How do I force the depth of cut each operation with same tool Z depth?
Hi,
I'm having problem that the NOTE SYSTEM does not output each different Z depth out as in the "()". Please take at the bottom
ps: it seem likes it takes the highest Z depth number and wouldn't update if the Z depth is changed for the next toolpath Z-depth...
N4(SPOT 8-32 , DOC-.104)
G0 G17 G40 G49 G53 G80 G90 Z0
T4 M6(.375, X90 DEG SPOT DR, 2FLT)
G0 G90 G54
X.505 Y-1.85 S5500 M3
G43 H4 Z1. T5 M8(DOC= Z-.128)
G98 G82 Z-.104 R.1 P2 F15.5
X2.205
G80
(DOC= Z-.128)
(SPOT 10-32, DOC-.095)
X.36 Y-3.68
G98 G82 Z-.095 R.1 P0 F15.5
X3.16
G80
(DOC= Z-.128)
(SPOT .221 HOLES)
Y-.929
G98 G82 Z-.11 R.1 P0 F15.5
Y-2.929
X1.1094 Y-.8784
G80
(DOC= Z-.128)
(SPOT .252 HOLE)
X1.36 Y-.3
G98 G82 Z-.128 R.1 P0 F15.5
G80
(DOC= Z-.128)
(SPOT SLOT)
Y-3.3
G80 M9
M5
G53 Y0
M1
Here it is:
Define 2 variables:
operation_depth : 0 # Operation full depth
last_op_id : 0 # OP tracking ID
Format output of DOC:
fmt "Z" 2 operation_depth # Operation full depth
At psof$ postblock put these 2 lines somewhere near to comment (comment$)
ptoolcomment
comment$
"( DOC =", *operation_depth, ")", e$
last_op_id = op_id$
pcan
pbld, n$, *t$, sm06, e$
At ptlchg0$ postblock put these logic somewhere near to comment (comment$)
Also "!op_id$" have to be there!
 comment$
 if op_id$ <> last_op_id,
 last_op_id = op_id$
 !op_id$
 pcan
 pbld, n$, sgplane, e$
 pspindchng
Do the same at ptlchg$ postblock:
 ptoolcomment
 comment$
 last_op_id = op_id$
 !op_id$
 pcan
Add this parameter read at pparameter$ postblock:
if prmcode$ = 10029, operation_depth = rpar(sparameter$, 1) #Capture the full depth of OP
Well? :coffee:
Thank you Peter, I got it worked. I would like to modify a little, would you mind?
Thankful for your help.
____________________________
N1(ROUGH MILL .03 FROM TOP DOWN TOP 2.220THK)
T1 M6(3.000" HERTEL FACEMILL)
G90 G54(XY STK.= -.25)
X13.4599 Y3.5501 S5000 M3
G43 H1(D31) Z.12 T2 M8(DOC= Z0.) -----------> GOOD
G1 Z0. F50.
G41 D31 X11.76
X-.01
G40 X-1.7099
G0 Z.1
Z.12
(DOC= Z0.) ---------------> I WOULD LIKE TO REMOVE IT
Y1.2499
G1 Z0.
G41 D31 X-.01
X11.76
G40 X13.4599
G0 Z.1 M9
M5
G53 Y0
M1
  • 4 weeks later...
This one shows...
N2(, CUT#18)
T2 M6(.515, 33/64" STUB DRILL )
G90 G54
X-4.542 Y11.4162 S3000 M3
G43 H2 Z.1 T3 M8(DOC= Z-.62)
G99 G83 Z-.7368 R.1 Q.1 F25.
X-2.7117 Y5.4297
X2.7117
X4.542 Y11.4162
G80 M9
M5
G53 Y0
M1
I have my Z is Z-.62 in my DEPTH... parameter
and I have my TIP COMP is .10679
Is there away I can make DEPTH + TIP LENGTH so it can appear Z-.7368?
Can you assist me how to define the STOCK TO LEAVE ON FLOORS? I found out that the operation_depth only reads out from the DEPTH but I would like it to SUBTRACT the STOCK TO LEAVE ON FLOOR so it would match the calulation on the map.
Therefore, how may I define the STOCK TO LEAVE ON FLOORS like
operation_depth + stock to leave on floor then it would be the right one from the G-Codes.
X-2.7117 Y5.4297
Hi Steven! Good thing that you catched this!
Need some improvement, I'll work on it! I didn't think about this issue when I made it.
I'll be back. ;)
Is there away I can add TIP COMP "LIP LENGTH" value into the "Depth..." value in the LINKING PARAMETERS PAGE?
I think that may be easier that way because I'm still having same problem for miss-calculating.
ps: I mean, the final Z-DEPTH in the G-CODES...
N1(3.0000 MITSUBISHI "SE300R03060" 90DEG 6FLTS .500LOC SHELL MILL)
T1 M6(SKIM CUT RAW MATERIAL, CUT#2)
G90 G54
X1.65 Y.7874 S7000 M3
G43 H1(D31) Z1. T2 M8
Z.15
G1 Z.005 F50. ==============> FINAL ONE
X-22.9098
Z0.
X1.65
G0 Z1. M9
M5
G53 Y0
M1
Thanks.
