Welcome to eMastercam.com
FEEDS & SPEEDS FOR 1/8-27 NPT
  • Please log in to reply
14 replies to this topic
#1
Camdude®
Camdude®
    Advanced Member
  • Members
  • PipPipPip
  • 1,977 posts
I have to tap afew holes in 1018 using a 1/8-27 NPT tap. Doesanyone have a good feed and speed range for this tap. normally i would thread mill it but TPTB's don't want to do that so i'm stuck tapping.
#2
Mike Whitten CAD/CAM Contractors
    Advanced Member
  • Customers
  • PipPipPip
  • 1,756 posts
It depends if you are using oil or coolant (water based) and what type of tap and machine as you must have the power at low rpm. If coolant and standard tap and machine, I usually go slow. Something in the range of 10-15sfm would be fine. It's about 40% of what the book (OSG) would say. By the way, I always recommend tapering the hole using a taper pipe reamer or 1-1/2 deg em. This makes for much easier tapping and less chance of tap failure.
Mike
#3
Plastmo
Plastmo
    Member
  • Members
  • PipPip
  • 103 posts
270 rpm and 10 ipm feed
#4
Mic6
Mic6
    Advanced Member
  • Members
  • PipPipPip
  • 3,439 posts
tap failure
aka...POW!
#5
jeff
jeff
    Advanced Member
  • Members
  • PipPipPip
  • 7,222 posts
As said above, an NPT Reamer helps out alot.
Interrupted tooth taps seem to be better also (just from my own experience).
Try it at about 400 rpm's and see what the threads look like.
But overall, I've never had the best of luck tapping npt's on a cnc for some reason, the threads like to tear about 50% of the time.
#6
K2csq7
K2csq7
    Advanced Member
  • Members
  • PipPipPip
  • 2,468 posts
"the threads like to tear about 50% of the time."
1018, 50% may be an understatement... you say just a few holes, I'd just go deep enough to get them started & finish by hand.
cutting oil will be much better than coolant IMO.
#7
jeff
jeff
    Advanced Member
  • Members
  • PipPipPip
  • 7,222 posts
Another good thing about using an npt reamer is that it's way easier to start the tap by hand, if you don't start it on the cnc, provided that you take the reamer to the correct depth and let it chamfer the hole.
#8
newbeeee
newbeeee
    old but NOT grown up
  • Members
  • PipPipPip
  • 2,547 posts
I know you don't want to thread mill, but if you tap by hand, at the point that you stop there will be a vertical line up the flanks because it's cutting on the full engagement of the tap (unlike parallel tapping where it's only at the bottom/start of the tap).
We couldn't get around the line whatever we did (different oils/taps etc), so had to end up thread milling.
#9
RandleXX
RandleXX
    Advanced Member
  • Members
  • PipPipPip
  • 737 posts
+100 on Threadmilling
#10
Odell
Odell
    Member
  • Members
  • PipPip
  • 165 posts
REMEMBER....stop 1/4 turn before it breaks and you'll have no problems. biggrin.gif
#11
CADCAM3D5AXIS
CADCAM3D5AXIS
    Advanced Member
  • eMC Learning Group
  • PipPipPip
  • 534 posts
#12
Camdude®
Camdude®
    Advanced Member
  • Members
  • PipPipPip
  • 1,977 posts
lol@Odell,
thanks guys gives me a start point,
#13
Cad-Camr
Cad-Camr
    Member
  • Members
  • PipPip
  • 119 posts
Use a good rich mix on your coolant or use tapping fluid if possible and peck tap if you have that capability. graemlins/cheers.gif
#14
lionel 3362
lionel 3362
    Newbie
  • Members
  • Pip
  • 13 posts
We run npts at my shop all the time. On a 1/8-27 i go 300 RPM 11.11 IPM and Z-.350 deep and we use tapping fluid
#15
jhjr
jhjr
    Member
  • Members
  • PipPip
  • 173 posts
Tapping oil +++ , coolant works sometimes depending on what coolant you are using. Using both won't hurt. Definatly use an interrupted tooth tap as others have said.
