The mat'l is some 9000 series hardened steel at 55hrc...a sector gear. An EDM vendor quoted a per part time of 28 minutes. I'd like to do something like plunge rough with a ceramic insert but the root diameter is pretty small...about .177dia. I uploaded the MCX-6 file here: ftp://mastercam-cadcam.com/Mastercam_forum/X6_FIles/EDM SAYS 28MINUTES.MCX-6
Maybe a 2D dynamic toolpath???? But man...I don't think that I can beat 28minutes. I know that its going to spring some to so I'd have to stop to re-clamp.
I've seen ceramic inserts to some pretty amazing stuff in inconel. If I could crank up the R's and plunge with some kind of .250dia ceramic cutter at a crazy feed rate of 40-60ipm, then 2D HFM the rest.....
Any suggestions? Heres what the part looks like with the stock drawn around it:
Need to rough some 55HRC Steel and beat the 28minutes EDM quote
Started by
danielm
, Aug 11 2012 11:55 AM
Roughing suggestions please.
9 replies to this topic
#1
Posted 11 August 2012 - 11:55 AM
#2
Posted 11 August 2012 - 12:47 PM
How thick is that stock? Can an EDM really cut that in 28 minutes? I've never used a wire EDM, but I thought feedrates were typically more like inches per hour than 2+ inches per minute.
#3
Posted 11 August 2012 - 12:52 PM
+1 to Joe. My wire experience is limited, but I doubt 28min is possible. However, milling that in 28min at 55hrc is a tall order. I guess it depends on your definition of "rough".
Mike
Mike
#4
Posted 11 August 2012 - 03:45 PM
Keep in mind that the wire EDM is going to stack the parts up, so the real cycle time might be more like 4hr to do 8 pcs.
We've had great luck cutting starter gear teeth in flywheels over 70Rc using AlCrona coated endmills, using straight oil.
#5
Posted 11 August 2012 - 04:54 PM
That's a wire-cutting job no matter how you look at it. Even if they do stack 8 pieces together ( unsure of thickness ), 28 minutes is a bargain. Based on the perimeter of the part, that wire edm would have to be flying.
Carmen
Carmen
#6
Posted 11 August 2012 - 08:55 PM
I'm with Carmen on this one, I had a good friend for about 4 years owned a WEDM shop, all Mits. Wire is the only way to do that with any speed and accuracy at all. Cut around the entire thing.
28 minutes is a bargain, depending on the thickness.
#7
Posted 12 August 2012 - 09:05 AM
Also, make sure your customer will allow EDM. None of ours will, unless we machine off the recast layer
#8
Posted 13 August 2012 - 07:15 AM
Carmen
Carmen
#9
Posted 13 August 2012 - 07:19 AM
Better jump all over the 28 minutes quote. I wouldn't do it for that if it was only an 1/8''thick.
#10
Posted 13 August 2012 - 04:00 PM
high pressure waterjet going deadly slow with 28 heads
