Makino A99 Post
Odin
I think its G43. here is the first ten lines of the program.
O0000(SC4 HELPER)
G17G40G49G80
(T37 2.0 HELIMILL .063 CR )
M741(CONVEYOR ON)
G0G90G40G54X-7.3568Y-.5108S955M3
G43H37Z2.
G05P10000
Z.1
G1Z.065F100.
The machine alarms out on the highlighted line.
Yeah, are sister company failed to tell us that the sent us the wrong machine, the machine we got doesn't have the SGI. they are pulling the board out as I'm typing. I also have another program error. it is 003 too many digits. I cant figure that one out,. in the post under the format statements it has this...
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (:)
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place (feedrate)
fs2 16 1 0 1 0n #Integer, forced output
fs2 17 0.2 0.3 #Decimal, absolute, 2/3 place (tapping feedrate)
I'm not sure what to do! is it a post problem or a machine parameter issue?
TIA
Yes, they are formatted inside the post. You should see a line like this "
fmt "C" 2 P9990_C
This is formatting the variable P9990_C to an absolute decimal 4/3
Find the variable you need to change and see what it is formatting it to. It's is as simple as changing that number in the fmt statement.
There is no fmt "C" P9990_C in the post anywhere, this is thefmt lines in the post,
# Toolchange / NC output Variable Formats
fmt "T" 4 t$ #Tool Number
fmt "T" 4 first_tool$ #First Tool Used
fmt "T" 4 next_tool$ #Next Tool Used
fmt "D" 4 tloffno$ #Diameter Offset Number
fmt "H" 4 tlngno$ #Length Offset Number
fmt "G" 4 g_wcs #WCS G address
fmt "P" 4 p_wcs #WCS P address
fmt "S" 4 speed #Spindle Speed
fmt "M" 4 gear #Gear range
fmt "N" 4 n$ #Sequence number
fmt "X" 2 xabs #X position output
fmt "Y" 2 yabs #Y position output
fmt "Z" 2 zabs #Z position output
fmt "X" 3 xinc #X position output
fmt "Y" 3 yinc #Y position output
fmt "Z" 3 zinc #Z position output
fmt "B" 11 cabs #C axis position
fmt "B" 14 cinc #C axis position
fmt "B" 4 indx_out #Index position
fmt "R" 14 rt_cinc #C axis position, G68
fmt "I" 3 i$ #Arc center description in X
fmt "J" 3 j$ #Arc center description in Y
fmt "K" 3 k$ #Arc center description in Z
fmt "R" 2 arcrad$ #Arc Radius
fmt "F" 15 feed #Feedrate
fmt "P" 11 dwell$ #Dwell
fmt "M" 5 cantext$ #Canned text
fmt "P" 4 dtloffno
fmt "R" 1 mr1$
#CNC<<MSG-ERROR(498)>> The format statement number is not defined (default to 1)
#CNC<<MSG-ERROR(497)>> The format statement number is not defined (default to 1)
#Move comment (pound) to output colon with program numbers
fmt "O" 7 progno$ #Program number
#fmt ":" 7 progno$ #Program number
fmt "O" 7 main_prg_no$ #Program number
#fmt ":" 7 main_prg_no$ #Program number
fmt "O" 7 sub_prg_no$ #Program number
#fmt ":" 7 sub_prg_no$ #Program number
fmt "X" 2 sub_trnsx$ #Rotation point
fmt "Y" 2 sub_trnsy$ #Rotation point
fmt "Z" 2 sub_trnsz$ #Rotation point
fmt "Q" 2 peck1$ #First peck increment (positive)
fmt "I" 2 peck2$
fmt "Q" 2 shftdrl$ #Fine bore tool shift
fmt "R" 2 refht_a #Reference height
fmt "R" 2 refht_i #Reference height
fmt "T" 4 tnote # Note format
fmt " DIA. OFF. - " 4 toffnote # Note format
fmt " LEN. - " 4 tlngnote # Note format
fmt " DIA. - " 1 tldia$ # Note format
