Haas TR-160Y Trunnion Table
MSL
Hi,
We just bought a Haas TR-160Y Trunnion Table. I need to do a test run on it. Was wondering if anyone out there is using this machine? If I start with the generic Haas TR series post that comes with Mastercam what should I change first since the TR160Y is sitting along the Y axis?
Using X6MU2
Thanks in advance.
Ara.
If you are using the Generic Haas TR Post, do not try and change anything in the Machine Definition. It has no effect on the TR post.
All of our Generic 5X Posts must be configured in the PST file itself. You will need to change the setting of the 'rotdir2$' variable. 'rotaxis' and 'rotdir' use vectors to establish the axis of rotation and the rotary zero direction. These vectors are always perpendicular to the rotary axis.
For the TR post, try setting 'rotdir2$' to either 'vecx' or '-vecx'. That should change the secondary rotary axis to rotate about Y.
Thanks Colin. I'll try this.
Ara.
We just started using a Haas TR-160Y with a control box recently.
I have not made any programs for it in MC yet, but made the changes that Collin suggested to the TR post and did a quick test. The code looks right so far.
Hi Oscar,
I made the changes. It looks right. just need to run my test program.
Thanks.
Ara.
Hi Colin,
Could you check see if this part of my post is ok. Something is not right, can not find out why!!!!
It's a Haas TR-160Y Trunnion Table which sits along Y axis.
Thanks.
Ara.
# 5 Axis Rotary Settings
#Assign axis address
str_pri_axis : "A" #Changed from "B" to "A" 09/26/12
str_sec_axis : "B" #Changed from "B" to "A" 09/26/12
str_dum_axis : "C"
#Toolplane mapped to top angle position strings
str_n_a_axis : "A" #Changed from "B" to "A" 09/26/12
str_n_b_axis : "B" #Changed from "A" to "B" 09/26/12
str_n_c_axis : "C"
#Machine rotary routine settings
mtype : 0 #Machine type (Define base and rotation plane below)
#0 = Table/Table
#1 = Tilt Head/Table
#2 = Head/Head
#3 = Nutator Table/Table
#4 = Nutator Tilt Head/Table
#5 = Nutator Head/Head
Hi Ara,
The Primary axis string should be 'B' (axis with the highest travel range) and the Secondary should be 'A'.
You need to post the 'rotaxis1$/rotdir1$' and 'rotaxis2$/rotdir2$' settings. Those variables control how the angles are output.
Hi Colin,
Thanks for the reply. This post is for one of our local community collage, Since they don't have any luck with their local reseller. I'm volunteering my time to make it work, but don't have lot of experience on editing post. So, it will take me a while to get it right.
Appreciate your help.
Ara.
head_is_sec : 1 #Set with mtype 1 and 4 to indicate head is on secondary
#Preferred setup is pri. zero matches sec. zero/direction
#Zero machine and determine the planes perp. to axis rotations
#These plane combinations are valid:
#Primary plane XY XZ YZ
#Secondary or XZ XY XY
#Secondary YZ YZ XZ
#Primary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis must be the XY plane
rotaxis1$ = vecy #Zero
rotdir1$ = -vecx #Direction
#Secondary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis and this plane normal
#are aligned to calculate the secondary angle
rotaxis2$ = vecz #Zero
rotdir2$ = vecx #Direction # Changed from (vecy) to (vecx) 09/26/12
#NOTE: Use of 'top_map' requires the dealer match the
# above settings below. These must match initial settings!!!
p_nut_restore #Postblock, restores original axis settings
result = updgbl(rotaxis1$, "vecy") #Zero
result = updgbl(rotdir1$, "-vecx") #Direction
result = updgbl(rotaxis2$, "vecz") #Zero
result = updgbl(rotdir2$, "vecy") #Direction
  • 3 weeks later...
Hi Ara,
On this machene the A is the one with the highest range. B can only go from -120 to 120.
  • 10 months later...
Hello I tried follow step by step your description and almost everything is working, apart from B axis.
Our Trunion is located on right side
(Just for your informations
I limit axis to limit A axis as below:
#Set the absolute angles for axis travel on secondary
sec_limlo$ : -30
sec_limhi$ : 120
#Set intermediate angle, in limits, for post to reposition machine
sec_intlo$ : -30
sec_inthi$ : 120
All movements on X, Y, Z, A look fine
But B axis is wrong.
In example we must change:
( b AXIS IS 90 DEGREE OUT)
B-90 to B180 or B-180.
Which variables I need to change to get this output ?
Could You help?
This is part of out 5 axis post:
str_pri_axis : "B"
str_sec_axis : "A"
str_dum_axis : "C"
str_n_a_axis : "B"
str_n_b_axis : "A"
str_n_c_axis : "C"
#0 = Table/Table
#2 = Head/Head
#Secondary YZ YZ XZ
rotdir1$ = -vecx #Direction (originally -vecx )
rotdir2$ = vecx #Direction (originally vecy) # this value is responsible for x 03.09.2013
  • 10 years later...
Здравствуйте у меня есть пост TR и пост UMC750. Станок нового поколения с функцией MRZP. В TR посте нет функции DWO / TCPC. В UMC посте есть те функции.
Пробовал писать УП на UMC. Cтанок передвигается рывками. Потом как выводит УП не очень хорошо.  Есть предположение что перепутаны оси.  Подскажите как можно исправить?
  • Huh? 1
