Post remove decimal
Hey guys,
We are using the standard MPLFAN post from mastercam,
our lathe is a regular 2 axis single turret with a fanuc 0iTD controller.
The current posts for outside thread.
G20
(TOOL - 5 OFFSET - 5)
(OD THREAD RIGHT INSERT - NONE)
( OD THREAD )
G0 T0505
G97 S400 M03
G0 G54 X.5737 Z.2167
G76 P010029 Q.001 R.001
G76 X.2993 Z-1. P372 Q70 R0. E.0625
G28 U0. W0. M05
T0500
The problem seems to be the first g76 line.
G76 P010029 Q001 R.001 the controller complains about the decimal point for the Q.
How can I modify the post to remove the Decimal point for this Q only?
Thank you.
Mike
One more thing!
G20
( OD THREAD )
G0 T0505
G97 S400 M03
G28 U0. W0. M05
T0500
I need to change or format the E.0625 value for the feed to F.0625.
How can I do this?
Thank you.
Mike
  • 1 year later...
"Find this line in your post"
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
Bellow you will see your "fs2" or Format statements you will need to add a statement
because if you change one that already exsits you will most likely change others as well.
ADD THIS at the bottom of the fs2 lines
fs2 27 0 4 0 4 #Decimal, absolute, 3 place
Then search for your fmt "Q" line under your #Thread output it will probably have a 2 next to it.
Change it to look like this.....
fmt "Q" 27 thdfirst$ #First depth cut in thread
To change the E output Look for this....
#String and string selector definitions for NC output
#Address string definitions
stra : "A" #String for address A
strd : "D" #String for address D
stre : "F" #String for address E Change E to F
strf : "F" #String for address F
stri : "I" #String for address I
Hey guys,
G20
( OD THREAD )
G0 T0505
G97 S400 M03
G28 U0. W0. M05
T0500
Thank you.
Mike
We do have the same controller on our new Mori Dura Turn lathes. I have been working on a post on and off. I know there is some work that needs to be done for canned cycles.I have to take a look at that. How is your drilling cycle working?
A format statements will take care of the decimal point.
