Okuma communications
dan m
Hi all. I haven't posted here in a while. I started a new job running Okuma Lathes and they are definitly different from what i am used to. The problem I am having is I can save a program to the PC but when I try to load it back to the machine I get a message saying the file names do not match. I saved program ABC.min to the pc and the first line looks like
$ABC.min
so at the machine i push the read button than ABC.min and get the alarm i discribed above. I am sure i am missing something simple.
thanks in advance
Place a comma before the filename
note-- CN0: is the RS232C channel on the machine , and is not required if the default devices have been altered from TT: ( the papertape reader )
and the .MIN is not required as it is the default extension
ie
<PIP> <READ> CN0:, <WRITE> (the comma is a rename delineator, the program will come in as A.MIN)
or
<PIP> <READ> CN0:,ABC123.MIN <WRITE> ( the control will rename the incoming ABC.MIN file as ABC123.MIN )
or
<PIP> <READ> CN0:<WRITE> ( the program will come into the control as the $ABC.MIN filename string or as A.MIN if omitted )
Hope this helps, this is our method
OKUMA PROGRAM TRANSFER
FROM MACHINE TO COMPUTER
#1 MAKE SURE COMPUTER TERMINAL IS SET TO THE DESIRED MACHINE NUMBER,
#2 FIND PROGRAM IN COMPUTER ( PROVEN/UNPROVEN FOLDER)
#3 IN THE CIMCO EDITOR, CLICK TRANSFER.
THEN RECIEVE
#4 PREP THE MACHINE FOR TRANSFER,
#4A CHOOSE THE MDI MENU,
#4B CHOOSE PIP
#4C CHOOSE PUNCH,
#4D TYPE IN THE PROGRAM # AND ADD.MIN
THEN TYPE ,TT;,
#4E HIT WRITE
#5 GO BACK TO THE COMPUTER AND MAKE SURE PROGRAM IS BEING
RECEIVED (IF NOT REPEAT 1 THRU 4)
#6 ONCE THE PROGRAM IS VISABLE ON THE COMPUTER YOU NEED TO
SAVE IT TO THE PROVEN FILE.
#6A SELECT FILE (TOP LEFT CORNER)
#6B SELECT FILE SAVE AS
#6C FIND THE PROVEN FOLDER
#6D CHOOSE CNC LATHES
#6E TYPE IN THE PROGRAM # AND .NC (EXAMPLE: LK564123NC)
#6F THEN SAVE
#6G AFTER PROVEN PROGRAM IS SAVED YOU MUST DELETE
THE UNPROVEN FILE
FROM COMPUTER TO MACHINE
#4B CHOOSE PIP
#4C CHOOSE READ,
#4D TYPE IN TT;’
#4E HIT WRITE
#5 GO BACK TO THE COMPUTER AND HIT ENTER
#6 ON THE MACHINE MONITOR YOU SHOULD SEE THE PROGRAM
NUMBER (IF NOT REPEAT STEPS 1 THRU 5)
#7 NOW THE PROGRAM IS IN THE MACHINE BUT NOT ACTIVE
YOU MUST CALL THE PROGRAM UP.
PROGRAM SELECT, * THEN CHOOSE PROGRAM NUMBER.
Anybody has an idea how to run statements like "if" ,when you using dnc connection on OSP-e100l control?
V1 is the user variable # from the parameter page
LE stands for less or equal
GE is greater or equal
EQ is equal
remember that the spaces are important in a if/goto sequence
and if the "V" is not correct , try "VC", some controller generations differs on that point but the "V"! should be good on the OSP100L
Try this:
V1=1 (define a value to user variable #1)
NA1 (reference number for the GOTO)
V1=V1-1 (arithmetics to calculate a new defined variable)
IF [V1 LE -10] NA2 (if the IF is true , the controls will read the NA2 and jump to the NA2 line if it's false, the control jump to the next line)
GOTO NA1 (return to top if the IF line is false)
NA2 (jump to this line if the IF line id true)
M02
EQ is equal
Try this:
M02
Ok ,but it going to work if you using DNC ? My question was how to run this kind of programs in DNC mode ?
