How to change a G83 to post three positive z's?
Hello,
I am building a post for our Bridgeport 308 machine.. It has a different canned cycles.. For all canned cycles G81 to G85 the z has to be a positive number not negative.. Also it needs two z code for each peck on a G83 so first peck Z then next Z is second peck... I started with a MPmaster post with X6.. I can just put a positive Z number in Mastercam but the verify or backplot will be wrong...
Here is how I need it to post..
G99 G83 X(First hole X location) Y (First hole Y location) Z (Positive final depth) Z (Positive 1st peck depth) Z (Positive 2nd peck depth) F (feed rate)
Here is how it post now...
G00 G17 G90 X2.5625 Y-.25 S2200 M03
H5 Z1.
Z.1
G94
G99 G83 Z-.53 R.1 Q.0265 F4 <---------------- Z needs to be positive and the R and Q need to be gone and the X,Y location from above needs to be on this line------------------------------->
Can this be done?
this will add the X and Y on the first line
force_dpts : no$ #Force XY output on all drilling lines including cycle call?
change to
force_dpts : yes$ #Force XY output on all drilling lines including cycle call?
Great thanks... Do you know how to get rid of the R and Q on the canned cycles? Also how to post positive Z's in all canned cycles?
  • 9 months later...
This equation will take care of your positive z's. Took a bit to figure out the right language as my base in code is java and things of that nature:
ppeck$ # Canned Peck Drill Cycle
if depth$ < 0, depth$ = zr$ + depth$ * -1.
n$, *sgdrill, *x$, *y$, *depth$, peck1$, peck2$, dwell$, *frplunge$,e$
This will take any take any (-) depths make them positive and the zr$ has to be added on BOSS8 to take in account the feed plane distance when drilling cycles are used.
I started with a boss9 post from v9 of mastercam. Thought it would be easier but there are some serious differences.
To remove the R and the Q you need to edit the variable to reflect whatever letter your control reads for dwell and remove any reference to Q (example):
fmt P 1 dwell$
fmt Z 1 peck1$
fmt Z 1 peck2$
what BOSS8 uses. Seems yours might be same or similar.
I'm not really sure... I would use abs() function:
if depth$ < 0, depth$ = abs(zr$ + depth$)
