Canned text output postion?
Darin
I would like the canned text to output after the operation's finished just before the last G00 Z retract. When I select add after it outputs it before my operation. Where can I change this in this post?
This is how it outputs now with add after on a canned text
N100 G20
N110 G91 G28 Z0.
N120 G91 G28 X0. Y0. B0.
N130 G00 G17 G40 G49 G80 G90
N17 M01 ( 1-1/4 END MILL )
N140 T17 M06
N150 G00 G90 G55 X2.4218 Y2.4218 B0. S450 M03
N160 G43 H17 Z.1
N170 M05 <------------------------------- Need this to be before the G00 Z.1---------------------------------------->
N180 G01 Z-16.5 F15.
N190 G02 X2.6048 Y1.9799 I-.4419 J-.4419
N200 X1.9799 Y1.355 I-.6249 J0.
N210 X1.355 Y1.9799 I0. J.6249
N220 X1.9799 Y2.6048 I.6249 J0.
N230 X2.4218 Y2.4218 I0. J-.6249
N240 G00 Z.1
This is how I would like it to post
N100 G20
N110 G91 G28 Z0.
N140 T17 M06
N160 G43 H17 Z.1
N235 M05 <--------------------------------Post here---------------------------------->
N240 G00 Z.1
Here is the post
[post_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V16.00 P0 E1 W16.00 T1368216059 M16.00 I0 O0
# Post Name : Fanuc 4X Mill.pst
# Product : Mill
# Machine Name : Mill
# Control Name : Fanuc
# Description : Generic 4 Axis Mill Post
# 4-axis/Axis subs. : Yes
# 5-axis : No
# Subprograms : Yes
# Executable : MP 14.0
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# THIS POST REQUIRES A VALID 3 OR 4 AXIS MACHINE DEFINITION.
# YOU WILL RECEIVE AN ERROR MESSAGE IF MORE THAN ONE ROTARY AXIS IS DETECTED IN
# THE ACTIVE AXIS COMBINATION WITH READ_MD SET TO YES.
# Associated File List$
# GENERIC FANUC 4X MILL.control-5
# Revision log:
# CNC 06/09/05 - Initial post setup for Mastercam X
# CNC 10/06/05 - Changed parameter read for min_speed, modified pspindle, pprep$ and pset_mach
# - Modified pset_rot_label to use srot_y for horizontal machines
# - Added call to pset_mach in pq$ to set rotaxtyp$
Try this, First save a copy of your post and search for the following,
pcom_movea #Common motion preparation routines, after
pcan2
pe_inc_calc
Change to this,
#pcan2<----------------------------------------------------------------------------------------Note: #
pe_inc_calc
Then search for the following section,
pretract #End of tool path, toolchange
sav_absinc = absinc$
absinc$ = one
sav_coolant = coolant$
coolant$ = zero
# if nextop$ = 1003, #Uncomment this line to leave coolant on until eof unless
[ # explicitely turned off through a canned text edit
if all_cool_off,
#all coolant off with a single off code here
if coolant_on, pbld, n$, sall_cool_off, e$
coolant_on = zero
else,
local_int = zero
coolantx = zero
while local_int < 20 & coolant_on > 0,
coolantx = and(2^local_int, coolant_on)
local_int = local_int + one
if coolantx > zero,
coolantx = local_int
pbld, n$, scoolantx, e$
coolantx = zero
coolant_on = zero
#cc_pos is reset in the toolchange here
cc_pos$ = zero
gcode$ = zero
pbld, n$, sccomp, *sm05, psub_end_mny, pcan2, e$ <--------------------------------------Note: pcan2 is inserted
pbld, n$, sgabsinc, sgcode, *sg28ref, "Z0.", scoolant, e$
if nextop$ = 1003 | tlchg_home, pbld, n$, *sg28ref, "X0.", "Y0.", protretinc, e$
else, pbld, n$, protretinc, e$
absinc$ = sav_absinc
coolant$ = sav_coolant
This should do it,
