Welcome to eMastercam.com
MasterCam X6, I can not build a chain
  • Please log in to reply
9 replies to this topic
#1
pevek80
pevek80
    Newbie
  • Members
  • Pip
  • 9 posts
I can not build a chain for the new model. But if I use the old file from the MC X4, I can build a chain.
Why?
See the video.
Sorry my english!
#2
pip
pip
    Advanced Member
  • Members
  • PipPipPip
  • 1,204 posts
You have no chain to select. It is a solid. Use solid selection to chain it. Or draw new chain around the solid.
#3
SledGeek
SledGeek
    Advanced Member
  • eMC Learning Group
  • PipPipPip
  • 620 posts
Create /curve/curve on all edges.....select your solid or surfaces. This will create your wireframe on the whole part. You can also use "Curve on one edge" and select just the edges you want instead of the whole part.
#4
pevek80
pevek80
    Newbie
  • Members
  • Pip
  • 9 posts
Thank you!
Why I can to built the chain for "Old_sample"? What are the differences between the two files ( "Old_sample" and "Sample").
When I used the MC X4 I did not have such problems.
#5
SledGeek
SledGeek
    Advanced Member
  • PipPipPip
  • 620 posts
I couldn't see the video. It sounds like you are importing a file that is getting wireframe in X4, but no wireframe in X6.
Are you importing these models from a different format....iges, step,sldprt etc ?
If you are, then go to your configuration in X6 and look under converters. See if the "edge curves" button is checked. It migh be checked in X4 but not in X6
Also, use your screen/ statistics drop down to seen exactly what entities are on your screen.....
#6
Jay Kramer @ Precision Programming
    Advanced Member
  • Moderators
  • 4,447 posts
Review picture.
#7
pevek80
pevek80
    Newbie
  • Members
  • Pip
  • 9 posts
If you are, then go to your configuration in X6 and look under converters. .
Yes! Thank you very much!
I changed the settings and it works!
  • Attached File  222.jpg   133.32KB   21 downloads
#8
    Advanced Member
  • Moderators
  • 4,447 posts
You do not have to make wire on model why not use solid selection and pick the solid edges.
#9
SledGeek
SledGeek
    Advanced Member
  • PipPipPip
  • 620 posts
pevek, I typically do what Jay is saying whenever possible , too. Just bring in your solid and you can add wireframe for just what you need for boundaries or whatever. Bringing in a model with all the wireframe just adds to file size when you don't always need it for machining. Use the solids chaining option in your toolpaths....quick and easy.
#10
pevek80
pevek80
    Newbie
  • Members
  • Pip
  • 9 posts
Thank you all again!
I will accept your advices.
