How many time have you crashed today?
#101
Posted 07 July 2012 - 08:53 AM
froze solid while dragging it, hard reboot was the only cure.
#102
Posted 07 July 2012 - 09:13 AM
#103
Posted 07 July 2012 - 10:04 AM
I don't think I will have the exact same scenario thou.
I create curves through two sets of multiple compound angle surfaces.
I was using the 'u' shaped, multiple splines as the trimming chain and keeping both sides,
that worked, i hit the plus sign to do it again, selected the surfaces,check, chain window
came up and then the freeze as stated above.
I did have Mc open for awhile created a funky runner, part line and drafted slide seal off.
After I rebooted I was able to do it with out a hitch. I think my cache was peaking, seems typicle
because earlier Project to surface wouldn't work, (happens alot) and a simple close and restart
fixed it as usual.
I was trimming the orange seal off to the runner
I had saved just prior so I did not lose more than a few minutes.
#104
Posted 07 July 2012 - 01:17 PM
But i don't blame the software. I'm sure I need more gigglebites and ram or something.
#105
Posted 09 July 2012 - 05:59 AM
Crunch a 5 axis toolpath and while its working, hit the little red x in the top of the status box not the bottom one.
#106 Guest_CNC Apps Guy 1_*
Posted 09 July 2012 - 12:40 PM
#107 Guest_CNC Apps Guy 1_*
Posted 09 July 2012 - 01:10 PM
#108
Posted 09 July 2012 - 01:19 PM
cruch mastercam X6 MU1?, no problema:
toolpath, multiaxis-> curve 5 axis
select tool
select holder
cut patern->3D curves->select->chain
tool axis control->chain->select->chain
colision control->on selected curve
linking-> whatever
roughing-BOOM!!!-YOU ARE OUT
selekting parameters in order from top to bottom
as logical way is not what you expect
btw, mastercam X4 and X5 is O.K.
#109
Posted 09 July 2012 - 01:27 PM
select tool
select holder
linking-> whatever
if you can create a step by step proceedure that will crash X6MU1, you should send a file
and step by step instructions to qc@mastercam.com
#110
Posted 09 July 2012 - 01:31 PM
company restrictions
#111
Posted 09 July 2012 - 02:28 PM
Rickster™, on 09 July 2012 - 02:14 PM, said:
from the edge of a surface. Rarely they are
arcs. Someday they will make geo creation
off surface edges better, I have faith, for
Now SC. Is flawless.
Continuous spline ( 1entity ) should not
be an issue with surface creation.
Ah well it is what it is.
Second crash today. Once just did a core dump with segmented fault.
The other just crashed icon still sitting there, gonna force me to reboot.
Dam I hate Solaris...
Wait a minute......
Duh......and I was only modeling...
I was drawing a spline though.
Hell my DROID crcrashed 4 times already today. I already did a factory reset. I am not being sarcastic. Swear... true it is! I would probably be crashing Mastercam if I was using it today....
#112 Guest_CNC Apps Guy 1_*
Posted 11 July 2012 - 04:45 PM
Profiling a spherical radius part. I did not have the line tangent to the sphere. I originally drew a new line from the chamfer to the sphere trimmed it up, deleted the old line, then regenned it. Somethign didn't seem quite right but I tried verifying it anyway. No bueno. So I opened it back up, edited the line in question, changed the endpoint of the line to be tangent, trimmed it up. Worked like I expected.
Guess I messed up somewhere along the line.
[hijack]
I'm trying to imagine what it would be like to be so OCD about hating on something every waking moment of every day and that I have absolutely no control over what I'm hating on.
[/hijack]
#113
Posted 12 July 2012 - 04:46 AM
#114
Posted 02 January 2013 - 01:13 PM
#115
Posted 02 January 2013 - 04:27 PM
#116
Posted 03 January 2013 - 01:28 PM
Running Windows 8
X6 MU2
