How do I add revision number?
In our shop we have many versions of NC files and we would like it posts out revision number everytime we generate g-code. How do I do that? Please help. Here is the sample that I would like to have. Thank you
O0000 (T)
(This Post Is Only For - HAAS)
(Unproven/ Proven By: )
(Post Revision "1") -----------> I want some thing like this, thank you
(ALUMINUM INCH - 2024)
(***** Posted Date And Time *****)
(JUL.05.2012 @ 7:17PM)
(Source - C:\USERS\MASTER\DOCUMENTS\MY MCAMX5\MCX\T.MCX-5)
(NC - C:\USERS\MASTER\DOCUMENTS\MY MCAMX5\MILL\NC\T.NC)
(****** Note From Programmer ******)
(MANUAL ENTRY)
(********* Tool List Info *********)
(T1 -2" FACE MILL - H1 - D1)
(T2 - 3/4 FLAT ENDMILL - H2 - D2)
(T4 - 1/2 DRILL - H4 - D4)
(T5 - 3/4-10 TAPRH - H5 - D5)
(T3 - 1/2 FLAT ENDMILL - H3 - D3)
(******* Work Offset List *******)
G90 G10 L2 P1 X0 Y0 Z0
G90 G10 L P X0 Y0 Z0 (Optional)
N1 ( FACING )
G91 G28 Z0
G0 G17 G40 G49 G80 G90
T1 M06 (2" FACE MILL)
G0 G90 G54 X-7.2 Y-.5001 S5000 M3
G43 H1 Z2. T2 M8
Z.2 G1 Z-.0001 F100.
X1.2 F50.
G2 Y-1.4999 I0. J-.4999 F200.
G1 X-7.2 F50.
G0 Z2. M9
G91 G28 Z0 M5
M1
N2(CONTOUR)
G91 G28 Z0
T2 M06 ( 3/4 FLAT ENDMILL)
G0 G90 G54 X-3.25 Y1.875 S700 M3
G43 H2 Z2. T4 M8
Z.2 G1 Z-1. F100.
G41 D2 Y1.125 F70.
G3 X-2.5 Y.375 I.75 J0.
G1 X0.
G2 X.375 Y0. I0. J-.375
G1 Y-2.
G2 X0. Y-2.375 I-.375 J0.
G1 X-5.
G2 X-5.375 Y-2. I0. J.375
G1 Y0.
G2 X-5. Y.375 I.375 J0.
G1 X-2.5
G3 X-1.75 Y1.125 I0. J.75
G1 G40 Y1.875
Z.2 F6.42
G0 Z2. M9
G91 G28 Z0 M5
M1
N4(DRILLL)
G91 G28 Z0
T4 M06 ( 1/2 DRILL)
G0 G90 G54 X-2.3998 Y-.9136 S2000 M3
G43 H4 Z2. T5 M8
G98 G82 Z-.75 R.1 P100. F20.
M9
G91 G28 Z0 M5
M1
N5(TAP)
G91 G28 Z0
T5 M06 ( 3/4-10 TAPRH)
G43 H5 Z2. T3 M8
M29 S200
G98 G84 Z-1. R.1 F20. P100
M9
G91 G28 Z0 M5
M1
N3(OD)
G91 G28 Z0
T3 M06 ( 1/2 FLAT ENDMILL)
G0 G90 G54 X-2. Y-3.25 S7000 M3
G43 H3 Z2. T1 M8
Z.2 G1 Z-2. F6.42
G41 D3 Y-2.75 F40.
G3 X-2.5 Y-2.25 I-.5 J0.
G1 X-5.
G2 X-5.25 Y-2. I0. J.25
G1 Y0.
G2 X-5. Y.25 I.25 J0.
G1 X0.
G2 X.25 Y0. I0. J-.25
G1 Y-2.
G2 X0. Y-2.25 I-.25 J0.
G1 X-2.5
G3 X-3. Y-2.75 I0. J-.5
G1 G40 Y-3.25
Z.2 F6.42
G0 Z2. M5
G91 G28 Z0 M9
G28 Y0
Here is how I did it sorry Chris. :welcome:
Up in the notes:
# mr9 - Control Program Revision A to Z control in the post.
#   	0 = N/C
#   	1 = A
#   	2 = B
#   	26 = Z
# mr10 - Customer Selection output when posted.
#   	0 = ADD CUSTOMER
#   	1 = BOEING
#   	2 = FUJI
#   	3 = LEFIELL
#   	4 = GE AEROSPACE
#   	5 = MITSUBISHI
#   	6 = SPIRIT
#   	7 = GOODRICH LANDING
#   	8 = ROCKWELL COLLINS
#   	9 = SPIRIT
#   	10 = D.O.D.
#   	11 = LOCKHEED
#   	12 = VOUGHT
Then down in the body of the post where strings are defined it this:
# Customer selector
scust0   : "ADD CUSTOMER"
scust1   : "BOEING"
scust2   : "FUJI"
scust3   : "LEFIELL"
scust4   : "GE AEROSPACE"
scust5   : "MITSUBISHI"
scust6   : "SPIRIT"
scust7   : "GOODRICH LANDING"
scust8   : "ROCKWELL COLLINS"
scust9   : "SPIRIT"
scust10  : "D.O.D."
scust11  : "LOCKHEED"
scust12  : "VOUGHT"
scust : ""
fstrsel scust0 mr10$ scust 13 -1
# Program Rev Complience with Boeing/Spirit MBD Requirements
sr00  : "N/C"
sr01  : "A"
sr02  : "B"
sr03  : "C"
sr04  : "D"
sr05  : "E"
sr06  : "F"
sr07  : "G"
sr08  : "H"
sr09  : "I"
sr10  : "J"
sr11  : "K"
sr12  : "L"
sr13  : "M"
sr14  : "N"
sr15  : "O"
sr16  : "P"
sr17  : "Q"
sr18  : "R"
sr19  : "S"
sr20  : "T"
sr21  : "U"
sr22  : "V"
sr23  : "W"
sr24  : "X"
sr25  : "Y"
sr26  : "Z"
srev : ""
fstrsel sr00 mr9$ srev 27 -1
Then in the definitions section of the post:
prdbcustp
	*scust
psrev
	*srev
Then in the header it is called this way:
  	#"%", e
 	#!spaces$
 	spaces$ = 0
 	#*progno$, " (", sprogname$,")", e$
 	#spaces$ = prv_spaces$
 	#pbld, n$, *smetric, e
 	"(PROGRAM NAME - ", sprogname$, ")", e$
 	"(CUSTOMER 	- ", prdbcustp, ")", e$ # Added RDB
 	"(PART NUMBER  - ", smachgrp_name, ")", e$ # ADDED Roger Martin
 	"(MODEL #  	- ", smachgrp_name, ".CATPART)", e$ # Added RDB
 	"(PROGRAMMER   - RON ", e$ # Added RDB
 	"(DATE 		- ", *smonth,"-",day$,"-",*year2,")", e$ #Date output as month,day,year - Ex. Feb. 12 2005
 	"(TIME 		- ",ptime,")", e$  #12 hour time output 3:52 PM
 	"(PROGRAM REV  - ", psrev, ")", e$
 	"(TOOL LIST)", e$ #Giving it a title
 	"(--------------------------------------------------------------------------)", e$
 	spaces$ = 1
Hopefully that is helpful and gets you on your way. I developed most of this but I did get some help along the way so glad to share.
  • 1 year later...
Well, If you don't mind that you have an additional but very small text file in the same directory, then here is my
solution what I put together in the afternoon. Just for fun and training. :)
This simple postblock read this tiny file, which holds rev number in the very first line.
If this file not exist (at first post run) it creates one with the same name of MCX but with different extension (.data in my sample)
Extension is doesn't really matter, it only needs to be a plain ASCII text file.
Now as I said, it's based on MCX name and same folder. Easy to change to NC name (or path too)
Additionally this postblock try read more line from this small line if there is.
What is it mean? It's mean that you can use this file as a job definition if you like. So if you write more line after
the first line (that's only rev number) like Programmer, Drawing number, Fixture, Comment, etc, this postblok
will output also. So you can hold the job details in this file, and then output into the header of NC code.
Sounds good? :)
This postblock also can override the revision number. You can switch on a question during posting, so you
have an option if you don't want to increase the revision number, then you can input yours and the post will
use that from that moment. Otherwise just hit ESC or ENTER to 0 and post will go ahead the actual REV number.
I built in this, because many times people just post a part of OPs or just wanna look something.
With the tools of MP language, many-many thing is possible, just need to imagine-define-think.
So I hope someday, someone will found this useful:
Variables, buffer-8
# Revision number and header Buffer - 8
rc8 : 1
wc8 : 1
size8 : 0
fbuf 8 1 255 1 1
s_b8_strings : "" # String definiton for Buffer - 8
b8_RevNumber : 0 # Revision number
RevNoReset : 0 # RevNo reset number after question
CheckRevNum : yes$ # Ask RevNumber to change during posting?
sRevExtension : ".data" # File extension of revision/header file
fmt 4 b8_RevNumber # Format RevNumber
fq 20 RevNoReset "Revision number will be //b8_RevNumber// is it OK?" # Question to ensure of RevNumber
Postblock:
# Following postblock based on a ".data" ASCII text file, in the same name and directory of MCX file
# Data file read into Buffer - 8
pReadRevNumber # Read and set revision number of NC code
 sbufname8$ = smcpath$ + smcname$ + sRevExtension
 if fexist(sbufname8$),		    # Check if .data file exist
  size8 = rbuf(8, 0)
  rc8 = 1
  # Read first line from buffer, revision number
  s_b8_strings = rbuf(8, rc8)		  # Read first line from data file
  b8_RevNumber = plcval(s_b8_strings, 3) * 100	 # 1st digit in string
  b8_RevNumber = b8_RevNumber + (plcval(s_b8_strings, 2) * 10) # 2nd digit in string
  b8_RevNumber = b8_RevNumber + plcval(s_b8_strings, 1)   # 3rd digit in string
  if CheckRevNum, q20		    # Ask question of revise RevNumber
  if RevNoReset, b8_RevNumber = RevNoReset	  # Set RevNumber by question if not zero answer
  s_b8_strings = no2str(b8_RevNumber + 1)	   # Increment RevNumber
  if b8_RevNumber + 1 < 10, s_b8_strings = "0" + s_b8_strings  # Set trailing zero of string based on RevNumber length
  if b8_RevNumber + 1 < 100, s_b8_strings = "0" + s_b8_strings # Set trailing zero of string based on RevNumber length
  s_b8_strings = wbuf(8, wc8)		  # Write back the first line to data buffer file
  # Read additional lines if already exist in .data file, Customer, Programmer, Drawing No, etc...
  while rc8 <= size8,
   s_b8_strings, e$
 else,	    # Create a simple .data file if not exist and set RevNumber value
  spathext$ = smcpath$   # Set path based on MCX path
  snameext$ = smcname$   # Set filename based on MCX name
  sextext$ = sRevExtension  # Set .data extension
  subout$ = 3	  # Create & output into external .data file
  extprg$ = 1	  # Open our data file to write
  "002", e$	  # Write RevNumber for next run in new data file
  subout$ = 0	  # Set output back to main NC file
  b8_RevNumber = 1    # Set actual RevNumber @ fist run
Drop this into pheader$ or psof$
pReadRevNumber
"( Revision Number: ", *b8_RevNumber, ")", e$
hundredbucksplease :laughing::D
How about my english? Get better? :D:guitar:
:cheers: Cheers, Peter! Very nicely done, this method of external file manipulation can be adapted for many different scenarios. Maybe like automated sequential serialization engraving.... Or maybe heat lot numbers...
THX Ex-W! :)
...or during posting you can ask a string what you modified at actual revision and collect them into this file, even with timestamp and name!
...or... :D
:cheers:
I got buffer problem, MasterCam stop respond. Do you know why?
This is what I got...
# Buffer 8 - Customized tool and sequence numbers
rc8 : 1
wc8 : 1
init : 0
rpttl : 0
rpttl2 : 0
size8 : 0
fbuf 8 1 255 1 1
# Parameter read postblocks:
pprep$ #Pre-process postblock - Allows post instructions after the post is parsed but before the NC and NCI file are opened.
param_read$ = 1
#DO NOT ATTEMPT TO OUTPUT TO THE NC FILE IN THIS POSTBLOCK (OR ANY POSTBLOCKS YOU MAY CALL FROM HERE) BECAUSE THE NC OUTPUT FILE IS NOT YET OPENED!
rd_mch_ent_no$ = 0 #Read only the machine base parameters (use to collect common parameters from CNC_MACHINE_TYPE)
rd_md$ #Read machine definition parameters
#debug
#error_msg$ = 0
#err_file$ = 4
#bug2$ = 40
fastmode$ = yes$
pparameter$ # Run parameter table
if opcode$=13 | opcode$=14, result = fprm (opcode$)
if prmcode$ = 10000, stoper = ucase(sparameter$)
if stoper=snull, stoper = snullop
if prmcode$ = 10010, stock = rpar(sparameter$,1) # Stock to leave in Z
if prmcode$ = 10068, stock1 = rpar(sparameter$,1) # Stock to leave in XY
if prmcode$ = 12068, stock2 = rpar(sparameter$,1) # Stock to leave in Z facing
if prmcode$ = 10020, clearinc = rpar(sparameter$,1) #param 10020 is clearance now and 10021 indicates abs or inc
if prmcode$ = 15100, clearflg = rpar(sparameter$,1)
if prmcode$ = 15145, metvals = rpar(sparameter$,1)
if prmcode$ = 15339, clearstrt = rpar(sparameter$,1)
if prmcode$ = 15346, comp_type = rpar(sparameter$,1)
if prmcode$ = 15182, miscvalon = rpar(sparameter$,1)
if prmcode$ = 20010, sconstplname = ucase(sparameter$)
if prmcode$ = 20011, sconstplcomm = ucase(sparameter$)
if prmcode$ = 20012, stoolplname = ucase(sparameter$)
if prmcode$ = 20013, stoolplcomm = ucase(sparameter$)
if prmcode$ = 20014, swcsplname = ucase(sparameter$)
if prmcode$ = 20015, swcsplcomm = ucase(sparameter$)
if prmcode$ = 20016, smatlname1 = ucase(sparameter$)
if prmcode$ = 20017, smatlname2 = ucase(sparameter$)
if prmcode$ = 20018, stpgrpname = ucase(sparameter$)
if prmcode$ = 12025, rotary_axis2 = rpar(sparameter$,1) #Capture the axis of rotation in Multiaxis Drill and Curve 5 Axis
if prmcode$ = 15371, axissubdir = rpar(sparameter$,1)
if prmcode$ = 10029, operation_depth = rpar(sparameter$, 1) #Capture the full depth of OP
if prmcode$ = 10027, OpTopOfStock = rpar(sparameter$, 1) # Operation Top of Stock
if prmcode$ = 10020, OpClrPlane = rpar(sparameter$, 1) # Operation Clearance plane
if prmcode$ = 15374, OpRtrPlane = rpar(sparameter$, 1) # Operation Retract plane
if prmcode$ = 10024, OpFeedPlane = rpar(sparameter$, 1) # Operation Clearance plane
if prmcode$ = 15100, OpClrPlane_ON = rpar(sparameter$, 1) # Operation Clearance plane set or not
if prmcode$ = 15101, OpRtrPlane_ON = rpar(sparameter$, 1) # Operation Retract plane set or not
if prmcode$ = 12628,
hst_flg = 1
hststyle = rpar(sparameter$,1)
if prmcode$ = 15084, NumEntities = rpar(sparameter$, 1)
if prmcode$ = 15211, DepthCuts = rpar(sparameter$, 1)
if prmcode$ = 15240, sOpSeqNo = sparameter$ #This is the operation manager operation number
if prmcode$ = 20001,
s20001 = sparameter$
s20002 = sparameter$
pwrttparam$ #Information from parameters
if prmcode$ = 20004, slot = rpar(sparameter$,16)
if prmcode$ = 20006, cut_ability = rpar(sparameter$,8)
if prmcode$ = 20007, pilot_dia = rpar(sparameter$,11)
hst_flg = 1
poperation
if sof & scomm_sav <> snull,
spaces$ = 0
*sav_n3, spaces$ = 0, scomm_str, *scomm_sav, scomm_end, e$
spaces$ = sav_spc
size8 = rbuf(8, 0)
rc8 = 1
while rc8 <= size8,
s_b8_strings, e$
pheader$ #Call before start of file
hour = int(time$)
min = int((time$ - hour)* 100)
if hour > 12, hour = hour - 12
if hour = 0, hour = 12
year$ = year$ + 2000
"%", e$
spaces$=0
*progno$, " ", scomm_str, snamenc$, sextnc$, scomm_end, e$
#scomm_str, spathnc$, scomm_end, e$
comment$, e$
[spaces$ = 0, scomm_str, "SOURCE= ", smcname$, smcext$, scomm_end, spaces$=sav_spc], e$
########## Posted Date & Time ##########
[spaces$ = 0, "(POSTED ON ", *smonth, ".", *day$, ".", *year$ # MON-DD-YYYY
" AT ", time$,")", spaces$=sav_spc], e$ # 24 hour
#scomm_str, smcpath$, scomm_end, e$
[spaces$ = 0, if spostname_sav = snull, spostname_sav = spostname, spaces$=sav_spc]
scomm_str, snamepst$, scomm_end, e$
#q3
#"(OPERATION # ", sindividualoperation,"",
q4
if stotaloperation, "(", stotaloperation, ")", *e$, else, "", e$,
#"(CUSTOMER NAME= "
#q5
#"", scustomername,")", e$
#q6
#"(PART NAME= ", spartname,")", e$
#q7
#"(PART#= ", spartnumber,"",
#q8
#" REV.", spartrevision,")", e$
#q9
#"(PROGRAMMER= ", sprogrammer,")", e$
#q10
#"(SETUP BY= ", ssetupby,")", e$
#scomm_str, sprogname$, scomm_end, e$
spathnc$ = ucase(spathnc$)
smcname$ = ucase(smcname$)
spaces$=0
#scomm_str, "PROGRAM NAME - ", sprogname, scomm_end, e
#scomm_str, "DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, scomm_end, e
#scomm_str, "MASTERCAM - V", *vers_no$, scomm_end, e$
# scomm_str, "MASTERCAM - X", scomm_end, e$
#scomm_str, "MCX FILE - ", smcpath$, smcname$, smcext$, scomm_end, e$
# scomm_str, "POST - ", snamepst$, scomm_end, e$
#scomm_str, "MP - V", *dll_vers$, scomm_end, e$
stck_matl$ = ucase(stck_matl$)
#scomm_str, stpgrpname, scomm_end, e$
#scomm_str, "MATERIAL STK SIZE= ", *stck_ht$, " ", *stck_wdth$, " ", *stck_thck$, "", smatlname2, scomm_end, e$
#scomm_str, "MATERIAL TYPE= ", stck_matl$, scomm_end, e$
spaces$=sav_spc
#scomm_str, "PROGRAM - ", sprogname$, sextnc$, scomm_end, e$
#*e$
#"(***** Posted Date And Time *****)", e$
#scomm_str, *smonth, ".", *day$, ".", *year$ # MON-DD-YYYY
#scomm_str, "DATE - ", *year$, "/", *month$, "/", *day$, scomm_end, e$ # YYYY/MN/DD
#scomm_str, "DATE - ", *day$, "/", *month$, "/", *year$, scomm_end, e$ # DD/MN/YYYY
#scomm_str, "DATE - ", date$, scomm_end, e$ # DD-MM-YR
#" @ ", *hour, ":", *min, [if time$ < 12, "AM"], [if time$ >= 12, "PM"], scomm_end, e$ # 12 hour
#scomm_str, "Post Rev. - ", *slicense, scomm_end, e$
#scomm_str, "Source - ", smcpath$, smcname$, smcext$, scomm_end, e$
#scomm_str, "NC - ", spathnc$, sprogname$, sextnc$, scomm_end, e$
pReadRevNumber
In your post buffer 8 is already defined.
So in my example change the buffer definition to "9"
This line:
fbuf 9 1 255 1 1
Then change every "8" realted variables to 9. Like rc8 to rc9, size8 to size9. Everything.
Changes in filestuff:
 sbufname9$ = smcpath$ + smcname$ + sRevExtension
 if fexist(sbufname9$),		    # Check if .data file exist
And need to change read write routines to "9" also:
  size9 = rbuf(9, 0)
  rc9 = 1
  s_b9_strings = rbuf(9, rc9)		  # Read first line from data file
And:
  s_b9_strings = wbuf(9, wc9)		  # Write back the first line to data buffer file
  while rc9 <= size9,
   s_b9_strings, e$
Everything have to be 9.
This is what I got and the MasterCam did not input the revision, I think I did something wrong...
# Revision number and header Buffer - 9
rc9 : 1
wc9 : 1
size9 : 0
fbuf 9 1 255 1 1
s_b9_strings : "" # String definiton for Buffer - 8
b9_RevNumber : 0 # Revision number
fmt 4 b9_RevNumber # Format RevNumber
fq 20 RevNoReset "Revision number will be //b9_RevNumber// is it OK?" # Question to ensure of RevNumber
# Data file read into Buffer - 9
size9 = rbuf(9, 0)
rc9 = 1
b9_RevNumber = plcval(s_b9_strings, 3) * 100 # 1st digit in string
b9_RevNumber = b9_RevNumber + (plcval(s_b9_strings, 2) * 10) # 2nd digit in string
b9_RevNumber = b9_RevNumber + plcval(s_b9_strings, 1) # 3rd digit in string
if RevNoReset, b9_RevNumber = RevNoReset # Set RevNumber by question if not zero answer
s_b9_strings = no2str(b9_RevNumber + 1) # Increment RevNumber
if b9_RevNumber + 1 < 10, s_b9_strings = "0" + s_b9_strings # Set trailing zero of string based on RevNumber length
if b9_RevNumber + 1 < 100, s_b9_strings = "0" + s_b9_strings # Set trailing zero of string based on RevNumber length
while rc9 <= size9,
s_b9_strings, e$
b9_RevNumber = 1 # Set actual RevNumber @ fist run
hour = int(time$)
"%", e$
spaces$=0
comment$, e$
#q3
q4
#"(CUSTOMER NAME= "
#q5
#q6
#q7
#q8
#q9
#q10
pReadRevNumber
"( Revision Number: ", *b9_RevNumber, ")", e$
Do you know why sometimes if gives me like
15-427723-00-REV 1-FIX.NC REV.890 instead of 15-427723-00-REV 1-FIX.NC REV.1
I think I have to RESET the revision number at the QUESTION WINDOW if I opened A.MCX-7 file then switch to B.MCX-7 the revision occurrence is sometimes not counting sequential.
Original 1st or previous 2nd? In this case (current 3).
Like we make this part 1 year ago for OP1 then we modified it like the way we love it to be as "NOW". I think it should notify us like
CNC Rev.2 (Originally Rev.1 was posted on Sep.1st.2000)
OK, so you ALWAYS want to see the FIRST revision date? Even if current rev is 1232444?
Have you thought about the G10? Suppose I have this
G90 M0 (CHECK WORK OFFSET)
G10 L2 P0 X0 Y0 Z0 B0(G53 ZERO)
G10 L2 P1 X0 Y0 Z0 B0(G54 B90.)
G10 L2 P2 X0 Y0 Z0 B0(G55 B270.)
In the WCS ---> VIEW MANAGER
G10 L2 P1 X0 Y0 Z0 B0(G54 B90.) would be ----> G10 L2 P1 X.258 Y852. Z0 B0(G54 B90.) ======> XYZ manually entered by programmer and the post reads from WCS Comment
G10 L2 P2 X0 Y0 Z0 B0(G55 B270.) would be ----> G10 L2 P2 X-.253 Y-.952 Z.500 B0(G55 B270.) ======> XYZ manually entered by programmer and the post reads from WCS Comment
I think we should utilize the WCS COMMENT to output the VALUE as programmer input their G10 XYZ location value..... for B0, B90. B270.
do you think it is possible to do it? Because we save G10 lines into the source file and will post at demands since the job fixture already stayed on the PALLET....
