Hi,
I use Mastercam 5 router pro level 1. I received a drawing in .dxf file for a 3D job. Unfortunately they did not send me the wireframe, and I only a 3d shaped drawing with 9454 broken lines. I am not able to connect the lines and keep the shape and I don’t know what to do. I rather stay within my capabilities, and pay somebody else to do these drawings for us unless there is a simple solution. Anyone interested
creating surfaces in router level 1
Started by
carpenters
, Aug 06 2012 09:00 AM
surfaces from lines wireframe
2 replies to this topic
#1
Posted 06 August 2012 - 09:00 AM
#2
Posted 06 August 2012 - 10:02 AM
I'd ask the customer for an IGES, STEP, or Solidworks file. Remodeling the part will take a lot of time, thus adding expense, and has the possibility of introducing errors.
Edit:
Wait, you're doing router? Do you just need a 2D outline? That should be fairly quick and easy. Put the file on the FTP and I'll take a peek at it.
Edit:
#3
Posted 09 August 2012 - 01:57 PM
sounds like it may be a STL or Mesh file. But as Mathew said as for a 3d surface model or a solid model.With Router Pro you can do full 3D programming.
Also tagged with one or more of these keywords: surfaces, from lines, wireframe
Mastercam Forums →
Industrial Forum →
Rotated Entities Left BehindStarted by Seanc , 10 Aug 2012 |
