2D HS with Axis Sub
  • Please log in to reply
2 replies to this topic
#1 Zack Offen @ Irongate Machine
    Member
  • Members
  • PipPip
  • 169 posts
Posted 09 July 2012 - 09:48 AM
I'm trying to rough out each slot on this part using a 2d HS toolpath with axis sub ( rotated around X here).
How should i set up everything to make it turn out right? I can't get the toolpath to line up with the slot.
Should i be using the bottom of the slot and unrolling that? What is the best way to generate geo for this type of toolpath?
Thanks!
#2 NOTW Programmer
NOTW Programmer
    Advanced Member
  • Members
  • PipPipPip
  • 383 posts
Posted 09 July 2012 - 01:49 PM
Thanks!
Do you have to use Axis Subs, I find that when you try to mill straight walls because the cutter never leaves the center, I get undercuts and not a staight wall. You should try simultaneous 4th axis or the screenshot you have might also work, you would probably need a second plane for the Rest operation on the material missed by the roughpass.
#3 Zack Offen @ Irongate Machine
    Member
  • Members
  • PipPip
  • 169 posts
Posted 09 July 2012 - 10:30 PM
Thanx. Gonna try some 4axis stuff.
