Concrete Slab thickness for CNC Machines
  • Please log in to reply
20 replies to this topic
#1 danielm
danielm
    Member
  • Customers
  • PipPip
  • 96 posts
Posted 26 July 2012 - 05:48 PM
The place that I work for is moving into another bldg next spring.  The property is already paid for so its a done deal as far as I know.
I just was told that the place only has a 4" slab floor and now I'm getting nervous.  Our biggest machine is a 60,000lb Okuma HMC.  4" seems pretty thin to me.
#2 Mr. M
Mr. M
    Application Engineer
  • Members
  • PipPipPip
  • 1,110 posts
Posted 26 July 2012 - 06:30 PM
Yup, I wouldn't put that on a 4" slab
#3 Joe788
Joe788
    Advanced Member
  • Members
  • PipPipPip
  • 3,272 posts
Posted 26 July 2012 - 07:18 PM
That seems a little thin. Having a contractor chop a hole in the floor and pour two feet on concrete isn't that expensive.
The machine will probably be fine if the floor is old, and you anchor it nicely. The issue will be the poor little Haas Mini-mill (or any other machine) that's sitting next to it, trying to cut a finish pass when that 60,000lb Okuma is changing pallets.
#4 uncle_dolan
uncle_dolan
    Member
  • eMC Learning Group
  • PipPip
  • 295 posts
Posted 26 July 2012 - 07:20 PM
"Standard concrete floor slab thickness in residential construction is 4 inches. Five to six inches is recommended if the concrete will receive occasional heavy loads, such as motor homes or garbage trucks."
found this online on a very quick search. 4" sounds too thin to me... I think you are right to be a little concerned.
Brendan
#5 newbeeee
newbeeee
    old but NOT grown up
  • Members
  • PipPipPip
  • 982 posts
Posted 27 July 2012 - 12:20 AM
I would definately get some soil samples taken for a machine of that weight. It also all depends upon water table level.
Worked at a place that had new floor put in, and the contractors just cut straight through the drains. So when it rained, the water had nowhere to go except to saturate the slab which lifted the very expensive epoxy floor coating (non breathable).
4" can be ok and I wouldn't have any probs putting a machine onto some 3/4 boiler plate pads (12" square). Spreads the load over area and all that.
Putting 2ft thick slabs is ok, providing the soil below the slab is ok. No good pouring onto quicksand...just means the whole slab moves.
#6 JerryBenoit
JerryBenoit
    Member
  • Members
  • PipPip
  • 99 posts
Posted 27 July 2012 - 05:21 AM
I would contact a rep for that machine or a similar one and ask them? 4" as already stated is thin, I work at a shop that the fork truck broke the floor with a 4" slab.
Jerry
#7 JParis
JParis
    Advanced Member
  • Moderators
  • 23,612 posts
Posted 27 July 2012 - 05:32 AM
Jerry
Have we worked in the same shop perhaps  ;)
We put a new Mori NV5000 on the floor, the standard floor was 4", we dug out and iirc, we had poured a 12" concrete and rebar pad, it may have been closer to 18 but it's been awhile.  Another place I worked, and Okuma LC-40, a solid 18 of concrete and rebar.
4" is NOT going to do it, it "might" hold depending what's under it but you'll chase tolerance and machine squareness ALL the time.
#8 GoetzInd
GoetzInd
    Master Machine Masher
  • Members
  • PipPipPip
  • 1,014 posts
Posted 27 July 2012 - 05:55 AM
We have a Makino A51 (17,200lbs) on the thin part of our floor which is coincidentally 4". We were getting a LOT of vibration compared to it being on a thicker slab. We recently had holes drilled all around the machine and low viscosity concrete injected. It helped a little but still not nearly as good as it was.
Mike
#9 danielm
danielm
    Member
  • Customers
  • PipPip
  • 96 posts
Posted 27 July 2012 - 08:38 AM
Yep.  The neys have it.  A 4" slab a happy CNC machine does not make especially after reading this:
http://www.emasterca...=1
My manager is bringing this up at a meeting with the biggies on Monday.  Should be interesting.
#10 Guest_CNC Apps Guy 1_*
  • Guests
Posted 27 July 2012 - 08:45 AM
In one of your manuals (usually the installation manual) there should be specs for a proper floor. I'd put a Robodrill on a 4" slab and that's sbout it.
For a 65k# machine, you're probably lookign at 18~24" with rebar and anchors, etc...
This is the one area I see sooooooooooo many people skimp on, and of course, when the machines hav issues it's because the machine is a POS not the fact it's on a potato-chip thick floor.  I see it all the time, flatness and squareness issues, machine vibrates, etc...
DO A PROPER FLOOR!!!!!!!!
#11 spade117
spade117
    The one and only
  • Members
  • PipPipPip
  • 3,374 posts
Posted 27 July 2012 - 09:04 AM
4" is definitely not enough.
Another alternative would be to use a large plate that would disperse the load a little, but even that isn't a great idea.
#12 Guest_CNC Apps Guy 1_*
  • Guests
Posted 27 July 2012 - 09:20 AM
We do this at trade shows often when we're on 2nd floors. Good TEMPORARY solution.
#13 gcode
gcode
    Serenity
  • Moderators
  • 19,882 posts
Posted 27 July 2012 - 09:25 AM
You definitely need to have a foundation build for that machine.
As James said, the specs should be in the machines installation manual.
I'm guessing they'll want at least 3ft of concrete. Someone else mentioned the water table
If you've got a high water table, you'll have problems as well.
I've seen a machine sitting on a 15ft thick slab of concrete, that was really floating on the water table.
It was a big gantry mill, and a laser tracker could see it moving up and down along it's X axis as you
rapided back and forth.
It will cost some $$$ up front but if you don't do it, you will pay for not doing it  EVERY SINGLE DAY.
We just put in a big VTL ( 200 hp 140" table  900K pounds)
They dug a hole 50 feet deep, lined the walls with a double row of cinderblock and poured 30 ft of concrete.
The foundations cost $80K.
The machine tool builder deemed it marginal but acceptable..:rolleyes:
#14 Mr. M
Mr. M
  • Members
  • PipPipPip
  • 1,110 posts
Posted 27 July 2012 - 02:21 PM
For the big Okuma horizontals it's probably a spec for a 36" slab. You could probably get away with 24" if you had that, but not 4
#15 newbeeee
newbeeee
  • Members
  • PipPipPip
  • 982 posts
Posted 27 July 2012 - 02:24 PM
Just to be clearer after reading these...we put a leadwell 760ap on a 4" floor on boiler plate with no probs. Faster machines may move/slide so would want bolting down.
If the soil sample (ie under the slab) is good, I wouldn't hesitate to put a 40" size vertical on a 4" sat on boiler plate.
But 60000lbs requires a serious floor.
#16 Crazy^Mill/Turn
Crazy^Mill/Turn
    Regular Guy
  • Members
  • PipPipPip
  • 10,545 posts
Posted 27 July 2012 - 03:34 PM
Gcode what about the $1 million foundation for the 220' SNK at JCM? Not sure if that is the correct number since it was done before I was there, but I heard that number floated many times.
#17 gcode
gcode
    Serenity
  • Moderators
  • 19,882 posts
Posted 27 July 2012 - 03:37 PM
I don't know.. the foundation was done and they were building the machine when I started.
The number I got was $8 million complete, but I don't know how much of that was foundation
#18 newbeeee
newbeeee
  • Members
  • PipPipPip
  • 982 posts
Posted 28 July 2012 - 12:49 AM
Crazy/G
You chaps got a pic/link for that machine? What a beastie.
#19 GoetzInd
GoetzInd
  • Members
  • PipPipPip
  • 1,014 posts
Posted 28 July 2012 - 06:55 AM
Quote
http://jcmcorp.com/w...4_900x600.jpg   :thumbsup:
#20 newbeeee
newbeeee
  • Members
  • PipPipPip
  • 982 posts
Posted 28 July 2012 - 08:45 AM
WOW! I'm asuming that's a 'full size' operator in the pic :D
How do you get on with coolant / swarf flying everywhere with this style of machine?
Also, any ingress into the ways or motors (the red caps look very exposed)?
