arbor, or an expanding 5C soft collet) in the ID to finish
#18 Larry1958
Larry1958
    Member
  • Members
  • PipPip
  • 93 posts
Posted 30 April 2012 - 07:33 AM
Had a part simular to that. Used an expansion arbor (homemade out of brass). Make it the 2.2" o.d. and long enough to bottom out on c'bore face.
#19 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 02 May 2012 - 04:07 PM
I cut the first side and the 2.2 bore is out of round by .001 (I have .0005 tolerance), I cut a setup part out of some hot rolled and the center was round within .0001. I'm wondering how much the part is going to move when I cut the other side. I'm thinking I will need to rough the part out complete then come back and finish.
#20 chris m
chris m
    Advanced Member
  • Members
  • PipPipPip
  • 5,800 posts
Posted 03 May 2012 - 06:28 AM
Depends on what shape the bore is; if it is a figure eight, then roughing first will help, if it is a triangle, then roughing isn't going to do much for you. That being said, roughing first is often a smart play; you may also consider stress relieving the blanks of you have in-house heat treating capability.
