Transform C-axis Contour Toolpaths
Below is an example of proper code for transforming a C-axis Contour toolpath. (no Y-axis).
The text in blue is what I had to add.
I have tried this with MPLFAN, & MPLMASTER, and i get the same results.
The posts I have tested are for Fanuc and Okuma Controls.
When I try to do this same thing using Y-axis, the output is perfect.
N1(INTERPOLATE HOLES)
M67
G28 U0. W0. H0.
T0303(.75 SOLID CARBIDE EMILL W/.032 RAD.)
M93 (CHIP CONVEYOR ON)
G54 G98 M68
G0 C0.
G0 Z2.
X7.
G97 S2500 M24
G12.1
G1 X7. C0. F500.
Z.25
Z0. F100.
X7.375 F40.
X7.75
G3 X6.25 Z-.05 R.375
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
Z2. F500.
(INTERPOLATE HOLES)
G13.1
G0 C90. X7.0
Z.25
G12.1
G1 Z0. F100.
X7.375 F40.
X7.75
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
Z2. F500.
(INTERPOLATE HOLES)
G13.1
G0 C180. X7.0
Z.25
G12.1
G1 Z0. F100.
X7.375 F40.
X7.75
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
Z2. F500.
(INTERPOLATE HOLES)
G13.1
G0 C270. X7.0
Z.25
G12.1
G1 Z0. F100.
X7.375 F40.
X7.75
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
Z2. F500.
G13.1
G28 U0. M05 M25
G28 W0. M95 (CHIP CONVEYOR OFF)
M66
Below is what my post actually outputs. (no Y-axis).
The text in red is where the post seems to reset C-axis to zero each time.(from what i gather in the debugger).
M67
G28 U0. W0. H0.
G54 G98 M68
G0 C0.
G0 Z2.
X7.
G97 S2500 M24
G12.1
G1 X7. C0. F500.
Z.25
Z0. F100.
X7.375 F40.
X7.75
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
Z2. F500.
(INTERPOLATE HOLES)
F500.
F500.
Z.25
Z0. F100.
X7.375 F40.
X7.75
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
Z2. F500.
(INTERPOLATE HOLES)
F500.
F500.
Z.25
Z0. F100.
X7.375 F40.
X7.75
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
Z2. F500.
(INTERPOLATE HOLES)
F500.
F500.
Z.25
Z0. F100.
X7.375 F40.
X7.75
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
Z2. F500.
G13.1
G28 U0. M05 M25
M66
If i were to chain all 4 holes and not use Transform, the code would be correct like below.
The problem is, I want my operator to be able to read the code, & this is much easier if the C-axis is rotated between each location and basically the same program is run again.
Also this is just an extrememly simple example to be able to read the code easier.
M67
G28 U0. W0. H0.
G54 G98 M68
G0 C0.
G0 Z2.
X7.
G97 S2500 M24
G12.1
G1 X7. C0. F500.
Z.25
Z0. F100.
X7.375 F40.
X7.75
X7.75 Z-.1 R.375
X6.25 Z-.15 R.375
X7.75 Z-.2 R.375
X6.25 Z-.25 R.375
X7.75 Z-.3 R.375
X6.25 Z-.35 R.375
X7.75 Z-.4 R.375
X6.25 Z-.45 R.375
X7.75 Z-.5 R.375
X6.25 Z-.55 R.375
X7.75 Z-.6 R.375
X6.25 Z-.65 R.375
X7.75 Z-.7 R.375
X6.25 Z-.75 R.375
X7.75 Z-.8 R.375
X6.25 Z-.85 R.375
X7.75 Z-.9 R.375
X6.25 Z-.95 R.375
X7.75 Z-1. R.375
X6.25 R.375 F4.
X7.75 R.375
G1 X7.
Z.25 F500.
X0. C3.5 F500.
Z0. F100.
X.375 F40.
X.75
G3 X-.75 Z-.05 R.375
X.75 Z-.1 R.375
X-.75 Z-.15 R.375
X.75 Z-.2 R.375
X-.75 Z-.25 R.375
X.75 Z-.3 R.375
X-.75 Z-.35 R.375
X.75 Z-.4 R.375
X-.75 Z-.45 R.375
X.75 Z-.5 R.375
X-.75 Z-.55 R.375
X.75 Z-.6 R.375
X-.75 Z-.65 R.375
X.75 Z-.7 R.375
X-.75 Z-.75 R.375
X.75 Z-.8 R.375
X-.75 Z-.85 R.375
X.75 Z-.9 R.375
X-.75 Z-.95 R.375
X.75 Z-1. R.375
X-.75 R.375 F4.
X.75 R.375
G1 X0.
Z.25 F500.
X-7. C0. F500.
Z0. F100.
X-6.625 F40.
X-6.25
G3 X-7.75 Z-.05 R.375
X-6.25 Z-.1 R.375
X-7.75 Z-.15 R.375
X-6.25 Z-.2 R.375
X-7.75 Z-.25 R.375
X-6.25 Z-.3 R.375
X-7.75 Z-.35 R.375
X-6.25 Z-.4 R.375
X-7.75 Z-.45 R.375
X-6.25 Z-.5 R.375
X-7.75 Z-.55 R.375
X-6.25 Z-.6 R.375
X-7.75 Z-.65 R.375
X-6.25 Z-.7 R.375
X-7.75 Z-.75 R.375
X-6.25 Z-.8 R.375
X-7.75 Z-.85 R.375
X-6.25 Z-.9 R.375
X-7.75 Z-.95 R.375
X-6.25 Z-1. R.375
X-7.75 R.375 F4.
X-6.25 R.375
G1 X-7.
Z.25 F500.
X0. C-3.5 F500.
Z0. F100.
X.375 F40.
X.75
X.75 Z-.1 R.375
X-.75 Z-.15 R.375
X.75 Z-.2 R.375
X-.75 Z-.25 R.375
X.75 Z-.3 R.375
X-.75 Z-.35 R.375
X.75 Z-.4 R.375
X-.75 Z-.45 R.375
X.75 Z-.5 R.375
X-.75 Z-.55 R.375
X.75 Z-.6 R.375
X-.75 Z-.65 R.375
X.75 Z-.7 R.375
X-.75 Z-.75 R.375
X.75 Z-.8 R.375
X-.75 Z-.85 R.375
X.75 Z-.9 R.375
X-.75 Z-.95 R.375
X.75 Z-1. R.375
X-.75 R.375 F4.
X.75 R.375
G1 X0.
Z.25 F500.
Z2. F500.
G13.1
G28 U0. M05 M25
M66
2 of my lathes here do not have Y-axis, and I do this type of operation almost daily.
I have searched through this forum and have not seen anyone make mention of this issue.
So I always thought that I was doing something wrong.
Anybody else come across this?
