check surfaces
  • Please log in to reply
2 replies to this topic
#1 imec dies and molding
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 13 July 2012 - 10:36 AM
i want help about this:
when i need machining some surfaces in the part, i use the check surface, but i alwais need use them? or have other comand to auto chech other surfaces that i won't machining?  thanks
#2 Reko
Reko
    Advanced Member
  • Members
  • PipPipPip
  • 558 posts
Posted 13 July 2012 - 10:50 AM
You do not have to use them, but be careful if you choose not to use them because the cutter could violate surfaces you do not want to cut.
Another good way to control the cutter is to use "Containment Boundaries." Just draw a contour around the area you want machined, choose the chained contour and offset it to inside.
#3 imec dies and molding
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 25 July 2012 - 09:06 AM
thanks,  i'll try do it!
