Fine Pitch Rougher EM for steel recomendations
  • Please log in to reply
27 replies to this topic
#21 mkd
mkd
    Advanced Member
  • Members
  • PipPipPip
  • 579 posts
Posted 14 June 2012 - 11:38 AM
from your FSwizard reference in other thread:
2.0" endmill, 1.8 width of cut, 2in deep@4.6 ipm
ya i know, it's ONLY 16 cuin/ minute
nice try though :harhar:
Units:
Link: 11985
Surface Speed: f/min 143
RPM:
APT: in/tooth
Feed: in/min
MRR: 16.1 in^3/min
HP: 9.2
Torque: 2112.5 in-lb
Breaking Torque: 5502.9 in-lb
Cutting Force: 2112.5 lb
Tool Deflection: 0.0102 in
Max Tool Deflection: 0.0050 in
Effective Dia: 2.0000 in
Chip Thickness: 0.00204 in
#22 jeff
jeff
    Advanced Member
  • Members
  • PipPipPip
  • 6,402 posts
Posted 14 June 2012 - 12:06 PM
lol so you're comparing a 2" cutter to a 1/2" cutter?
go away troll.
#23 mkd
mkd
    Advanced Member
  • Members
  • PipPipPip
  • 579 posts
Posted 14 June 2012 - 12:13 PM
go away troll.
that wasn't very nice. i was never disrespectful.
thought we were have a gentleman's debate.
you came up with the .500 cutter, not me.
#24 mkd
mkd
    Advanced Member
  • Members
  • PipPipPip
  • 579 posts
Posted 14 June 2012 - 12:37 PM
i was talking about "big" cutters from the start.
i guess some people are sore losers :thumbdown:
for a more applicable application:
1.25 corncobb (uncoated/ slow RPM to be charitable to HSM fanboys)
169sfm 8.3 feed, 1.0 step over, 2 in deep= 16.6 cuin/min
or 723 rpm (240sfm) @12ipm for 23 cu in/ min.
or .450" step over at 18ipm= 16mrr
so 11MRR the HSM way is not automatically faster than old school (16 to 23 MRR). cant make that blanket statement.
#25 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 14 June 2012 - 01:01 PM
With the speed and feed info both of you posted I put together a Mastercam test.
Material: 10" x 10" x 2" depth
2.00" hog end mill
sfpm: 143
ipm: 4.6
step over: 1.8"
depth: 2.00"
time:32 minutes
.5" end mill
sfpm: 780 (5962 rpm)
ipm: 180
step over: .06
depth of cut: 1.00" (had to make two depth cuts to reach 2.00" depth)
time: 19 minutes
#26 jeff
jeff
    Advanced Member
  • Members
  • PipPipPip
  • 6,402 posts
Posted 14 June 2012 - 01:41 PM
Not only is it that much faster, but I can remove that much material while only holding onto about .100" in my vise.
You will have to have extra material to hold onto if you're using a corn cob because of all the tool pressure.
#27 mkd
mkd
    Advanced Member
  • Members
  • PipPipPip
  • 579 posts
Posted 14 June 2012 - 02:56 PM
2.00" hog end mill
sfpm: 143
ipm: 4.6
step over: 1.8"
depth: 2.00"
time:32 minutes
.5" end mill
ipm: 180
step over: .06
time: 19 minutes
uh, how you figure?
7 passes can cover a 10 x 10. with 2.0 cutter
@4.5 ipm it equals 19min
@9 ipm it quals 10 min (not that i would try this). better try 16 passes at 18ipm which is still half the time of your HSM "greatness"
guys "the emperor has no clothes"
give it up
#28 BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,293 posts
Posted 14 June 2012 - 06:03 PM
It all depends on the machine I'm working on. If I'm using a big 50 taper machine that can handle a lot of tool pressure than I will use a bigger insertable cutter to remove material, but on a lighter 40 taper I will always go with the light radial engagement. Making a blanket statement either way is silly in my opinion. One big advantage with using light radial cuts is your tool cost; by using a smaller tool you only need to spend a fraction of the money.
