REDONDANT "COLLANT M8-M9"
Hi,
I'm having repeating coolant ON/OFF how do I fix it you guys know? Thanks.
PS: I programmed two toolpaths with same tool
N102(SLOT)
G0 G17 G40 G49 G53 G80 G90 Z0
T1 M6(.7500, 3/4 CEM 5FLT 1.000LOC)
G0 G90 G54
X1.1922 Y.1537 S1500 M3
G43 H1(D31) Z1. T1 M8 - GOOD TO KEEP(DOC= Z-.035)
Z.1
G1 Z-.035 F10.
G42 D31 X.7375 Y-.1088 F3.
G2 X.625 Y-.1389 I-.1125 J.1949
G1 X-.625 F10.
G2 X-.7375 Y-.1088 I0. J.225 F3.
G1 G40 X-1.1922 Y.1537
G0 Z.1 M9 - BAD TO HAVE
M8 - BAD TO HAVE
Y-.1537
G1 Z-.035 F10.
G42 D31 X-.7375 Y.1088 F3.
G2 X-.625 Y.1389 I.1125 J-.1949
G1 X.625 F10.
G2 X.7375 Y.1088 I0. J-.225 F3.
G1 G40 X1.1922 Y-.1537
G0 Z1. M9 - GOOD TO KEEP
M5
G53 Y0
M1
this is what I have
sm09 : "M09" #Coolant Off (Use sm09_0 through sm09_2)
sm08 : "M8" #Coolant Flood
sm08_1 : "M07" #Coolant Mist
sm08_2 : "M08" #Coolant Tool
sm09_0 : "M9" #Coolant Flood Off
sm09_1 : "M09" #Coolant Mist Off
sm09_2 : "M09" #Coolant Tool Off
scoolant : "" #Target for string
fstrsel sm09 coolant$ scoolant 7 -1
# Coolant output code selection for X style coolant
# Note: To enable X style coolant, click on the General Machine Parameters icon
# in the Machine Definition Manager, Coolant tab, disable first check box
# Output of X style coolant commands in this post is controlled by pcan, pcan1, & pcan2
# This string select is setup using the "Coolant Commands" tab in the "General Machine Parameters"
scool50 : "" #Coolant 1 on value
scool51 : "" #Coolant 1 off value
scool52 : "" #Coolant 2 on value
scool53 : "" #Coolant 2 off value
scool54 : "" #Coolant 3 on value
scool55 : "" #Coolant 3 off value
scool56 : "" #Coolant 4 on value
scool57 : "" #Coolant 4 off value
scool58 : "" #Coolant 5 on value
scool59 : "" #Coolant 5 off value
scool60 : "" #Coolant 6 on value
scool61 : "" #Coolant 6 off value
scool62 : "" #Coolant 7 on value
scool63 : "" #Coolant 7 off value
scool64 : "" #Coolant 8 on value
scool65 : "" #Coolant 8 off value
scool66 : "" #Coolant 9 on value
scool67 : "" #Coolant 9 off value
scool68 : "" #Coolant 10 on value
scool69 : "" #Coolant 10 off value
scoolantx : "" #Target for string
I removed the scoolant at RAPIDOUT then at the end of the Z.1 does not have M9
N102(SLOT)
G0 G90 G54
Z.1
G1 Z-.035 F10.
G1 X-.625 F10.
G0 Z.1 M9 - GONE
M8 - GONE
Y-.1537
G1 Z-.035 F10.
G1 X.625 F10.
G0 Z1. MISSING M9 HERE
M5
G53 Y0
M1
