Haas tool stage
I am using MPMASTER post V15.00. I understand about enabling staging in control and post. This is what gets posted
N60
G00 G90 G54 X4.125 Y.125 S10000 M03
N70
G43 H40 Z1.125 M08 T39
N80
Z1.1
but the machine needs
N60
N70
G43 H40 Z1.125 M08
T39 This is on it's own line
N80
Z1.1
When I move the tool down one line machine runs fine
Thank you
phsm1_on #must remain before G43
pbld, n$, *tlngno$, pfzout, scoolant, next_tool$, e$
pcan2 #Added so M and G codes in canned text will output before phsm2_on
phsm2_on #must remain after G43
sav_coolant = coolant$
change to:
pbld, n$, *tlngno$, pfzout, scoolant, e$
next_tool$, e$
or something like that
Thank you for all the help. Sorry it took a while to respond. You pointed me in the right direction and here is what I ended up with. I added the n$ and the e$ so I could get the line numbers to show up. Once again thank you
Brian Ripley
pstop
# Stop routine
pretract
pcom_moveb
if
mi10$=one, n$, *sm00, e$
sav_absinc
= absinc$
if wcstype
> one, absinc$ = zero
if lock_codes
= 1 & not(index) & rot_on_x, pbld, n$, *sunlock, "(UNLOCK)", e$
pcan1, pbld,
n$, *sgcode, *sgabsinc, pwcs, pfxout, pfyout,
pfcout,
*speed, *spindle, pgear, strcantext, e$
if lock_codes
= 1 & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, "(LOCK)", e$
pbld,
n$, "G43", *tlngno$, pfzout, scoolant, e$
n$, next_tool$, e$ #(change here move from line above)
sav_coolant
= coolant$
if
coolant$ = 1, sm09 = sm09_0
if
coolant$ = 2, sm09 = sm09_1
if
coolant$ = 3, sm09 = sm09_2
absinc$ = sav_absinc
And I change it here also
ptlchg_com
#Tool change common blocks
pcom_moveb
#ptoolcomment
comment$
pcan
if
plane$ < 0, plane$ = 0
if stagetool
>= zero, pbld, n$, *t$, "M06", ptoolcomm, e$
spaces$=0
if output_z
= yes$,
preadbuf5
if (
opcode$ > 0 & opcode$ < 16) | opcode$ = 19,
n$, pspc, "(", "MAX - ", *max_depth, ")", e$
n$, pspc, "(", "MIN - ", *min_depth, ")", e$
spaces$=sav_spc
pstock
pindex
sav_absinc
= absinc$
if wcstype
> one, absinc$ = zero
if lock_codes
pcan1, pbld,
pfcout,
if lock_codes
pbld,
sav_coolant
= coolant$
if
if
if
pcom_movea
toolchng
= zero
c_msng$ #Single tool subprogram call
last_op_id
= op_id$
last_cuttype
= cuttype
I don't know what the difference is. We have a 2008 VF6 that I use to run in a different part of the plant and had know problems. But this is a 2007 VFE with pallet changer. When the prestage tool is called out on the G43 line I get a "TT or unknown axis error". We run this with the H and T in agreement so I don't know if that has anything to do with it.
