To all,
I have visited this form many times learning a lot about editing my post and a few dif things However I am stumped now.
I Have programmed with mastercam for over 20 yrs and our latest version of MC is X3 because my boss wont let me upgrade to the newest ver but we really dont need it cause what we have works and have not bought a new machine in yrs until a few months ago. We bought a new Haas VF3 and I know there is a lot of ppl out there that dont like them but I love it for now. Anyway to my point, I have a good working post and have been moding it to fit my needs. I added a custom drill cycle to peck tap and Have got that to work how I like but I also want to add a Programmable stop so I dont have to manually edit the Program every time. Right now I just do a normal drill cycle in the location I want my stop to get this code:
G0 G17 G40 G49 G80 G90
( 3/8 DOWELL | )
T19 M6
G0 G90 G54 X-1.3939 Y.1561 S0 M5
G43 H19 Z2.
G98 G81 Z-.5 R0. F110.
G80
M5
G91 G28 Z0.
Then I edit it to look like this:
( 3/8 DOWELL | )
T19 M6
G43 H19 Z2.
G1 Z-.5 F110.
M00
G91 G28 Z0.
How can I add a custom drill cycle to post out what I edit?
Like I said before I did add a peck tap cycle to the post like this:
pdrlcst$ #Custom drill cycles 8 - 19 (user option)
if drillcyc$ = 9,
numpeck = peck2$,
peck_cnt = numpeck
initial_calc = (depth$ - tosz$) / peck_cnt
strt_depth = (tosz$ + initial_calc)
calc_depth = (depth$ - tosz$)
calc_peck = calc_depth / numpeck
#"(PECK tapping CYCLE)", e$
pcan1, pbld, n$, *sgdrlref, *sg84, pdrlxy, *strt_depth, pcout, prdrlout, *feed, strcantext, e$
count = peck_cnt
pass = 1
WHILE count > 1,
sub_depth = strt_depth + (calc_peck * pass)
pbld, n$, *sg84, *sub_depth, *refht_a, e$
pass = pass + 1
count = count - 1
#pbld, n$, sg84, pfzout, *refht_a, e$
pcom_movea
and it works like I want thanks to the sample of John Paris post I just had to change a little to get to work for me.
My question is what would I use to output the code I need as shown above in my edited code, also where and how would I add it to the PST file to still use my peck tap
and also a stop under the custom drill cycle section? Any Ideas?
Brian Pugh
Mastercam x3
Yes I want it to post M00 every time but I want it for a part stop not for my tapping cycle, I just put that in my last form post showing what I have now as my first custom drill cycle and how do I add a 2nd custom drill cycle to that and still have both to work, I need something to post out a code that looks like this:
( 3/8 DOWELL | )
T19 M6
G43 H19 Z2.
G1 Z-.5 F110.
M00
G91 G28 Z0.
I use a 3/8 Dowel pin to come down ( not turning) and stop at my zero location, I put the part against the dowel, tighten vise and press cycle start that the z rapids up to start the next tool.
Brian
mastercam x3 (yes its old)
Haas VF3 2013
I have modified my post to 'read' the tool description. If I identify a tool as a dowel, the post will not output a speed or M3 command, and will output a M0 when depth is reached.
This is more work on the post side, but after the logic is in place, it makes the desired output very easy.
That is something like I am looking to do. I could do what FNMI said but then I would have to use one of my canned cycles and mod one of those but I was really hoping to use a custom cycle. Could you show me some examples of your post that looks for a dowel?
sdr08 : "1/4 dowel stop" # " "
[drill cycle 10]
1. "Dowel Pin Stop"
2. ""
3. ""
4. ""
5. ""
6. ""
7. ""
8. ""
9. ""
10. ""
11. ""
#Use this postblock to customize drilling cycles 8 - 19
pdrlcommonb
if drillcyc$ = 8,
sub_prg_call = peck1$
pcan1, pbld, n$, *sg00, *sgabsinc, pfxout, pfyout, pfcout, pindexdrl, strcantext, e$
pbld, n$, "M98", *sub_prg_call, e$
else,
##"CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, pindexdrl, e$
pcan1, pbld, n$, *sg01, pdrlxy, pfzout, pcout, pindexdrl, *feed, strcantext, e$
pbld, n$, "M00", scomm_str, "MOVE PART TO STOP", scomm_end, e$
pcom_movea
this will set up a drill cycle to use for dowel stop, which results in the code snipet below:
O0000 (OP-1)
(TIME - 07:05)
(T1 - 1/4 DOWELL PIN )
(WCS NAME - TOP)
G00 G17 G40 G80 G90
T1 M06 ( 1/4 DOWELL PIN )
(MAX - Z1.)
(MIN - Z-.5)
G00 G17 G90 G54 X0. Y0.
G43 H1 Z1.
G94
G01 Z-.5 F14.67
M00 ( MOVE PART TO STOP )
G91 G28 Z0.
G0 G90 G154 P20 X0 Y0
First, you need to define a variable to hold an integer, like this:
fmt	 4 dowelchk	 #Check for "DOWEL" in comment
Next, define the string that you want to look for:
sdowelchk : "DOWEL"
Add this to pcomment$:
pcomment$	 #Comment from manual entry
 scomm$ = ucase (scomm$)
 dowelchk = strstr (sdowelchk, scomm$)
Now, in pdrill$:
pdrill$		 #Canned Drill Cycle
 if dowelchk <> 0,
	 # Insert Code For Dowel Pin
	 dowelchk = 0
 else,
	 # Normal Drill Code Here
This will give you the output that you want.
Ex-programmer I see the concept and how your code should work and I like how it can be use for so many dif things but for some reason I cant get it to work for me I have put DOWEL in every comment place there is with nothing, now I'm not 100% what the code should be to have the dowel come down and stop but I used a combo of a few suggestions above and no joy, it just posts out a normal G81 drill cycle.
When I am troubleshooting a new section of my post, I force the status of the non-working variables to be output at each stage of calculation. For example, if I did not get the expected results from the variable dowelchk, I would temporarily insert this line to see the real status of the variable at that point of the post:
 "(postblock pdrill$, dowelchk =", *dowelchk, ")", e$
If the variable is not the expected value, then insert this code at every location that the variable is manipulated, and you will find the error somewhere.
  • 2 years later...
OK I know this is a bit old but I am revisiting this because last time I could never get this to work. I got busy and kind of forgot about it but now I could really use it again so maybe I can understand how to edit my post to get it to work if someone would be so kind to explain it or show an example that I can just cut and paste. What I want to do is have a programmable stop where  I can get this code to  post out
( 3/8 DOWELL | )
T19 M6
G43 H19 Z2.
G1 Z-.5 F110.
M00
G91 G28 Z0.
 Here is the drill part of my post now ( the part about dowel I added but could not get to work):
# Drilling
pdrill0$         #Pre-process before drill call
      sav_dgcode = gcode$ #Capture gcode for 5 axis drill
pdrlcommonb     #Canned Drill Cycle common call, before
      if initht$ <> refht$, drillref = zero
      else, drillref = one
      if sav_dgcode = 81,
        result = newfs(two, zinc)
        if drillcyc$ = three | drillcyc$ = 7, drlgsel = fsg1(-ss$) + drillcyc$ * two
        else, drlgsel = fsg2(dwell$) + drillcyc$ * two
        prv_refht_a = c9k
        prv_refht_i = c9k
        prv_dwell$ = zero
        prv_shftdrl$ = zero
      if cuttype = three, sav_dgcode = gcode$
      else, z$ = depth$
      if cuttype = one, prv_zia = initht$ + (rotdia$/two)
      else, prv_zia = initht$
      pcom_moveb
      feed = fr_pos$
      comment$
      pcan
      #5 axis must map the true Z, correct Z calculation here
      if cuttype = three,
        prv_zia = zabs + (-depth$) + initht$
        zia = fmtrnd(zabs)
        zinc = zia - prv_zia
prdrlout        #R drill position
      if cuttype = one, refht_a = refht$ + (rotdia$ / two)
      else, refht_a = refht$
      refht_i = refht$ - initht$
      if cuttype = three, refht_a = w$
      if absinc$ = zero, refht_a, !refht_i
      else, refht_i, !refht_a
      pdrlcommonb
    if dowelchk <> 0,
               pcan1, pbld, n$, "M00",  e$,  # Insert Code For Dowel Pin
                 dowelchk = 0
         else,
            pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
        prdrlout, dwell$, *feed, strcantext, e$
      pcom_movea
ppeck$           #Canned Peck Drill Cycle
      pdrlcommonb
        prdrlout, *peck1$, *feed, strcantext, e$
      pcom_movea
pchpbrk$         #Canned Chip Break Cycle
      pdrlcommonb
      pcom_movea
ptap$            #Canned Tap Cycle
      pdrlcommonb
      pcom_movea
pbore1$          #Canned Bore #1 Cycle
      pdrlcommonb
      pcom_movea
pbore2$          #Canned Bore #2 Cycle
      pdrlcommonb
      pcom_movea
pmisc1$          #Canned Fine Bore (shift) Cycle
      pdrlcommonb
        prdrlout, shftdrl$, dwell$, *feed, strcantext, e$
      pcom_movea
pmisc2$          #Canned Rigid Tapping Cycle
      pdrlcommonb
      #RH/LH based on spindle direction
      result = newfs(12, feed)
      pcom_movea
      if drillcyc$ = 9,
      numpeck = peck2$,
      peck_cnt = numpeck
      pcan1, pbld, n$, *sgdrlref, *sg84, pdrlxy, *strt_depth, pcout, prdrlout,*refht_a, *feed, strcantext, e$
      count = peck_cnt
      pass = 1
      WHILE count > 1,
       pass = pass + 1
       count = count - 1
       pcom_movea
pdrlcst8         #Canned Descending Peck Drill Cycle
      pdrlcommonb
      result = nwadrs(stri, peck1$)
        prdrlout, *peck1$, *peck2$, *peckclr$, *feed, strcantext, e$
      pcom_movea
# ADDITIONAL HOLES
pdrill_2$        #Canned Drill Cycle, additional points
      pdrlcommonb
      pcan1, pbld, n$, pxout, pyout, pzout, pcout, prdrlout, feed, strcantext, e$
      pcom_movea
ppeck_2$         #Canned Peck Drill Cycle
      pdrill_2$
pchpbrk_2$       #Canned Chip Break Cycle
      pdrill_2$
ptap_2$          #Canned Tap Cycle
      pdrill_2$
pbore1_2$        #Canned Bore #1 Cycle
      pdrill_2$
pbore2_2$        #Canned Bore #2 Cycle
      pdrill_2$
pmisc1_2$        #Canned Fine Bore (shift) Cycle
      pdrill_2$
pmisc2_2$        #Canned Rigid Tapping Cycle
      pdrlcommonb
      pcan1, pbld, n$, pxout, pyout, pzout, pcout, prdrlout, strcantext, e$
      pcom_movea
pdrlcst_2$       #Custom drill cycles 8 - 19, additional points (user option)
      if drillcyc$ = 9,
      numpeck = peck2$,
      if stepeck = 0,
      peck_cnt = numpeck
      pdrlcommonb
      *SG00 pcan1, pbld, n$, pfxout, pfyout, e$
  *sg84, pcout, *strt_depth, prdrlout, *refht_a, *feed, strcantext, e$
      count = peck_cnt
        pass = 1
      WHILE count > 1,
       pass = pass + 1
       count = count - 1
       pcom_movea
pcanceldc$       #Cancel canned drill cycle
      result = newfs(9, feed)
      result = newfs(three, zinc)
      result = nwadrs(strq, peck1$)
      z$ = initht$
      pxyzcout
      !zabs, !zinc
      prv_gcode$ = zero
      pcan
      pcan1, pbld, n$, sg80, strcantext, e$
      pcan2
  • 3 weeks later...
Update..... I have been able to get the post to almost work. I just need to know how to keep from posting out S0M5 because HAAS control don't like that and reason I need to do all this so if others post out programs if Im not here they work because no one here really knows how to edit or hand write programs but me but they can pull up programs and post that I have written.
That is controlled in the toolchange section of the post where the spindle speed is called. You will need to put some logic in there to look at the drillcyc being used and if it is called to then output something different.
Ok, to get this to work, you need to take advantage of the "next" variables. This is because the post is setup to process data as it is presented in the NCI File. What this means is that the Tool Change codes in the NCI are output before the Drill Cycle info.
There is not a real way to look "forward" in the NCI during NC output. So CNC Software invented a mechanism that helps take care of this for you.
You should have the variable 'getnextop$' initialized to '1' at the start of your post. This tells MP to build the "next variable" table. It does this during the 'NCI Pre-Read' cycle. The get next op routine can scan the NCI, and get info about what is coming "next" in the NCI.
Once the routine is enabled, MP will fill pre-defined variables that allow you to "look ahead", but only for certain situations.
For Drilling, the secret is to check the variable 'nextdc$'. This variable will hold the value of the next NCI 81 'drillcyc$' value.
So at the tool change or SOF, you can add something like this:
if nextdc$ = 8, pcan1, n$, sgcode, sgabsinc, pwcs, pfxout, pfyout, strcantext, e$
else, pcan1, n$, sgcode, sgabsinc, pwcs, pfxout, pfyout, *spindle, *speed, strcantext, e$
I'm writing the start codes from memory, so yours probably looks a little different. The important thing is to add the if/else statement that checks the value of 'nextdc$' and outputs spindle speed only when the drill cycle value does not match your dowel check.
Keep in mind that the 8 canned drill cycles are numbered 0-7. So '8' is the first custom drill cycle number...
Hope that helps,
Colin
ok thanks for the info Colin I will give it a shot and see if I can get it to work. I tried one of the "if" statements as shown in an example above from someone else  ( along with a few other things) but I couldn't get it to work and not saying it won't but just wasn't given enuff info to figure it out.
Hope that helps,
Colin
OK Ran in to my first issue I dont have a "nextdc$" of any sort I do have "drillcyc$" and the "getnextop$" that you stated. I'm guessing I need to use "drillcyc$" so im going to try it until I hope to hear back from someone but thanks for everyones help I have been working on this a while as you can see and no our dealer wont help because they want us to buy the newest ver and the owner wont do it due to $$ and what we have works for what we do in his eyes. He hates software as much as insurance companys.
I could be wrong but I believe nextdc$ is a system variable and even if you don't currently have it in your post you can use it.
Well thanks to everyone's help and I thought I had it before but just needed to get rid of the s0m5 but I was wrong. Im about to just give up cause I have tried every example here and other places. I tried combining diff things  and even tried editing the mpmaster post where again, I could get all my other edits to work but just cant get this dowel pin stop to work to save my life. I understand the logic and how it should work but it just don't for me and I'm sure its prob something dirt simple I'm over looking somewhere. I'm sure I will revisit it again but just wanted to thank those who tried to help. :ouch:
