okuma p200 post
Hi,
Here is output from post for Okuma OSP P200 by "CNC Softwhare"
"(T1 - AL 3/16 FLAT ENDMILL - H1)
N20 G20
N22 G90 G80 G40 G0
N24 G114 T1
N26 (T1 - AL 3/16 FLAT ENDMILL - TOOL DIA. - .1875)
N28 Call OO88 PA=0. PH=1 PP=51"
Can sombody explane
G114 T1-- this is must be some .SSB/.LIB program call , but what program ?
OO88 also subprogram call -what this subprogram do and what parameters PA, PH=1, PP=51?
Thank you in advance
G114 is a probably a tool change macro
On our new MU10000, the correct number is G116... you can also use a conventional M6
but the control is very picky about whether the tool is already in spindle
or the proper tool is staged or not staged. The logic in our G116 macro solves those problems.
CALL 0088 is a coordinate rotation macro that comps the program if the part is not centered on the rotary axis
It works for 5 axis machines as well
hello,
look in the post for this
fixtrack : 1 #Fixture Offset Tracking switch variable (Call OO88)
change to 0 to remove that from the code
also change this to 1
tool_chg_str : 0 #Used to configure start of file toolchange output
#0 = Use G116 T#
#1 = Output Tool Spindle Check (VTLCN check)
Hi Mig,
You need to look through the post and check the variable switches at the top of the post. If you don't have the Toolchange Macro on your control, then use the "Tool Spindle Check" option. (Set 'tool_chg_str' to '1').
This post has many different configuration options, based on how you like to setup and run your machine.
For example, the Fixture Offset Tracking (Call OO88) can be enabled or disabled with a switch in your post.
Please read the information at the top of the post file header section, and use that information to setup your post.
