MPMaster toolpath group name comments?
Hi,
How can you add the toolpath group comments to a MPMaster post? I would like to have it post out what I put in the name for the toolpath group name in the top of the program somewhere.
Like I have 2ND OP on the screen shot. Would like that to be somewhere on the top.
Right now I have to put in a manual entry to do this. The problem with that is that the manual entry still has the issue with not saving whatever you name it after you edit it every time. This has been this way since I can remember. What I mean by that is try to name the manual entry something then go back and change something in the manual entry and see what happens to what you named it. It will be gone and you will have to rename it every time you change it. This is has been a bug for awhile now.
Initialize variable
sgroupname : ""
Add to psof$, ptlchg$ and ptlchg0$ wherever you want the comment to come out, probably before/after "comment$".
sopen_prn, sgroupname, sclose_prn, e$
Add to pparameter$ postblock
 #Group Comment
 if prmcode$ = 20018, sgroupname = sparameter$
Initialize variable
sgroupname : ""
 #Group Comment
Thanks John. But for some reason I get a error. Maybe I am putting in at the wrong place.
Here is the error I am getting
g 2013 04:18:32 PM - <2> - Initialization of pre-defined post variables, strings, postblocks was successful.
27 Aug 2013 04:18:32 PM - <2> - Search for defined post variables, strings, postblocks was successful.
27 Aug 2013 04:18:32 PM - <2> - PST LINE (1742) - The post block output type processing has failed!, , Label has not been defined[4]
27 Aug 2013 04:18:32 PM - <2> - PST LINE (1742) - The post block output type processing has failed!, , Label has not been defined[27]
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'mtol$' was re-initialized from 0.0001 to 0.00001
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'met_mtol$' was re-initialized from 0.001 to 0.0001
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'ltol$' was re-initialized from 0.0005 to 0.002
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'maxrad$' was re-initialized from 999.9999 to 999.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'met_maxrad$' was re-initialized from 9999.999 to 9999.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'helix_tol$' was re-initialized from 0.0005 to 0.0001
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'met_helix_tol$' was re-initialized from 0.005 to 0.001
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'atol$' was re-initialized from 0.5 to 0.01
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'dec_seq_right$' was re-initialized from 3. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'dec_seq_left$' was re-initialized from 3. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'sub_seq_typ$' was re-initialized from 0. to 1.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'bldnxtool$' was re-initialized from 0. to 1.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'nobrk$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'nobrkxz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'nobrkyz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'lnobrk$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'lnobrkxz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'lnobrkyz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'arcoutput$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'arcoutputxz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'arcoutputyz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'larcoutput$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'larctypexz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'larcoutputyz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'breakarcs$' was re-initialized from 0. to 2.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'breakarcsxz$' was re-initialized from 0. to 2.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'breakarcsyz$' was re-initialized from 0. to 2.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'lbreakarcs$' was re-initialized from 0. to 2.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'lbreakarcsxz$' was re-initialized from 0. to 2.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'lbreakarcsyz$' was re-initialized from 0. to 2.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'do_full_arc$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'do_full_arcxz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'do_full_arcyz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'ldo_full_arc$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'ldo_full_arcxz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'ldo_full_arcyz$' was re-initialized from 1. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'rotfeed4$' was re-initialized from 2. to 1.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'rotfeed5$' was re-initialized from 3. to 0.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'lrotfeed4$' was re-initialized from 2. to 1.
27 Aug 2013 04:18:32 PM - <2> - CONTROL DEFINITION - Post variable 'sub_level$' was re-initialized from 0. to 0.
27 Aug 2013 04:18:32 PM - <2> - Successful completion of posting process!
This is where I added the changes.
pparameter$ # Run parameter table
if opcode$=13 | opcode$=14, result = fprm (opcode$)
if prmcode$ = 10000, stoper = ucase(sparameter$)
if stoper=snull, stoper = snullop
if prmcode$ = 10010, stock = rpar(sparameter$,1) # Stock to leave in Z
if prmcode$ = 10068, stock1 = rpar(sparameter$,1) # Stock to leave in XY
if prmcode$ = 12068, stock2 = rpar(sparameter$,1) # Stock to leave in Z facing
if prmcode$ = 10020, clearinc = rpar(sparameter$,1) #param 10020 is clearance now and 10021 indicates abs or inc
if prmcode$ = 15100, clearflg = rpar(sparameter$,1)
if prmcode$ = 15145, metvals = rpar(sparameter$,1)
if prmcode$ = 15339, clearstrt = rpar(sparameter$,1)
if prmcode$ = 15346, comp_type = rpar(sparameter$,1)
if prmcode$ = 15182, miscvalon = rpar(sparameter$,1)
if prmcode$ = 20010, sconstplname = ucase(sparameter$)
if prmcode$ = 20011, sconstplcomm = ucase(sparameter$)
if prmcode$ = 20012, stoolplname = ucase(sparameter$)
if prmcode$ = 20013, stoolplcomm = ucase(sparameter$)
if prmcode$ = 20014, swcsplname = ucase(sparameter$)
if prmcode$ = 20015, swcsplcomm = ucase(sparameter$)
if prmcode$ = 20016, smatlname1 = ucase(sparameter$)
if prmcode$ = 20017, smatlname2 = ucase(sparameter$)
if prmcode$ = 20018, stpgrpname = ucase(sparameter$)
if prmcode$ = 12025, rotary_axis2 = rpar(sparameter$,1) #Capture the axis of rotation in Multiaxis Drill and Curve 5 Axis
if prmcode$ = 15371, axissubdir = rpar(sparameter$,1)
if prmcode$ = 12628,
if prmcode$ = 20018, sgroupname = sparameter$ #Group comment <<<<<<<----------- Added this here.................>>>>>>>>>>>>>
hst_flg = 1
hststyle = rpar(sparameter$,1)
pwrttparam$ #Information from parameters
Misc variables
tcnt : 0 #Count the number of tool changes
toolcount : 1 #Tool counter for logic control
toolcountn : 0 #Next tool counter for logic control
toolcountp : 0 #Previous tool counter for logic control
tooltotal : 0 #Tool tool count
nexttool : 0 #Next actual tool
counter : 0 #Counter
nstrlen : 0 #Length of string
stock_typ : 0 #Predator Stock Type
cyl_typ : 0 #Predator Cyl Stock Type
z_min$ : 99999 #Min Z
z_tmin : 99999 #Overall min Z
z_max$ : -99999 #Max Z
z_tmax : -99999 #Overall max Z
sav_mi9 : 0 #Saved mi9 value
rotretflg : 0 #Flag used for indexing lock code output
compwarnflg : 0 #Flag for compensation warning output
sof : 1 #Indicates start of file through toolchange
header : 1 #Indicates start of file (header) for comment output
miscvalon : 0 #Flag for warning that misc values are set to post default
abs2incflg : 0 #Flag for post change from abs to inc output for rot_type = 2
axissubdir : 0 #Direction of current axis substitution 0 = CCW, 1 = CW
retractflg : 0 #Flag to indicate retract at null toolchange
mr1_flg : 0 #Flag to indicate whether look ahead function is active or not
lim_flg : 0 #Flag to only output limit warning once
tilt_flg : 0 #Flag to only output tilt limit warning once
hst_flg : 0 #Flag to output HST comments
sgroupname : "" #Flag to output groupname comments <<<<<<<<<<<<<<<< Added this here............>>>>>>>>>>>>>>>>>>>>>>
# Start of File and Toolchange Setup
psof0$ #Start of file for tool zero
psof$
sopen_prn, sgroupname, sclose_prn, e$ <<<<<<<<<<<<<<<<<<<<<<<<Added this here.......................>>>>>>>>>>>>>>>>>>>>>>>
psof$ #Start of file for non-zero tool number
ptravel
pwritbuf5
pcuttype
I just took a look at the mpmaster post and the logic is already there for what you want to do. Remove all the code that I gave you earlier and uncomment the following in pcomment3
#	 if stpgrpname <> snull, pbld, n$, pspc, scomm_str, "TOOLPATH GROUP - ", stpgrpname, scomm_end, e$
Just for reference the issues with the what you had were
1. The IF statement was inside of another IF improperly.
2. Not sure that was exactly where you whanted the sgroupname to be output
3. Your post didn't have "sopen_prn" and "sclose_prn" strings defined.
Great thanks . Worked perfect. I thought it was in there.
