MPMASTER
1.Is it possible to add to the post, if the size of the NC file more than 300kb ,writes the serial number in the tool change ? I need it to search a tool when working with flash cards
2. How to disable the G94 in MPMASTER&
N1 T271 M06 (75 FACE MILL)
T219(MAX Z5.| MIN Z0.)
G00 G17 G90 G54 X-95.339 Y.093 S2000 M03
G43 H271 Z5.
M08
G94 G01 Z0. F1000.
X93.261
G00 Z5.
M09
M05
G91 G28 Z0.
M01
N2 T219 M06 (10. FLAT ENDMILL)
T213(MAX Z5.| MIN Z-6.2)
G00 G17 G90 G54 X-10.539 Y54.093 S6500 M03
G43 H219 Z5.
if smaller 300kb
G43 H271 Z5.
M08
G94 G01 Z0. F1000.
X93.261
G00 Z5.
M09
M05
G91 G28 Z0.
M01
G43 H219 Z5.
M08
G94 G01 Z-3.1 F1200.
There is no easy way to evaluate the size of the NC file inside the post. The way that I would adress this issue is with a fq statement. This will popup a question for the programmer when he runs the post, asking if N numbers should be output or not.
My question for you is: Why only on files larger than 300k? It hurts nothing for them to be there on all files, even if you don't use them in the smaller files.
More than 300 kb I wrote for example, in fanuc 0mc memory of 256 kb and so we have to work with flash cards, to search for the tool in the program have to write N there is a search Nsrh
With first question - I understand, but how to be with second question - shutdown G94
The easiest way to remove the G94:
Change this:
# Feed mode G code selection
sg94 : "G94"	 #UPM
sg94d : "G94"	 #DPM, See pfcalc_deg if you use another gcode
sg93 : "G93"	 #Inverse
sg95 : "G95"	 #UPR	 #set with mi6$
sgfeed : ""		 #Target for string
fstrsel sg94 ipr_type sgfeed 4 -1
To this:
sg94 : ""	 #UPM
sg94d : ""	 #DPM, See pfcalc_deg if you use another gcode
