err when posting
can anyone tell me what is causing the err message when i post this one job below is the err code.
28 Jun 2013 07:15:40 AM - <0> - Report created.
28 Jun 2013 07:15:40 AM - <2> - Initialize posting log file
28 Jun 2013 07:15:40 AM - <2> - Using MP run version 15.00 and post components version 15.00
28 Jun 2013 07:15:40 AM - <2> - Initiate opening the post processor file(s).
28 Jun 2013 07:15:40 AM - <2> - C:\DOCUMENTS AND SETTINGS\ALL USERS\DOCUMENTS\SHARED MCAMX6\MILL\POSTS\MIKRON_HSM_600U.PST
28 Jun 2013 07:15:40 AM - <2> - An encrypted post file is associated with the post file.
28 Jun 2013 07:15:40 AM - <2> - Post processor file name: C:\DOCUMENTS AND SETTINGS\ALL USERS\DOCUMENTS\SHARED MCAMX6\MILL\POSTS\MIKRON_HSM_600U.PSB
28 Jun 2013 07:15:40 AM - <2> - The post processor file has finished the read process.
28 Jun 2013 07:15:40 AM - <2> - Post version information (input):
28 Jun 2013 07:15:40 AM - <2> - UPDATEPOST Version 15. was used to modify this file.
28 Jun 2013 07:15:40 AM - <2> - The file was modified by this product on 10 Apr 12 09:29:34
28 Jun 2013 07:15:40 AM - <2> - The post was written to run with Mastercam Version 15.
28 Jun 2013 07:15:40 AM - <2> - The post product type is Mill.
28 Jun 2013 07:15:40 AM - <2> - Initialization of pre-defined post variables, strings, postblocks was successful.
28 Jun 2013 07:15:40 AM - <2> - Search for defined post variables, strings, postblocks was successful.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'met_mtol$' was re-initialized from 0.000001 to 0.001
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'met_ltol$' was re-initialized from 0.002 to 0.01
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'error_msg$' was re-initialized from 1. to 0.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'err_file$' was re-initialized from 1. to 0.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'dec_seq_right$' was re-initialized from 3. to 0.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'dec_seq_left$' was re-initialized from 3. to 0.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'rotfeed4$' was re-initialized from 2. to 1.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'rotfeed5$' was re-initialized from 3. to 1.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'lrotfeed4$' was re-initialized from 2. to 1.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'lrotfeed5$' was re-initialized from 0. to 1.
28 Jun 2013 07:15:44 AM - <2> - CONTROL DEFINITION - Post variable 'peckacel$' was re-initialized from 0. to 1.
28 Jun 2013 07:15:44 AM - <2> - RUN TIME - PST(2644,2644), NCI(6618) - The formula is attempting to divide by zero
28 Jun 2013 07:15:44 AM - <2> - RUN TIME (QUESTION) Enter Z Shift (Base of Pallet to Z Zero)? - OPERATION 6 NCI LINE 154.
28 Jun 2013 07:15:44 AM - <2> - RUN TIME (RESPONSE) 9.4 - OPERATION 6 NCI LINE 154.
28 Jun 2013 07:15:44 AM - <2> - Successful completion of posting process!
  • 1 month later...
28 Jun 2013 07:15:44 AM - <2> - RUN TIME - PST(2644,2644), NCI(6618) - The formula is attempting to divide by zero #<----------- Post line 2644
  • 4 years later...
Here is the issue I am having with a 4th axis post that worked flawlessly in V8, and after doing update post to X8 it does this:
Report created.
 Using MP run version 17.00 and post components version 17.00
 U:\SHARED MCAMX8\MILL\POSTS\XXXXXXXXX.PST
 The post processor file has been successfully opened.
 UPDATEPOST Version 17. was used to modify this file.
 The post was written to run with Mastercam Version 17.
 CONTROL DEFINITION - Post variable 'met_ltol$' was re-initialized from 0. to 0.
 CONTROL DEFINITION - Post variable 'dec_seq_right$' was re-initialized from 0. to 0.
 CONTROL DEFINITION - Post variable 'lrotfeed5$' was re-initialized from 0. to 0.
 CONTROL DEFINITION - Post variable 'peckacel$' was re-initialized from 0. to 0.
 RUN TIME -OPID(44)- Only single-axis rotation is allowed!  Angles may be incorrect.
And all code is mirror image about the x axis.
You  have an incorrect plane.....
You'll have to dig through and figure out which....typically saw this when someone uses either Back or Bottom as a plane and the X goes in the wrong direction
In V8 we were creating the planes and numbering them for 4th axis. With X8 we used BACK. Every other time I have done 4th, or even 5 axis programing, I start with TOP, then rotate thru to the next plane, be it BACK, BOTTOM, etc. Never had these errors with other posts for that type of programming in the past. I don't have access to those posts anymore, as that was at a different shop.
Is this a control def setting I need to fix, or a post issue itself?
This isn't a Post or a Control Definition issue. It is simply an incorrect Tool Plane being used in your program. When you program for a 4th Axis, you must pick a single axis of rotation, and the Vector Component of that axis must not change. When programming for a 4th Axis, that is a Vertical machine, you must create "new" planes for Back and Bottom. Both the 'Back' and 'Bottom' Planes in Mastercam have their X+ Axis direction "reversed" from the Top Plane X+ direction.
Correct the Planes settings in your Mastercam Operations, and the error messages will stop.
And yes, if you use a "Reversed" Plane, the NC Code itself will be mirrored, and will scrap the part...
