Inspection Point support ??
I'm starting a job that involves a lot of roughing in inconel.
I'm using the high speed 3D toolpaths and would like to utilize the Inspection Point Feature.
I'm using an older mpmaster right now and just get a rapid move up, and then it goes right back to work.
I tried using a default X6 mpfan 4X post and got
N792 M00 (TOOL INSPECTION POINT - POST CUSTOMIZATION REQUIRED)
are there any posts out thee that support this feature.. Its been around for several years now.
does the latest mpmaster support this.
I put this at the bottom of my prapidout postblock...
         pcan1, pbld, n$, psgplane, pexct, psgcode, pxout, pyout,
           pzout, pcout, pscool, strcantext, e$
           if cur_cflg$ = 70000,
             pbld, "M00", e$
             pbld, "(TOOL INSPECTION POINT)", e$
             ptcntip, "(          ", *tcnt, "   	BEGIN)", e$
             tcnt = tcnt + 1
             tcntip = tcntip + 1
             toolno = toolno - (t$ * 100)
             pbld, n$, sg97, *sgcode, pfxout, pfyout, pfzout, *toolno, "M00", e$
             toolno = toolno + (t$ * 100)
             pbld, *toolno, e$
             pcssg50
             pbld, n$, "M08", e$
     sav_seq = n$
plinout 		#Output to NC, linear movement - feed
All the tcnt & tcntip stuff is just for my N #'s
Then changed my pcssg50 postblock like so....
pcssg50 		#Output Constant surface speed clamp
     cut_count = zero
     if css_actv$, pbld, n$, *sg50, *maxss$, pgear, e$
     if cur_cflg$ = 70000, pbld, n$, pfspindle_l, e$
Here is what I get...
N2 (          2        BEGIN)
G97 G00 X20. Z10. T0001 M00
T0101
G50 S80 M41
M03
M08
X30.6473 Z-3.613
G01 Z-3.713
Z-4.8354
X30.6872
X30.8287 Z-4.7647
G00 Z-3.6354
X20. Z10.
M00
N3 (          3        BEGIN)
T0101
G50 S80 M41
M03
M08
X30.6273 Z-3.603
G01 Z-3.703
Z-4.8354
X30.6672
X30.8087 Z-4.7647
G00 Z-3.6354
X20. Z10.
M00
N4 (          4        BEGIN)
T0101
G50 S80 M41
M03
M08
X30.6073 Z-3.5879
G01 Z-3.6879
Z-4.8354
X30.6473
X30.7887 Z-4.7647
G00 Z-3.6354
I haven't heard of a stock post shipping with this functionality.
Happy to help more if you need it!
k2csq7 at gmail dot com if you want the post this hacked up thing I call a post (mplmaster) thumbsup.gif
thanks,
that looks like a lathe post ???
I found this in the mpfan 4X mill post
if rpd_typ$ = 7, pbld, n$, "M00",
then I downloaded the latest X6 mpmaster and did a search for
rpd_typ$
with no luck.
The rev notes make no mention of an Inspection report tweak so it looks like I've got some work to do.
I can use you lath edits as a starting point
You'll have it done in < 2 hrs.
I only have it in one of my lathe posts, don't use it anyway cause "each cut needs to be it's own operation" EACH AND EVERY CUT sleeping.gif (hence the N #'s)
BTW
rpd_typ$ = 7
I found out later is the same as
cur_cflg$ = 70000
"The rev notes make no mention of an Inspection report tweak "
Hi, the X4 NCI Reference explains how to modify your post to support this feature, there's a whole section on it. This should have been installed with Mastercam, but shoot me an email if you don't have it, I can send you the pages.
--Robert
thanks,
rpd_typ$
with no luck.
Thanks to everyone who helped me with this.
John Paris gave me the final tweak that made it perfect...
This feature is a lifesaver on the the job we're running right now.
We're machining a very large inconel waterbox and I have the Inspection time set to 20 minutes
Its working perfectly.
this is the output I'm getting
X4.8185 Y12.173 Z16.8412
G00 Z18.
X-4.5389 Y10.7114
M09
G91 G28 Z0.
M00 (TOOL INSPECTION POINT)
G00 G90 G54 X-4.5389 Y10.7114
S152 M03
G43 H1 Z18.
F6.4 M08
Z17.1012
G01 X-4.5383 Y10.7125 Z16.9793
X-4.5366 Y10.7157 Z16.9577
X-4.5339 Y10.7209 Z16.9366
  • 5 months later...
Jeremy,
The time calculation actually happens in the mp.dll I believe
You just need to set up the rpd_typ = 7 flag in the post if it exists, that will determine what happens when you hit the time.
Where does the turret go
This is what I have John....
prapidout #Output to NC of linear movement - rapid
pcan1, pbld, n$, sgfeed, sgplane, `sgcode, [if gcode$ = 1, sgfeed], sgabsinc, pccdia,
pxout, pyout, pzout, paout, pcout, [if gcode$ = 1, `feed], strcantext, scoolant, e$
#pbld, "M00", e$
#pbld, "(TOOL INSPECTION POINT)", e$
ptlchg$
if rpd_typ$ = 7,
#pbld, "M00", e$
#bld, "(TOOL INSPECTION POINT)", e$
ptlchg$
plinout #Output to NC of linear movement - feed
phsm_on
if mr5$ = 1,
use_frinv = 0
ipr_type = 0
pfcalc_u_min
if not(cuttype <> 0 & xinc = 0 & yinc = 0 & zinc = 0 & ainc = 0 & cinc = 0), #avoid output of feed with no motion when changing between G93 and G94/G95
if mill5$ = 1 & lock_codes = 1, #Force output to avoid axis locking when the lock_codes aren't being used
pcan1, pbld, n$, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
pfxout, pfyout, pfzout, pfaout, pfcout, `feed, strcantext, scoolant, e$
else,
pxout, pyout, pzout, paout, pcout, `feed, strcantext, scoolant, e$
#pbld, "M00", e$
ptlchg$
if rpd_typ$ = 7,
#pbld, "M00", e$
ptlchg$
If I set it to distance it goes home, If I set it to time it does not affect the code at all.
  • 1 year later...
