Puma 2500ttsy need to change x+ to x-
  • 10 months later...
Note: changing the dia_mult from 2 to -2 in the post could cause you problems later on depending on what you are machining. The post has switches just for that as you will see bellow.
For changing the sign, save a copy of your post, look for this section and edit the section you need. for (X plane 0 is the letter I) and (X plane 1 is the letter L) and (X plane 2 is the letter O) I would only change one at a time and test. Note: make sure you count toe places for each letter because the editor could have shifted the the spaces. I would test each turret and spindle with some simple toolpaths to setup your post. Its a little work up front but a lot of time saved down the road.
#Machining position turret/spindle settings
# Switch strings based on turret position top/bottom-left/right and cut type.
# Turret position is based on the Mastercam settings (see lathtype).
# Strings are re-assigned for output in the routine psw_str_mult.
# The string variable sw_string holds the place position value to determine
# how to assign the strings. Planes are relative to the view from Mastercam.
# Assign the 17 digit string following the alpha columns below:
# A - C axis, 1 = axis winds, 2 = axis signed, 3 = indexer, 4 = shortest direction
# B - Spindle direction, 0 = normal, 1 = reverse
# C - Plane 0 arc/comp, 0 = normal, 1 = switch
# D - Plane 1 arc/comp, 0 = normal, 1 = switch
# E - Plane 2 arc/comp, 0 = normal, 1 = switch
# F - Plane 0, 0 = G17, 1 = G19, 2 = G18
# G - Plane 1, 0 = G17, 1 = G19, 2 = G18
# H - Plane 2, 0 = G17, 1 = G19, 2 = G18
# Decimal (required)
# I - Plane 0, X axis, 0 = normal, 1 = switch sign from basic
# J - Plane 0, Y axis, 0 = normal, 1 = switch sign from basic
# K - Plane 0, Z axis, 0 = normal, 1 = switch sign from basic
# L - Plane 1, X axis, 0 = normal, 1 = switch sign from basic
# M - Plane 1, Y axis, 0 = normal, 1 = switch sign from basic
# N - Plane 1, Z axis, 0 = normal, 1 = switch sign from basic
# O - Plane 2, X axis, 0 = normal, 1 = switch sign from basic
# P - Plane 2, Y axis, 0 = normal, 1 = switch sign from basic
# Q - Plane 2, Z axis, 0 = normal, 1 = switch sign from basic
use_only_tl : 1 #Use only Top turret/Left spindle settings (below) for
#all Mastercam turret/spindle selections
#When configuring for multi-spindle/turret set to 0
#Columns- ABCDEFGH.IJKLMNOPQ #Turret/Spindle #Path Type
scase_tl_c1 : "10000222.000000000" #Top turret/Left spindle, Turning cut
scase_tl_c2 : "11000012.000000000" #Top turret/Left spindle, Right Face cut
scase_tl_c_2 : "11110012.000000000" #Top turret/Left spindle, Left Face cut
scase_tl_c3 : "10010102.000000000" #Top turret/Left spindle, Cross cut
scase_tl_c4c : "10000111.000000000" #Top turret/Left spindle, Y axis subs. Cycle
scase_tl_c4 : "10000222.000000000" #Top turret/Left spindle, Y axis subs.
scase_tl_c5 : "10000222.000000000" #Top turret/Left spindle, Multisurf Rotary
scase_bl_c1 : "10000222.000000000" #Bottom turret/Left spindle, Turning cut
scase_bl_c2 : "11000012.000000000" #Bottom turret/Left spindle, Right Face cut
scase_bl_c_2 : "11110012.000000000" #Bottom turret/Left spindle, Left Face cut
scase_bl_c3 : "10010102.000000000" #Bottom turret/Left spindle, Cross cut
scase_bl_c4c : "10000111.000000000" #Bottom turret/Left spindle, Y axis subs. Cycle
scase_bl_c4 : "10000222.000000000" #Bottom turret/Left spindle, Y axis subs.
scase_bl_c5 : "10000222.000000000" #Bottom turret/Left spindle, Multisurf Rotary
scase_tr_c1 : "10000222.000000000" #Top turret/Right spindle, Turning cut
scase_tr_c2 : "11000012.000000000" #Top turret/Right spindle, Right Face cut
scase_tr_c_2 : "11110012.000000000" #Top turret/Right spindle, Left Face cut
scase_tr_c3 : "10010102.000000000" #Top turret/Right spindle, Cross cut
scase_tr_c4c : "10000111.000000000" #Top turret/Right spindle, Y axis subs. Cycle
scase_tr_c4 : "10000222.000000000" #Top turret/Right spindle, Y axis subs.
scase_tr_c5 : "10000222.000000000" #Top turret/Right spindle, Multisurf Rotary
scase_br_c1 : "10000222.000000000" #Bottom turret/Right spindle, Turning cut
scase_br_c2 : "11000012.000000000" #Bottom turret/Right spindle, Right Face cut
scase_br_c_2 : "11110012.000000000" #Bottom turret/Right spindle, Right Face cut
scase_br_c3 : "10010102.000000000" #Bottom turret/Right spindle, Cross cut
scase_br_c4c : "10000111.000000000" #Bottom turret/Right spindle, Y axis subs. Cycle
scase_br_c4 : "10000222.000000000" #Bottom turret/Right spindle, Y axis subs.
scase_br_c5 : "10000222.000000000" #Bottom turret/Right spindle, Multisurf Rotary
For change the approach and retract change the following in (ltlchg$, mtlchg$, and pl_retract, pm_retract )
For the approach
Change from this,
pcan1, pbld, n$, psccomp, *sgcode, pwcs, pfxout, pyout, pfzout,
pscool, strcantext, e$
Change to this,
pcan1, pbld, n$, psccomp, *sgcode, pwcs, pfzout, pscool, strcantext, e$
pfxout, pyout, e$
For the retract
Change from this,
pcan1, pbld, n$, *sgcode, pfxout, pfyout, pfzout, *toolno, e$
Change to this,
pcan1, pbld, n$, *sgcode, pfxout, pfyout, *toolno, e$
pcan1, pbld, n$, pfzout, e$
Hope this helps you out.
