Post question
I am creating a specific gun drill cycle as we are doing more and more of this it makes sense for me now.
pgundrill
pdrlcommonb
drill_speed = dwell$
start_hgt = peck1$
drill_feed = peck2$
pbld, *sg01, start_hgt, *feed, e$
pbld, drill_speed, e$
pcan1, pbld, n$, *sg01, pdrlxy, pfzout, *drill_feed, strcantext, e$
pbld, n$, sg00, *start_hgt, e$
pcom_movea
My start height is actually inside of the part
The cycle itself looks like this
N4 T4 (438 X 9.5 IN GUN DRILL)
M6
(MAX - Z6.625)
(MIN - Z-.25)
G00 G90 G54 X-.9511 Y-3.8789 S500 M03
G43 H4 Z6.625 M88 T1
G01 Z3.885 F10.
S1500
G01 Z-.25 F1.7
G00 Z3.885
G80 M89
M05
G91 G28 Z0.
I am looking to be able to get a retract into the section before the G91 G28 move.
For obvious reasons I do not want to hardcode a height.
Any ideas how I can get a clearance height into here?
I am having a brain fart on this.
We've done this just like that in the past, it is the manufacturer's recommendation to turn it on about 500 RPM, then once in the hole beffore begining the feed to turn it up to the cutting RPM
We use Drill Masters/El Dorado Tool
John, something to keep in mind on gundrilling too....
I will always spin the drill backwards into the hole before turning it on. The drill you're using isn't that long on the DIA/LOC ratio so you're probably ok. But I had times with really long gundrills where the cutting edge catches the side of the pilot hole going in and crapping the drill out (and/or the part). Dropping the drill in spining backwards eliminated that.
I always pilot a 1.7 inch deep hole (1/4" dia)
and then feed my gun drill in 1.5 deep and guide the end in the hole by hand then 500 rpm and feed 15 ipm to .2 above previous drill then 2500 rpm and 1.3 feed to depth. My 36" and 48" long drills droop about 2 inches so you have to guide them in by hand not spinning. It's quite a reach to have left hand on drill end and right hand on feed override... cheers.gif
in replaced the pdrill$ call in misc2 with pgundrill and placed the postblock pgundrill right after misc1
pmisc2$          #Canned Misc #2 Cycle (User Option)
pgundrill
and right afetr pbore2$
pgundrill
pdrlcommonb
start_hgt = peck1$
drill_feed = peck2$
pbld, n$, *speed, e$
pbld, n$, sg00, clr_hght, e$
pcom_movea
I also changed this at the bottom of the post in the "old" text section
[misc2]
1. "Gun Drill"
2. ""
3. "Drill Speed"
4. ""
5. ""
6. ""
7. "Drill Start Height"
8. "Drill Cycle Feedrate"
9. ""
10. ""
11. ""
and cchanges this in the drill cycle descriptions at the bottom
8. "Gun Drill G01 Feed"
+1 to David. I always turn on the spindle at like 250-500 RPM, move to the hole, feed down into the pilot hole (.0005-.001 larger than the hole being drilled)I created 1-2x Diameter deep, turn on the high pressure coolant, dwell 1 sec., ramp up the spindle, dwell, 2-3 sec(will vary on how long the spindle takes to ramp up), feed to the bottom, turn off the coolant, dwell 1 sec, ramp down the spindle, dwell 2-3 sec., retract out, move to the next position and repeat the process. Yeah there's a lot of dwells there but when going 30xD+ ... it's worth the time for the results I get.
  • 7 years later...
I used your post as MAKINO tap, so how do I change from G81 to G84?  Thank you.
N1(0-80 CUT TAP)
G0 G17 G40 G49 G53 G80 G90 Z0
T1 M6(, CUT#2)
G90 G54 A0.
X1.42 Y5.5891 S800 M3
G43 H1 Z1. T3 M8 M135 S800
(DOC= Z0.)
G98 G81 Z0. R.25 F10.
X1.92
X2.42
X2.92
X3.42
X3.92
X4.42
X1.92 Y6.0891
X2.42
X2.92
X3.42
X3.92
X4.42
X4.92
G80 M9
M5
G53 Y0
M1
T3  M6
and then feed my gun drill in 1.5 deep and guide the end in the hole by hand then 500 rpm and feed 15 ipm to .2 above previous drill then 2500 rpm and 1.3 feed to depth. My 36" and 48" long drills droop about 2 inches so you have to guide them in by hand not spinning. It's quite a reach to have left hand on drill end and right hand on feed override... graemlins/cheers.gif
Pin what the heck are you drilling 4' deep? And how many beers does that take?
That cycle is hardcoded with a G81, a gundrill cycle you don't peck
A G83 cycle is already available in a post, so I don't understand why you would implement this instead
I did it, because I want to combine MAKINO, MATSUURA, HAAS, YCM and SUPER MAX  tapping cycles into one POST.
There are much easier & cleaner ways of doing this. I have Matsuura, Fanuc, Siemens, & Yasnac all in one post......using something like what EX-wccprogrammer outlines in this post:
http://www.emastercam.com/board/topic/78945-mastercam-posts/
is much cleaner, easier, & far more versatile for future upgrades.
This is from my post.
ptap$
       pdrlcommonb
       result = newfs(17, feed)  # Set for tapping Feedrate format
       if met_tool$,
         if toolismetric, pitch = n_tap_thds$  #Metric NC Code - Metric Tap
         else, pitch = (1/n_tap_thds$) * 25.4  #Metric NC Code - English Tap
       else,
         if toolismetric, pitch = n_tap_thds$ * (1/25.4)  #English NC Code - Metric Tap
         else, pitch = 1/n_tap_thds$           #English NC Code - English Tap
       pitch = pitch * speed #Force Units Per Minute for regular Tap cycle
       if machinepick = 8 | machinepick = 11,
         pcan1, pbld, *sgdrlref, *sgdrill, pfxout, pfyout, pfzout,
           pfrdrlout, *pitch, !feed, strcantext, "H0", *speed, e$
       if machinepick = 4, "M29", *speed, e$
       if machinepick > 8 & machinepick <= 16 & machinepick <> 11, "M29", *speed, e$
       if machinepick <> 8 & machinepick <> 11,
         pbld, pcout, e$
           pfrdrlout, *pitch, !feed, strcantext, e$
       pcom_movea
Please take note that this code is not copy paste for your post.  There is some other editing that needs to be done to make this functional.  I posted this to illustrate how I combined multiple formats into something I find very convenient.
  • 1 year later...
pmisc2$          #Canned Misc #2 Cycle (User Option)      pgundrill
pgundrill      pdrlcommonb      drill_speed = dwell$      start_hgt = peck1$      drill_feed = peck2$       pbld, *sg01, start_hgt, *feed, e$      pbld, drill_speed, e$      pcan1, pbld, n$, *sg01, pdrlxy, pfzout, *drill_feed, strcantext, e$      pbld, n$, sg00, *start_hgt, e$      pbld, n$, *speed, e$      pbld, n$, sg00, clr_hght, e$      pcom_movea
[misc2]1. "Gun Drill"2. ""3. "Drill Speed"4. ""5. ""6. ""7. "Drill Start Height"8. "Drill Cycle Feedrate"9. ""10. ""11. ""
JP,is it safe to assume this is the finished product? I want to try and implement this into my post.
