Can anyone tell me how I can change my dwell that posts out like this P.5 to P500?
I am working in the post right now and I cannot find and fs2 statements that match what I need?
My machine will either accept x.5 or p500 - I would like to know what everyone is using and how I change my post.
X6 Post - change decimal to trailing zeros
Started by
MIKO ELLO
, Jun 25 2012 08:27 PM
6 replies to this topic
#2
Posted 25 June 2012 - 09:13 PM
this is what my post is showing at the moment
fstrsel scomp comp_type scomp_type 5 -1
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place (feedrate)
fs2 16 1 0 1 0n #Integer, forced output
fs2 17 0.2 0.3 #Decimal, absolute, 2/3 place (tapping feedrate)
# These formats used for 'Date' & 'Time'
fs2 18 2.2 2.2lt #Decimal, force two leading & two trailing (time2)
fs2 19 2 0 2 0t #Integer, force trailing (hour)
fs2 20 0 2 0 2lt #Integer, force leading & trailing (min)
# This format statement is used for sequence number output
# Number of places output is determined by value for "Increment Sequence Number" in CD
# Max depth to the right of the decimal point is set in the fs statement below
fs2 21 0^7 0^7 #Decimal, 7 place, omit decimal if integer value
#4
Posted 26 June 2012 - 06:38 AM
use the post debugger to find out what variable is outputting the dwell value, then reformat it.
Or at the top of the toolchange postblock do this... (you first need the variable name for dwell.
dwell = dwell * 1000
I have this in the mpmaster....
fmt P 11 dwell$ #Dwell
#5
Posted 26 June 2012 - 08:01 AM
