G41-G42-G40 ..NEVER POST ON AND ARC MOVE
Started by
Oppiz
, Jul 27 2012 10:33 AM
13 replies to this topic
#1
Posted 27 July 2012 - 10:33 AM
What can I do to make sure that cutter comp. never starts or end on an arc move?
#2
Posted 27 July 2012 - 10:37 AM
We have a flag in out post that if a cutter comp move is posted with an arc move that it pops up a warning and flags the NC file where its at so we can go back and change it.
#3
Posted 27 July 2012 - 10:43 AM
the mpmaster post available for free from this website will yell at you if you have
cutter comp turning on during an arc move
#4
Posted 27 July 2012 - 10:44 AM
[attachment=3027:cflg.JPG]
You can use those to make a conditional statement,
if (comp on point or comp of point) and (sgcode$ = 2 | sgcode$ = 3)
pbld, "COMP ON OR OFF DURING ARC MOVE"
exitpost$
BTW, screenshot is from X5 nci & param ref guide.
exitpost$
#5
Posted 27 July 2012 - 12:51 PM
Use a short entry/exit line on the lead in/lead out, If you are on a circle, just start the tool from the center. and set the lead in /lead out value to zero.
#6
Posted 27 July 2012 - 01:06 PM
I know this sounds blaise' not the tone I mean but in the end, just pay attention, it's not hard to notice or control
#7
Posted 27 July 2012 - 01:15 PM
That's what I do for the wire edm. Line lead in and out only with start position set to thread position in control def.
#8
Posted 30 July 2012 - 06:11 AM
I know, but every now and then, a program will make it to the machine only to get and error. I was on vacation and the person filling in for me had an issue with it.
#9
Posted 30 July 2012 - 08:07 AM
Test for it in the post then. You can have it warn and continue, and then you look for the warning text in the g-code to see which is the offending operation.
#10
Posted 01 August 2012 - 12:46 AM
Why is this even allowed to happen? Is there ANY control out there that actually allows this? Just curious...
#11
Posted 01 August 2012 - 05:46 AM
Quote
Yes there are
#12
Posted 01 August 2012 - 07:56 AM
Bugger...
#13
Posted 02 August 2012 - 06:20 AM
As others have said put a "WARNING" in the post when G41/G42 activated on G3/G3 its easy even I did it.
Or use the IHS post
John what controller can do cutter comp on an arc??
Or use the IHS post
scompwarn : "WARNING - CUTTER COMP APPLIED ON ARC MOVE"
#14
Posted 03 August 2012 - 11:37 AM
I have found that turning off lead in / rad in on any profile will issue a G41 or G42 on an arc if starting from the center or a position off of the profile. I use this op only for deburring operations, where its starting on the profile, otherwise, I always use a minimal 0.01 for both parameters and this avoids the issues of radial cutter comp.
