Adding safety line at tool change?
Hi,
We has a Haas and I am using MPmaster post.. I need to add this safety line before every tool change G00 G17 G20 G40 G80 G49 G90.. Where is the safest place to add this in the post?
(OVERALL MAX - Z1.)
(OVERALL MIN - Z-4.375)
N110 G00 G17 G20 G40 G80 G49 G90 <----------------------------- Need this line posted on very tool change --------------------->
N120 G91 G28 Z0.
N130 (ROUGH MILLS EXTRA MATERIAL WITH 1 1/2 ROUGHING ENDMILL)
N140 (COMPENSATION TYPE - WEAR COMP)
N150 T2 M06 (1 1/2 HSS ROUGHING ENDMILL)
N160 (MAX - Z1.)
N170 (MIN - Z-4.375)
N180 M08
N190 G00 G17 G90 G54 X10.9625 Y2.9855 S800 M03
N200 G43 H2 Z1. T3
N210 Z.25
N220 G94 G01 Z-4.375 F50.
N230 G41 D2 Y2.1105 F15.
N240 Y-2.1105
N250 G40 Y-2.9855
N260 G00 Z1.
N270 X10.4 Y2.9855
N280 Z.25
N290 G01 Z-4.375 F50.
N300 G41 D2 Y2.1105 F15.
N310 Y-2.1105
N320 G40 Y-2.9855
N330 G00 Z1.
N340 M09
N350 M05
N360 G91 G28 Z0.
N370 M01
N380 (FINISH MILLS PART TO 9.610 LENGTH WITH 1 1/4 ENDMILL)
N390 (COMPENSATION TYPE - WEAR COMP)
N391 <------------------------------------------------------------------------------------- need it to post here -------------------------------->
N400 T3 M06 (1 1/4 HSS ENDMILL)
N410 (MAX - Z1.)
N420 (MIN - Z-4.375)
N430 M08
N440 G00 G17 G90 G54 X10.241 Y2.8397 S900 M03
ptlchg_com	  #Tool change common blocks
  if force_output | sof,
    result = force(ipr_type,ipr_type)
    result = force(absinc$,absinc$)
    result = force(plane$,plane$)
  pcom_moveb
  pcheckaxis	  #Check for valid rotary axis
  #ptoolcomment
  if sof & scomm_sav <> snull,
    spaces$ = 0
    n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
    spaces$ = sav_spc
  if sof = 0, scomm_sav = snull
  comment$
  pcomment3
  pmisccheck
  pcan
  pbld, n$, *sgcode, *sgplane, *smetric, "G40 G80 G49",  *sgabsinc, e$  #<<<<<<<<<<<<<<<<<<<<<<<<<
  if stagetool >= zero,
    if omitseq$ = 1 & tseqno > 0,
	  if tseqno = 2, n$ = t$
	  pbld, *n$, *t$, "M06", ptoolcomm, e$
    else, pbld, n$, *t$, "M06", ptoolcomm, e$
 pcom_moveb
 #ptoolcomment
 spaces$ = 0
 spaces$ = sav_spc
 comment$
 pcomment3
 pmisccheck
 pcan
Perfect thanks...
:smoke:
That line should be posted at the top of the file already.. (looks like I was a bit too slow now that I posted it .. lol someone beat me to it lol)
The only difference with this one is if you only output sequence numbers for each tool it will put the sequence number out so you still get the cancel codes when you go to that N number line fopr the tool..
The simplest way to do this is you could add it in ptlchg_com,
by changing this bit
to look like this..
		 if tseqno = 2,
		 n$ = t$
			 pbld, *n$, *sgplane, *sgmetric, "G40 G80 G49", *sgabsinc, e$
			 pbld, n$, *t$, "M06",ptoolcomm,e$
		 else,
	 pbld, n$, *sgplane, *sgmetric, "G40 G80 G49", *sgabsinc, e$
